19041261A
19041261A
    COMAIRROTRON
    19041261A
19041261A 数据手册
SPECIFICATIONS Model Number: Part Number: GL12K6PNDNX 19041261A Jan 5, 2009 Mechanical Drawing: Motor: High Speed Galaxy Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Max Program Speed Min Program Speed Bearings Airflow (at full-speed) Acoustic Additional Features: = 12 VDC = 6 - 14 vdc = 1.650 amps = 4.000 amps = 19.8 watts = 3550 (RPM) = 2950 (RPM) = Ball = 160 CFM = 55.5 dBA Construction: Venturi: Die Cast Zinc, Black Propeller: Polycarbonate, Black, UL94V-0 Life Expectancy: This fan is designed for continuous duty life of 80,000 hours at 40°C Agencies: UL, CUL, CE Fault Tolerant System Brushless DC Motors Electronic Locked Rotor Protection Polarity Protected 14 volt operation has max. operating temp of 50°C Alarm Features: Output: Open Collector Ic Logic: Delay: Latching: Isolated: 20mA Max. Low on Pass/High on Fail Yes No No Termination: Harness Assembly, 190+10mm, 22 AWG, UL1061 leadwires ,Connector: Molex 39-01-4051 Terminals: Molex 39-00-0181 Pin 1 – Return (Black) Pin 2 – Power (Red) Pin 3 – Alarm (Blue/White) Pin 4 – Program Lead (Yellow) Pin 5 – Not used
19041261A 价格&库存
很抱歉,暂时无法提供与“19041261A”相匹配的价格&库存,您可以联系我们找货
