19040451A
19040451A
    COMAIRROTRON
19040451A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: DD692148K1A-E2 Part Number: 19040451A SPEC Number: 26011951A03 Feb 26, 2013 Mechanical Drawing: Motor: Additional Features: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 48 vdc = 24 - 72 vdc = 0.650 amps = 2.0 amps = 31.20 watts = 3000 rpm = Ball = 250 cfm = 67.2 dBA Brushless DC Motor Polarity Protected Locked Rotor Protection Automatic Reset Capability Soft Start Capability Operating Temperature: Storage Temperature: Enviro-Shield Type 2 -40C to 75C -50C to 85C Tachometer: Construction: Life Expectancy: 5volt TTL Compatible Ic: 5mA Typ Pulses per Revolution: 2 Isolated: No This fan is designed for continuous duty life of 55,000 hours at 40C. Termination: Motor Base: Propeller: Die Cast Aluminum Sheet Metal, Galvanized Agency Approvals: UL, CUR, CE Output: 12” Lead-wires, AWG 22, UL1061 Red = Power (+) Black = Ground (-) Blue/White = Tachometer
19040451A 价格&库存
很抱歉,暂时无法提供与“19040451A”相匹配的价格&库存,您可以联系我们找货
