10/5/22, 6:33 AM
Toroidal L.V. - Chassis Mount - 15 VA to 1500 VA (182 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Toroidal L.V. - Chassis Mount - 15 VA to 1500 VA 182 Series
Note: This product line will soon be discontinued as a stocked series. Available while quantities last.
It has been replaced with
1182 Series.
For alternative solution assistance, please contact Hammond here
or call: USA (716) 630-7030, Canada and
International (519) 822-2960.
Features
Low profile, lightweight, cool running - due to high efficiency toroidal design
Dual 117/234 VAC primary, 50/60 Hz. operation
Units are designed to have all windings engaged.
Center single hole mounting - units over 225VA include a potted center (see photos
below) for extra mounting strength.
Supplied with two rubber insulating pads, one metal centering washer and all mounting
hardware (160VA and under)
Supplied with one bottom rubber insulating pad and mounting hardware (225VA and
larger)
Center bolt size varies with VA - see tables below.
Minimum 8" long flexible leads
Hi-Pot test of 4,000V RMS between primary & secondary
CSA certified to C22.2 #66 - CSA file #209651
UL recognized to UL506 - UL file #E207860
CE certified to IEC950
Note about Inrush Current:
Due to the superior magnetic properties of Toroidal transformers they will be susceptible
to high magnetizing current when initially energized, only limited by the low DC resistance
of the primary winding. Depending on where you are in the AC cycle when the
transformer is energized dictates the chances of overloading the supply circuit. This is
why the transformer may sometimes energize without a problem and other times it will
blow the fuse or trip the circuit breaker. The duration of this overload is rarely longer than
a half of a cycle. Therefore, you should consider using a slow-blow fuse, time delayed
circuit breaker or other form of soft start circuitry for the supply line when using these high
efficient Toroidal transformers.
https://www.hammfg.com/electronics/transformers/power/182
1/4
10/5/22, 6:33 AM
Included Mounting Top Steel Mounting Washer
VAC Secondary (RMS)
Dual or Single Toroid Outside
Potted
with Top & Bottom
Weight
Length
Rubber Washer
(lbs.)
8-32
1.50
Yes
0.76
10-24
2.00
Yes
1.12
10-24
2.00
Yes
1.67
10-24
2.00
Yes
2.15
No
8-32
1.50
Yes
0.76
No
10-24
2.00
Yes
1.12
1.73
No
10-24
2.00
Yes
1.67
3.73
1.52
No
10-24
2.00
Yes
2.15
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
Dual
Open
2.70
1.25
No
8-32
1.50
Yes
0.76
Dual
Open
2.95
1.60
No
10-24
2.00
Yes
1.12
12V @ 4.16A
Dual
Open
3.63
1.73
No
10-24
2.00
Yes
1.67
24V C.T. @ 3.33A
12V @ 6.66A
Dual
Open
3.73
1.52
No
10-24
2.00
Yes
2.15
120
24V C.T. @ 5A
12V @ 10A
Dual
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
182Q12
160
24V C.T. @ 6.67A
12V @ 13.34A
Dual
Open
4.43
1.73
No
1/4-20
2.50
Yes
3.87
182S12
225
24V C.T. @ 9.38A
12V @ 18.76A
Dual
Potted
4.97
1.90
Yes
1/4-20
2.50
Bottom Rubber Washer Only
4.96
182T12
300
24V C.T. @ 12.5A
12V @ 25A
Dual
Potted
5.06
2.27
Yes
1/4-20
2.50
5.58
182G15
15
30V C.T. @ .5A
15V @ 1A
Dual
Open
2.70
1.25
No
8-32
1.50
Yes
0.76
182J15
30
30V C.T. @ 1A
15V @ 2A
Dual
Open
2.95
1.60
No
10-24
2.00
Yes
1.12
182K15
50
30V C.T. @ 1.67A
15V @ 3.34A
Dual
Open
3.63
1.73
No
10-24
2.00
Yes
1.67
182M15
80
30V C.T. @ 2.67A
15V @ 5.34A
Dual
Open
3.73
1.52
No
10-24
2.00
Yes
2.15
182N15
120
30V C.T. @ 4A
15V @ 8A
Dual
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
182P15
160
30V C.T. @ 5.33A
15V @ 10.66A
Dual
Open
4.43
1.73
No
1/4-20
2.50
Yes
3.87
182H15
225
30V C.T. @ 7.5A
15V @ 15A
Dual
Potted
4.97
1.90
Yes
1/4-20
2.50
4.96
182S15
300
30V C.T. @ 10A
15V @ 20A
Dual
Potted
5.06
2.27
Yes
1/4-20
2.50
5.58
182F18
15
36V C.T. @ .42A
18V @ .84A
Dual
Open
2.70
1.25
No
8-32
1.50
Yes
0.76
182H18
30
36V C.T. @ .83A
18V @ 1.66A
Dual
Open
2.95
1.60
No
10-24
2.00
Yes
1.12
Part No.
