SPECIFICATIONS
Model Number:
Part Number:
PQ24B7-E2
19039032A
June 23, 2003
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Running Current
Locked Rotor Current
Running Power
Average Speed
Air Flow
Bearings
Acoustic
Features:
= 24 vdc
= 12 - 28 vdc
= 1.00 amps
= 2.00 amps
= 24 watts
= 3500 RPM
= 235 CFM
= Ball
= 51.2 dBA
Brushless DC Motor
Locked Rotor Protection
Automatic Restart Capability
Polarity Protected
Operating Temperature:
-10°C to 70°C
Storage Temperature:
-40°C to 85°C
Environmental Type II Coating
Tachometer Specifications:
Venturi: Single Piece, Die-Cast Aluminum, Black
Propeller: Plastic, Black, UL 94V-0
5 volt TTL Compatible
Ic:
5 vdc Typical
Pulses Per Revolution: 2
Isolated:
No
Agency Approvals:
Termination:
UL, CE
12” Lead-wires, AWG 22, UL 1061
Red:
= Power (+)
Black:
= Return (-)
Blue/White:
= Tachometer (Output)
Construction:
Life Expectancy:
This fan is designed for continuous duty life of
82,500 hours at 50°C.
Output:
很抱歉,暂时无法提供与“19039032A”相匹配的价格&库存,您可以联系我们找货
