19039306A
19039306A
    COMAIRROTRON
    插件
    19039306A
19039306A 数据手册
SPECIFICATIONS Model Number: Part Number: CLE3L5 19039306A Rev:02 Aug 07, 2018 Mechanical Drawing: Motor: Nominal Voltage Frequency Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Max. Airflow Max. Static Pressure Acoustic Additional Features: = 220/230 VAC = 50/60 Hz = 0.44/0.57 amps = 1.00 amps = 98/135 watts = 2650/2800 RPM = Ball = 878/950 CFM = 0.50/0.57inch H2O = 62.1/63.3 dBA Construction: Venturi: Aluminum, Black. Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 45,000 hours at 60C. Permanent Split Capacitor Motor Automatic Reset Thermal Protector Automatic Restart Capability Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Termination: 24” Lead wires, 18 AWG, UL 1015 Agency Approvals: UL, CUL, CE PQ Curve:
19039306A 价格&库存
很抱歉,暂时无法提供与“19039306A”相匹配的价格&库存,您可以联系我们找货