VA
Series
Parallel
Secondary
182K6
15
12V C.T. @ 1.25A
6V @ 2.5A
Dual
Open
2.70
1.25
No
182L6
30
12V C.T. @ 2.5A
6V @ 5A
Dual
Open
2.95
1.60
No
182N6
50
12V C.T. @ 4.17A
6V @ 8.34A
Dual
Open
3.63
1.73
No
182Q6
80
12V C.T. @ 6.67A
6V @ 13.34A
Dual
Open
3.73
1.52
No
182H9
15
18V C.T. @ .83A
9V @ 1.66A
Dual
Open
2.70
1.25
182K9
30
18V C.T. @ 1.67A
9V @ 3.34A
Dual
Open
2.95
1.60
182M9
50
18V C.T. @ 2.78A
9V @ 5.56A
Dual
Open
3.63
182N9
80
18V C.T. @ 4.44A
9V @ 8.88A
Dual
Open
182Q9
120
18V C.T. @ 6.67A
9V @ 13.34A
Dual
182G12
15
24V C.T. @ .63A
12V @ 1.26A
182K12
30
24V C.T. @ 1.25A
12V @ 2.5A
182L12
50
24V C.T. @ 2.08A
182M12
80
182P12
Hardware Size
Center Diameter Height Center Thread
182J18
50
36V C.T. @ 1.39A
18V @ 2.78A
Dual
Open
3.63
1.73
No
10-24
2.00
Yes
1.67
182L18
80
36V C.T. @ 2.22A
18V @ 4.44A
Dual
Open
3.73
1.52
No
10-24
2.00
Yes
2.15
182M18
120
36V C.T. @ 3.33A
18V @ 6.66A
Dual
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
182N18
160
36V C.T. @ 4.44A
18V @ 8.88A
Dual
Open
4.43
1.73
No
1/4-20
2.50
Yes
3.87
182G18
225
36V C.T. @ 6.25A
18V @ 12.5A
Dual
Potted
4.97
1.90
Yes
1/4-20
2.50
4.96
182F22
15
44V C.T. @ .34A
22V @ .68A
Dual
Open
2.70
1.25
No
8-32
1.50
Yes
0.76
182G22
30
44V C.T. @ .68A
22V @ 1.36A
Dual
Open
2.95
1.60
No
10-24
2.00
Yes
1.12
182J22
50
44V C.T. @ 1.14A
22V @ 2.28A
Dual
Open
3.63
1.73
No
10-24
2.00
Yes
1.67
182L22
80
44V C.T. @ 1.82A
22V @ 3.64A
Dual
Open
3.73
1.52
No
10-24
2.00
Yes
2.15
182M22
120
44V C.T. @ 2.73A
22V @ 5.46A
Dual
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
182N22
160
44V C.T. @ 3.64A
22V @ 7.28A
Dual
Open
4.43
1.73
No
1/4-20
2.50
Yes
3.87
182P22
225
44V C.T. @ 5.11A
22V @ 10.22A
Dual
Potted
4.97
1.90
Yes
1/4-20
2.50
4.96
182S24
500 48V C.T. @ 10.42A 24V @ 20.82A
Dual
Potted
5.50
2.21
Yes
1/4-20
2.50
8.46
182T24
625 48V C.T. @ 13.02A 24V @ 26.04A
Dual
Potted
6.10
3.10
Yes
3/8-16
3.50
10.38
182U24
750 48V C.T. @ 15.63A 24V @ 31.26A
Dual
Potted
6.40
3.10
Yes
3/8-16
3.50
13.53
182V24 1000 48V C.T. @ 20.8A
24V @ 41.7A
Dual
Potted
6.50
3.50
Yes
3/8-16
3.50
16.49
182K30
80
60V C.T. @ 1.33A
30V @ 2.66A
Dual
Open
3.73
1.52
No
10-24
2.00
Yes
2.15
182L30
120
60V C.T. @ 2A
30V @ 4A
Dual
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
182M30
160
60V C.T. @ 2.67A
30V @ 5.34A
Dual
Open
4.43
1.73
No
1/4-20
