226P
226P
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 20VA THRU HOLE
226P 数据手册
10/6/22, 9:06 AM Low Voltage PCB Mount - Epoxy Cast - 1 VA to 40 VA (226-227-228 Series) - Hammond Mfg. Quality Products. Service Excellence. Low Voltage PCB Mount - Epoxy Cast - 1 VA to 40 VA 226-227-228 Series Features Primary 115 VAC, 60 or 400Hz. models, 3 case sizes Epoxy cast to withstand shock and severe environments Two coil design provides balanced windings and low magnetic radiation - no electrostatic shield required. 228 series include four, 6-32 X .38 machine screw inserts for less strain on p.c. board connections.     https://www.hammfg.com/electronics/transformers/power/226-227-228 1/2 10/6/22, 9:06 AM Low Voltage PCB Mount - Epoxy Cast - 1 VA to 40 VA (226-227-228 Series) - Hammond Mfg. 226 Series: Size Freq. Part No. (VA) (Hz) Secondary (RMS) Temp. Rise % High Pin Regulation Max Diameter Weight Series Parallel (C) 226D 1 60 20V C.T. @ 50ma 10V @ 100ma 25 19.7 0.8 0.04 0.22 lbs. 226F 1 60 30V C.T. @ 34ma 15V @ 67ma 25 21.7 0.8 0.04 0.22 226H 1 60 40V C.T. @ 25ma 20V @ 50ma 25 18.9 0.8 0.04 0.22 226N 20 400 20V C.T. @ 1A 10V @ 2A 35 7.2 0.8 0.04 0.22 226P 20 400 26V C.T. @ 770ma 13V @ 1.54A 35 7.6 0.8 0.04 0.22 226R 20 400 30V C.T. @ 670ma 15V @ 1.33A 35 7.5 0.8 0.04 0.22 226T 20 400 40V C.T. @ 500ma 20V @ 1A 35 7.2 0.8 0.04 0.22 Temp. Rise % High Pin Weight 227 Series: Size Freq. Part No. (VA) (Hz) Secondary (RMS) Series Parallel (C) Regulation Max Diameter lbs. 227D 5 60 20V C.T. @ 250ma 10V @ 500ma 25 20.07 1.05 0.05 0.38 227F 5 60 30V C.T. @ 170ma 15V @ 340ma 25 24 1.05 0.05 0.38 227H 5 60 40V C.T. @ 125ma 20V @ 250ma 25 26 1.05 0.05 0.38 227N 40 400 20V C.T. @ 2A 10V @ 4A 45 6 1.05 0.05 0.38 227P 40 400 26V C.T. @ 1.54A 13V @ 3.08A 45 5.7 1.05 0.05 0.38 227R 40 400 30V C.T. @ 1.33A 15V @ 2.66A 45 6 1.05 0.05 0.38 227T 40 400 40V C.T. @ 1A 20V @ 2A 45 5.7 1.05 0.05 0.38 % High Pin Weight 228 Series: Size Freq. Part No. (VA) (Hz) Secondary (RMS) Temp. Rise Series Parallel (C) Regulation Max Diameter 10V @ 1A 20 12.2 1.22 0.50 0.91 lbs. 228D 10 60 20V C.T. @ 500ma 228F 10 60 30V C.T. @ 340ma 15V @ 670ma 20 12.5 1.22 0.50 0.91 228H 10 60 40V C.T. @ 250ma 20V @ 500ma 20 12.2 1.22 0.50 0.91 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/power/226-227-228 2/2
很抱歉,暂时无法提供与“226P”相匹配的价格&库存,您可以联系我们找货
