10/6/22, 6:26 AM
High Voltage (Plate) - 259 VA to 1610 VA (700 Series) - Hammond Mfg.
Quality Products. Service Excellence.
High Voltage (Plate) - 259 VA to 1610 VA 700 Series
115 V or 117/234 V Primary
Features
Two versions available:
Primary 115 VAC, 50/60 Hz. or
Primary 117/234 VAC, 50/60 Hz.
At 2,000 VAC and above, secondary leads are through rubber bushings (figure B).
Units can be run full wave bridge or full wave C.T.
V.A. is a C.C.S. rating
Current ratings are CCS (Continuous Commercial Service) & ICAS ratings (Intermittent
Commercial or Amateur Service).
Enclosed, 4 hole chassis mount.
Minimum 6" long leads.
Class A insulation (105 degrees C).
Hi-Pot test at a minimum of twice secondary voltage
Conservative designs - CSA certified (209651).
For other H.V. combinations check out our Peter W. Dahl series as well.
Notes:
VA rating specified is CCS (Continuous Commercial Service)
ICAS ratings (Intermittent Commercial or Amateur Service)
115VAC only models - Input Black & Black
Dual Primary (117/230VAC) models - 117VAC input: connect Blue to Black and
Brown to White.
234VAC input: connect Brown to Black - input is Blue & White
Gallery
A.C. High Voltage
H.V. Secondary
Part No.
Part No.
Secondary
115 VAC Primary
117/234 VAC Primary
V.A.
R.M.S.
(CCS)
(ICAS)
(Lbs)
710
710A
259
750V C.T.
345ma.
518ma.
7.2
712
712A
293
850V C.T.
345ma.
518ma.
8.8
714
714A
200
1,020V C.T.
196ma.
288ma.
5.5
715
715A
352
1,020V C.T.
300ma.
450ma.
9
717
717A
510
1,020V C.T.
500ma.
750ma.
17.7
718
718A
235
1,250V C.T.
200ma.
300ma.
8
720
720A
370
1,250V C.T.
300ma.
450ma.
12
722
722A
720
1,250V C.T.
575ma.
863ma
17.7
724
724A
345
1,500V C.T.
226ma.
339ma.
12
726
726A
312
1,780V C.T.
202ma.
299ma.
12
728
728A
346
2,000V C.T.
173ma.
259ma.
12
https://www.hammfg.com/electronics/transformers/classic/700
Current
Weight
1/2
10/6/22, 6:26 AM
A.C. High Voltage
H.V. Secondary
Part No.
Part No.
Secondary
115 VAC Primary
117/234 VAC Primary
V.A.
R.M.S.
(CCS)
Current
(ICAS)
Weight
(Lbs)
732
732A
500
2,500V C.T.
200ma.
300ma.
17.7
733
733A
750
2,500V C.T.
300ma.
450ma.
24
735
735A
735
3,000V C.T.
250ma.
375ma.
24
737
737A
1200
3,000V C.T.
400ma.
600ma.
28.5
739
739A
1610
3,500V C.T.
375ma.
565ma.
34.7
742A
1250
5,000V C.T.
250ma.
375ma.
26
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“714A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1597.901781+206.71299