2.50
Yes
3.87
182F30
225
60V C.T. @ 3.75A
30V @ 7.5A
Dual
Potted
4.97
1.90
Yes
1/4-20
2.50
4.96
182P30
300
60V C.T. @ 5A
30V @ 10A
Dual
Potted
5.06
2.27
Yes
1/4-20
2.50
5.58
182R30
500
60V C.T. @ 8.33A
30V @ 16.66A
Dual
Potted
5.50
2.21
Yes
1/4-20
2.50
8.46
182S30
625 60V C.T. @ 10.42A 30V @ 20.84A
Dual
Potted
6.10
3.10
Yes
3/8-16
3.50
10.38
182T30
750
30V @ 25A
Dual
Potted
6.40
3.10
Yes
3/8-16
3.50
13.53
182U30 1000 60V C.T. @ 16.7A
30V @ 33.3A
Dual
Potted
6.50
3.50
Yes
3/8-16
3.50
16.49
182V40 1500 80V C.T. @ 18.8A
40V @ 37.5A
Dual
Potted
7.20
3.50
Yes
3/8-16
3.50
24.97
60V @ 5A
Dual
Potted
5.06
2.27
Yes
1/4-20
2.50
5.58
182L60
300
60V C.T. @ 12.5A
120V C.T. @ 2.5A
2/4
10/5/22, 6:33 AM
VAC Secondary (RMS)
Part No.
VA
Series
182N60
500 120V C.T. @ 4.17A
182P60
182Q60
Potted
Parallel
Secondary
60V @ 8.34A
Dual
Potted
5.50
2.21
Yes
625 120V C.T. @ 5.21A 60V @ 10.42A
Dual
Potted
6.10
3.10
Yes
Hardware Size
with Top & Bottom
Weight
Length
Rubber Washer
(lbs.)
1/4-20
2.50
8.46
3/8-16
3.50
10.38
750 120V C.T. @ 6.25A
60V @ 12.5A
Dual
Potted
6.40
3.10
Yes
3/8-16
3.50
13.53
182R60 1000 120V C.T. @ 8.3A
60V @ 16.7A
Dual
Potted
6.50
3.50
Yes
3/8-16
3.50
16.49
182T60 1500 120V C.T. @ 12.5A
60V @ 25A
Dual
Potted
7.20
3.50
Yes
3/8-16
3.50
24.97
182D110
15
220V C.T. @ 68ma 110V @ 136ma
Dual
Open
2.70
1.25
No
8-32
1.50
Yes
0.76
182E110
30
220V C.T. @ 136ma 110V @ 272ma
Dual
Open
2.95
1.60
No
10-24
2.00
Yes
1.12
182G110
50
220V C.T. @ 227ma 110V @ 454ma
Dual
Open
3.63
1.73
No
10-24
2.00
Yes
1.67
182H110
80
220V C.T. @ 364ma 110V @ 728ma
Dual
Open
3.73
1.52
No
10-24
2.00
Yes
2.15
182J110 120 220V C.T. @ 545ma 110V @ 1.09A
Dual
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
182K110 160 220V C.T. @ 727ma 110V @ 1.45A
Dual
Open
4.43
1.73
No
1/4-20
2.50
Yes
3.87
182L110 225 220V C.T. @ 1.02A 110V @ 2.04A
Dual
Potted
4.97
1.90
Yes
1/4-20
2.50
4.96
182M110 300 220V C.T. @ 1.36A 110V @ 2.72A
Dual
Potted
5.06
2.27
Yes
1/4-20
2.50
5.58
182P110 500 220V C.T. @ 2.27A 110V @ 4.54A
Dual
Potted
5.50
2.21
Yes
1/4-20
2.50
8.46
182Q110 625 220V C.T. @ 2.84A 110V @ 5.68A
Dual
Potted
6.10
3.10
Yes
3/8-16
3.50
10.38
182R110 750 220V C.T. @ 3.41A 110V @ 6.82A
Dual
Potted
6.40
3.10
Yes
3/8-16
3.50
13.53
182S110 1000 220V C.T. @ 4.5A
110V @ 9.1A
Dual
Potted
6.50
3.50
Yes
3/8-16
3.50
16.49
