SPECIFICATIONS
Part Number:
19028887A
Model Number: MD48B5
(RoHS Compliant)
Drawing Number:26007403A 01
Jan.25.2013
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 48 vdc
= 24 – 56 vdc
= 0.120 amps
= 0.400 amps
= 5.8 watts
= 3100 rpm
= Ball
= 110 CFM
= 50.0 dBA
Construction:
Venturi: Die-Cast Zinc Alloy, Black
Propeller: Plastic, Black, UL 94V-0
Agency Certifications:
UL, CE
Life Expectancy:
This fan is designed for continuous duty life of 83,000
hours at 40C.
Brushless DC Motor
Automatic Restart Capability
Locked Rotor Protection
Polarity Protected
Operating Temperature:
Storage Temperature:
-10C to 70C
-40C to 85C
Tachometer Output:
Output:
5 volt TTL Compatible
Ic:
5mA Typical
Pulses per Revolution: 1
Isolated:
No
Termination:
12” Lead wires, 22 AWG, UL 1061
Red
= Power (+)
Black
= Return (-)
Blue/White
= Tachometer (Output)
很抱歉,暂时无法提供与“19028887A”相匹配的价格&库存,您可以联系我们找货
