718A
718A
    HAMMONDMANUFACTURING
    AIR IONIZER TEST KIT
718A 数据手册
10/6/22, 6:26 AM High Voltage (Plate) - 259 VA to 1610 VA (700 Series) - Hammond Mfg. Quality Products. Service Excellence. High Voltage (Plate) - 259 VA to 1610 VA 700 Series 115 V or 117/234 V Primary Features Two versions available: Primary 115 VAC, 50/60 Hz. or Primary 117/234 VAC, 50/60 Hz. At 2,000 VAC and above, secondary leads are through rubber bushings (figure B). Units can be run full wave bridge or full wave C.T. V.A. is a C.C.S. rating Current ratings are CCS (Continuous Commercial Service) & ICAS ratings (Intermittent Commercial or Amateur Service). Enclosed, 4 hole chassis mount. Minimum 6" long leads. Class A insulation (105 degrees C). Hi-Pot test at a minimum of twice secondary voltage Conservative designs - CSA certified (209651). For other H.V. combinations check out our Peter W. Dahl series as well. Notes: VA rating specified is CCS (Continuous Commercial Service) ICAS ratings (Intermittent Commercial or Amateur Service) 115VAC only models - Input Black & Black Dual Primary (117/230VAC) models - 117VAC input: connect Blue to Black and Brown to White. 234VAC input: connect Brown to Black - input is Blue & White Gallery       A.C. High Voltage     H.V. Secondary Part No. Part No. Secondary 115 VAC Primary 117/234 VAC Primary V.A. R.M.S. (CCS) (ICAS) (Lbs) 710 710A 259 750V C.T. 345ma. 518ma. 7.2 712 712A 293 850V C.T. 345ma. 518ma. 8.8 714 714A 200 1,020V C.T. 196ma. 288ma. 5.5 715 715A 352 1,020V C.T. 300ma. 450ma. 9 717 717A 510 1,020V C.T. 500ma. 750ma. 17.7 718 718A 235 1,250V C.T. 200ma. 300ma. 8 720 720A 370 1,250V C.T. 300ma. 450ma. 12 722 722A 720 1,250V C.T. 575ma. 863ma 17.7 724 724A 345 1,500V C.T. 226ma. 339ma. 12 726 726A 312 1,780V C.T. 202ma. 299ma. 12 728 728A 346 2,000V C.T. 173ma. 259ma. 12 https://www.hammfg.com/electronics/transformers/classic/700 Current Weight 1/2 10/6/22, 6:26 AM High Voltage (Plate) - 259 VA to 1610 VA (700 Series) - Hammond Mfg. A.C. High Voltage H.V. Secondary Part No. Part No. Secondary 115 VAC Primary 117/234 VAC Primary V.A. R.M.S. (CCS) Current (ICAS) Weight (Lbs) 732 732A 500 2,500V C.T. 200ma. 300ma. 17.7 733 733A 750 2,500V C.T. 300ma. 450ma. 24 735 735A 735 3,000V C.T. 250ma. 375ma. 24 737 737A 1200 3,000V C.T. 400ma. 600ma. 28.5 739 739A 1610 3,500V C.T. 375ma. 565ma. 34.7 742A 1250 5,000V C.T. 250ma. 375ma. 26 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/classic/700 2/2
很抱歉,暂时无法提供与“718A”相匹配的价格&库存,您可以联系我们找货
718A
  • 1+1666.336111+216.54463
