10/5/22, 3:32 AM
Plate & Filament - 22 VA to 248 VA (260 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Plate & Filament - 22 VA to 248 VA 260 Series
Universal Primary & 50/60 Hz. Operation
Features
Universal primary with taps for 100, 120, 220 or 240 VAC, 50/60 Hz. (Except the 260A6
which is 117V, 50/60 Hz only)
Designed for preamps, low power amps, general replacement, test equipment, etc.
Economical, open frame, chassis mount - two hole (.187 dia. = G) channel bracket (figure
#1) or four hole mounting (figure #2).
Units include a Faraday shield between the primary and secondary windings. Our
electrostatic shield reduces the capacitive coupling from the primary - greatly attenuating
higher frequency current coupling to the secondaries.
Minimum 5" long leads.
For more selection check out our 300 Series of universal plate & filament transformers.
NOTES
1. These units are designed to run with BOTH primary windings energized for maximum
efficiency (see wiring table below).
2. The Faraday shield lead - the gray wire - marked SH (shield) above, should remain
grounded to the mounting bracket & in turn to the chassis.
Gallery
A.C. High Voltage
A.C. Filament
A.C. Filament
Figure #
Secondary #1
Secondary #2
Secondary #3
or PDF
File
A
Part No.
VA
RMS
RMS
RMS
Dimensions
B
C
D
E
G
0.19
260A
22
400V C.T. @ 40ma.
6.3V C.T. @ 1A
1
3.25
2.00
2.00
2.81
260A6
57
740V C.T. @ 60ma.
6.3V C.T. @ 2A
See PDF
2.5
2.155
3
260C
65
500V C.T @ 85ma..
5V @ 2A
6.3V C.T. @ 2A
1
4.03
2.65
2.62
3.56
0.19
260E
80
450V C.T. @ 115ma.
5V @ 2A
6.3V C.T. @ 3A
See PDF
3.00
3.06
2.53
2.50
2.40
0.21
x
0.38
260G
175
550V C.T. @ 230ma.
5V @ 3A
6.3V C.T. @ 5A
See PDF
3.75
3.50
3.13
3.25
3.25
0.20
x
0.38
260J
152
650V C.T. @ 173ma.
5V @ 2A
6.3V C.T. @ 4A
2
3.75
3.13
3.13
3.12
2.75
0.22
x
0.56
260K
197
650V C.T. @ 230ma.
5V @ 3A
6.3V C.T. @ 5A
2
4.50
3.25
3.75
3.75
3.00
0.22
x
0.56
260M
248
700V C.T. @ 288ma.
5V @ 3A
6.3V C.T. @ 5A
2
4.50
3.25
3.75
3.75
3.00
0.22
x
0.56
Data subject to change without notice
https://www.hammfg.com/electronics/transformers/classic/260
1/2
10/5/22, 3:32 AM
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
