19031122A
19031122A
    COMAIRROTRON
    19031122A
19031122A 数据手册
SPECIFICATIONS Model Number: Part Number: PQ48S3HBDLX 19031122A August 1, 2010 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 48 vdc = 24 - 56 vdc = 0.460 Amps = 1.00 Amps = 24 Watts = 3500 RPM = Ball = 235 CFM = 51.2 dBA Brushless DC Motor Polarity Protected Automatic Restart Capability Locked Rotor Protection Bipolar Output FPS Thermal Speed Control: Operating Temperature: Storage Temperature: Fan Performance Sensor: FPS UL, CUL, CE Power Supply: Isolated: Delay: Latching: Trip Point: Pass Level: Fail Level: Life Expectancy: Termination: Construction: Venturi: Single Piece, Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 Agency Approvals: This fan is designed for continuous duty life of 77,000 hours at 40C PTC in Hub -10C to +70C -40C to +85C 5 vdc Yes 10  4 seconds Yes 1500  300 RPM 2.75 Min. to 5.50 Max. Vdc 0.00 Min. to 2.25 Max. Vdc 26” Leadwires, AWG 22, UL 1061 Red/White = Fan Power (+) Black/White = Fan Return (-) Red = FPS Power (+) Black = FPS Return (-) Blue = FPS Output
19031122A 价格&库存
很抱歉,暂时无法提供与“19031122A”相匹配的价格&库存,您可以联系我们找货
