3/1/22, 12:09 PM
Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg.
Quality Products. Service Excellence.
Peter W Dahl Transformers PWDAHL Series
Magnetics for Amateur Radio Products
This listing of transformers and chokes is directly from the
Peter W. Dahl files. They are arranged in alpha-numeric
order beginning with AAA and ending with 999.
These transformers are usually built to order one at a time.
Units we have already built are shown with Hammond part
numbers. If you do not see a part number listed remember that many of these designs are now decades old
- a few may have been originally designed using
"unobtainium". It is always best to confirm availability by phone or e-mail.
Some Hipersil C-Core models (Style #8, #9 & #10) need to be quoted by our office (due to
constant changes & high minimum charges imposed by current C-Core suppliers). We are
constantly updating pricing as we quote and/or build units. Most "E-I" lamination units are
normally shipped in our 6 week lead time.
Stock units can usually be shipped next business day!
Description
Hammond
Style
(see
Part Number Core
above)
Primary
10
240VCT, 60Hz
ADVANCED RADIO DEVICES 230A
A-274 C-
PLATE TRANSFORMER (2 EA 3CX800A7'S)
Core
ADVANCED RADIO DEVICES 230AX 50/60 HZ VERSION
A-0480/ C-
OF ARD 230A WITH TAPS
CORE
ADVANCED RADIO DEVICES 230C
A-0518/ C-
PLATE XFMR FOR 3 TUBE COMMERCIAL VERSION
CORE
ADVANCED RADIO DEVICES 230M
60 HZ VERSION OF 230AX WITH 1.4A RATING
A-0480/ CCORE
ALPHA A70V POWER TRANSFORMER
A-0393/ C-
FOR ALPHA VAPOR COOLED 3CV1500A7 LINEAR
CORE
ALPHA 76A POWER TRANSFORMER
FOR ALPHA MODELS 76A, 76PA, 76CA & 78
PWDP13139
B-0393/ CCORE
ALPHA 76A-1 POWER XFMR
A-0393/ C-
FILAMENT WINDING FOR 3CX800A7'S
CORE
10
10
10
10
10
10
https://www.hammfg.com/electronics/transformers/classic/pwdahl
Approx.
Weight
Secondary
1750 VRMS @ 1.1AMP
CCS
200-220-234 VCT
1750 VRMS @ 1.1 AMP
50/60 HZ
CCS
200-220-234 VCT
1750 VRMS @ 2.4 AMP
50/60 HZ
CCS
200-220-234 VCT 60
HZ 1PH
750 VRMS @ 1.4 AMP
CCS
115/230 VAC 60 HZ
1PH
120/240 VAC 60 HZ 1
PH
120/240 VAC 60 HZ 1
PH
(lbs)
37
46
66
46
S1) 0-2000-3000 VAC @
0.3A CCS
S2) 5.0 VCT @ 30A CCS
23
S3) 0-22-44-66 VAC @ 1A
CCS
S1) 0-1200-1950 VAC @
0.5A CCS
S2) 40 VCT @ 0.5A CCS
23
S3) 25 VAC @ 1A CCS
S4) 6.3 VAC @ 9.6A CCS
S1) 0-1100-1750 VAC @
0.5A CCS
23
S3) 25 VAC @ 1A CCS
S4) 13.5 VAC @ 3.0A CCS
1/31
3/1/22, 12:09 PM
Description
ALPHA 76A-2 POWER XFMR
SPECIAL HEAVY DUTY 3CX800A7'S VERSION
Hammond
Part Number Core
PWDP13047
B-0393/ CCORE
Style
(see
above)
10
Primary
120/240 VAC 60 HZ 1
PH
Secondary
Approx.
