Comair Rotron Specification Sheet
Specification Date: Nov 30, 2017
Version:03
COMAIR ROTRON PART NUMBER:
COMAIR ROTRON MODEL NUMBER:
19040965A
DDE114948K1E
A.) MOTOR:
RATED VOLTAGE:
48 Vdc
OPERATING VOLTAGE RANGE:
36 Vdc – 60 Vdc
LOW-START VOLTAGE:
36 Vdc
RUNNING CURRENT:
2.6 Amps
LOCKED ROTOR CURRENT:
4.0 Amps
RATED POWER:
125 Watts
NOMINAL SPEED:
1900 RPM
(At Free Delivery)
START UP TIME:
8 Seconds Maximum
MOTOR TYPE:
Brushless DC
MOTOR PROTECTION:
By Integrated Circuit, Fuse
LOCKED ROTORT PROTECTION:
Electronic
POLARITY PROTECTION:
Yes
AUTOMATIC RESTART CAPABILITY:
ROTATION:
Clockwise when viewed from Inlet
B.) MECHANICAL
DIMENSIONS:
281mm Dia. x 125mm
(11.0” Dia. x 4.90”) Figure 1
2.50 Kg (5.52 Lbs.)
WEIGHT:
BEARING TYPE:
MOTOR BASE:
Ball Bearing, Permanently Lubricated,
Shielded
Die Cast Aluminum
PROPELLER:
Metal, plated
-1-
Version:03
Figure 1
C.) ADDITIONAL FEATURES
TACHOMETER OUTPUT:
Open Collector
IC = 10 mA. Max.
Pulses per Revolution: 3
Isolated: No
D.) SPEED CONTROL
Voltage:
Response:
0~10V
9V, full speed
E.) ENVIRONMENTAL
OPERATING TEMPERATURE:
-10C to +70C
STORAGE TEMPERATURE:
-40C to +85 C, 65% 20% RH
HUMIDITY:
5% to 95% RH, non-condensing
VIBRATION:
3G’s (20 to 200 Hz)
-2-
Version:03
E.) PERFORMANCE CHARACTERISTICS
AIR FLOW:
1070 CFM 10%
(Measuring at zero static pressure)
STATIC PRESSURE:
1.86” Inches of H2O
(Measuring at zero air flow)
ACOUSTIC LEVEL:
78.0 dBA
(Freely Suspended at 1 meter per
ANSI S12.11-1987)
Figure 2
-3-
Version:03
F.) TERMINATION
HARNESS:
457.2mm 25.4mm (18” 1”)
18 AWG, UL 1007 Style
(From the edge of the motor base to the tip
of the connector. )
Connector: Molex 39-01-2040
Terminals: Molex 39-00-0059
COLOR DESIGNATION:
Red
Black
Blue/White
Yellow
G.) RELIABILITY
This fan is designed for continuous duty life of 42,000 Hours at 40C, (L10)
H.) SAFETY
UL,CUL,CE
I.) Flammability
The blower including all components meets an UL94V-0 rating or better.
Notes:
All parameters will perhaps fluctuate with the speed tolerance by 10%.
-4-
= Power (+)
= Return (-)
= Tachometer Output
= Speed control
很抱歉,暂时无法提供与“19040965A”相匹配的价格&库存,您可以联系我们找货