182U110 1500 220V C.T. @ 6.8A
110V @ 13.6A
Dual
Potted
7.20
3.50
Yes
3/8-16
3.50
24.97
182D117
15
234V C.T. @ 64ma 117V @ 128ma
Dual
Open
2.70
1.25
No
8-32
1.50
Yes
0.76
182E117
30
234V C.T. @ 128ma 117V @ 256ma
Dual
Open
2.95
1.60
No
10-24
2.00
Yes
1.12
182G117
50
234V C.T. @ 214ma 117V @ 428ma
Dual
Open
3.63
1.73
No
10-24
2.00
Yes
1.67
182H117
80
234V C.T. @ 342ma 117V @ 684ma
Dual
Open
3.73
1.52
No
10-24
2.00
Yes
2.15
182J117 120 234V C.T. @ 513ma 117V @ 1.02A
Dual
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
182K117 160 234V C.T. @ 684ma 117V @ 1.37A
Dual
Open
4.43
1.73
No
1/4-20
2.50
Yes
3.87
182L117 225
117V @ 1.92A
Dual
Potted
4.97
1.90
Yes
1/4-20
2.50
4.96
182M117 300 234V C.T. @ 1.28A 117V @ 2.56A
Dual
Potted
5.06
2.27
Yes
1/4-20
2.50
5.58
182N117 500 234V C.T. @ 2.14A 117V @ 4.28A
Dual
Potted
5.50
2.21
Yes
1/4-20
2.50
8.46
182P117 625 234V C.T. @ 2.67A 117V @ 5.34A
Dual
Potted
6.10
3.10
Yes
3/8-16
3.50
10.38
182Q117 750 234V C.T. @ 3.21A 117V @ 6.42A
Dual
Potted
6.40
3.10
Yes
3/8-16
3.50
13.53
182R117 1000 234V C.T. @ 4.3A
117V @ 8.5A
Dual
Potted
6.50
3.50
Yes
3/8-16
3.50
16.49
182T117 1500 234V C.T. @ 6.4A
117V @ 12.8A
Dual
Potted
7.20
3.50
Yes
3/8-16
3.50
24.97
182B240
15
240V @ 63ma
Single
Open
2.70
1.25
No
8-32
1.50
Yes
0.76
182D240
30
240V @ 125ma
Single
Open
2.95
1.60
No
10-24
2.00
Yes
1.12
182E240
50
240V @ 208ma
Single
Open
3.63
1.73
No
10-24
2.00
Yes
1.67
182F240
80
240V @ 333ma
Single
Open
3.73
1.52
No
10-24
2.00
Yes
2.15
182G240 120
240V @ .5A
Single
Open
3.98
1.68
No
10-24
2.00
Yes
2.84
182H240 160
240V @ 667ma
Single
Open
4.43
1.73
No
1/4-20
2.50
Yes
3.87
182J240 225
240V @ .94A
Single
Potted
4.97
1.90
Yes
1/4-20
2.50
4.96
182K240 300
240V @ 1.25A
Single
Potted
5.06
2.27
Yes
1/4-20
2.50
5.58
182L240 500
240V @ 2.08A
Single
Potted
5.50
2.21
Yes
1/4-20
2.50
8.46
182M240 625
240V @ 2.6A
Single
Potted
6.10
3.10
Yes
3/8-16
3.50
10.38
182N240 750
240V @ 3.13A
Single
Potted
6.40
3.10
Yes
3/8-16
3.50
13.53
182P240 1000
240V @ 4.17A
Single
Potted
6.50
3.50
Yes
3/8-16
3.50
16.49
182Q240 1500
240V @ 6.3A
Single
Potted
7.20
3.50
Yes
3/8-16
3.50
24.97
234V C.T. @ .96A
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
3/4
10/5/22, 6:33 AM
4/4
很抱歉,暂时无法提供与“182P110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1582.622621+204.96571