Weight
(lbs)
0.5A CCS
23
S3) 25 VAC @ 1A CCS
ALPHA 76PA 50 HZ SPECIAL PWR
115/230 VAC 50 HZ PRI & 20 VAC BUCK WIND
A-0393/ CCORE
10
0-115 & 0-115 VAC 50
HZ 1 PH
0.5A CCS
23
S3) 20 VAC @ 1A CCS
S1) 0-1800-2800 VAC @
ALPHA A77 POWER XFMR
FOR ORIGINAL ETO PA-77 LINEAR AMPLIFIER
PWDP13069
A-0393/ CCORE
10
120/240 VAC 60 HZ 1
PH
0.7A ICAS
S2) 0-22-66 VAC @ 0.5A
CCS
23
S3) 5.0 VAC @ 10A CCS
ALPHA A77S POWER TRANSFORMER
INBOARD TRANSFORMER FOR 2 TUBE ALPHA 77
A-0525/ CPWDP13107
CORE
9
120/240 VAC 60 HZ
1PH
1.2A CCS
S2) 5 VAC @ 20A CCS
S3) 50 VAC @ 1.0A CCS
49
S4) 0-22-44 VAC @
500MA CCS
1.2A CCS
PWDP13116
A-0525/ CCORE
9
220 VAC 50/60 HZ 1PH
S2) 5 VAC @ 20A CCS
S4) 0-22-44 VAC @
49
500MA CCS
S1) 0-1800-3000 VAC @
1.05A CCS
ALPHA A77S-3 POWER TRANS
SPECIAL WITH 3000 VAC SEC HI-TAP
A-0525/ CCORE
9
120/240 VAC 60 HZ
1PH
S2) 5 VAC @ 20A CCS
49
S4) 0-22-44 VAC @
500MA CCS
S1) 0-2400-3400 VAC @
ALPHA A77S-4 POWER TRANS SPECIAL 3400/2400 SEC
A-0525/ CVAC MODEL (NOTE: Installation requires modification to the
PWDP13009
CORE
power supply components
9
0.9A CCS
120/240 VAC 50/60 HZ S2) 5 VAC @ 20A CCS
1PH
49
S4) 0-22-44 VAC @
500MA CCS
0.5A CCS
ALPHA 78 50 HZ JAPAN
A-0393/ C-
SPECIAL FOR ALPHA 78 WITH 100/200V 50 HZ
CORE
10
0-100 & 0-100 VAC 50
HZ 1 PH
S3) 5 VAC @ 1A CCS
(FAN BUCKING
23
WINDING)
ALPHA 78 50 HZ SPECIAL POWER
SPECIAL FOR ALPHA 78 WITH 208/240V 50 HZ
A-0393/ CCORE
10
0-120 & 0-88-120 VAC
50 HZ 1 PH
0.5A CCS
23
S3) 25 VAC @ 1A CCS
ALPHA 87 POWER TRANSFORMER - REV K (NOT THE
SAME AS THE ALPHA 87a)
ALPHA POWER P/N TPX-X133
PWDP13140
A-0516/ CCORE
9
0-200-220-240 VAC
50/60 HZ 1 PH
S1) 0-1280-1900 VAC @
1.5A CCS
S2) 7.8 VAC @ 4A CCS
33
S3) 14.45 VAC @ 3A CCS
S4) 52 VCT @ 3.5A CCS
2/31
3/1/22, 12:09 PM
Description
Hammond
Style
(see
Part Number Core
above)
Approx.
Weight
Primary
Secondary
(lbs)
S1) 0-2050 VAC @ 1.5A
CCS
ALPHA POWER P/N TPX-X168
ALPHA 91b AND 99 POWER TRANSFORMER
PWDP13049
A-0516/ CCORE
9
0-100-120 & 0-100-120 S2) 105 VAC @ 0.5A CCS
VAC 50/60 HZ 1 PH
S3) 310 VAC @ 0.5A CCS
S4) 28 VCT @ 3.0A CCS
37
S5) 13.3 VAC @ 7.2A CCS
MODIFIED AMERITRON AL-80A HD POWER
SPECIAL HV MODEL FOR FWB&CAP (4000 VDC)
PWDP13242
EI-175 X 4"
S1) 2900 VAC @ 600 MA
4
240 VAC 60 HZ 1 PH
A-0274/ CCORE
10
60 HZ 1PH
2570 VAC @ 800 MA
ICAS
37
A-0274/ CCORE
10
0-120 & 0-100-120 VAC 2570 VAC @ 800 MA
60 HZ 1PH
ICAS
37
AMP SUPPLY #LK-450 HV POWER
HIGH VOLTAGE POWER TRANSFORMER
A-0393/ CCORE
10
110/220 VAC 50 HZ 1
PH
2200 VAC @ 400 MA CCS 23
AMP SUPPLY #LK-450 LV POWER
EI-150 X
110/220 VAC 50 HZ 1
LOW VOLTAGE POWER TRANSFORMER
1.5
S1) 5.5 VCT @ 15A CCS
S2) 0-10-20 VAC @ 2A
8
NO 5V OR 13.8V WINDINGS
AMERITRON P/N AR418-SP
AL-1200 PLATE TRANSFORMER WITH 208V TAP
AMERITRON P/N AR418-1D
AL-1200 / AL-1500 / AL-82 PLATE TRANSFORMER
AMP SUPPLY #LK-450 POWER
PLATE & FIL XFMR FOR SINGLE 3-500Z
PWDP13010
29G M6X
PWDP13134 2.5"
A-0393/ C-
AMP SUPPLY #LK-500C
CORE
AMP SUPPLY #LK-500C-200
A-393 C-
JAPANESE PRIMARY
CORE
FILAMENT TRANSFORMER FOR LK-500 AMP
AMP SUPPLY #LK-500F-2
FIL & CONTROL FOR 2 EA 3-500Z TUBES
PWDF13229
PWDP13232
AMP SUPPLY #LK-500F-3
EI-150 X
1.5
EI-150 X
1.5
EI-175 X 2
FIL & CONTROL FOR 3 EA 3-500Z TUBES
AMP SUPPLY #LK-500F2-200
EI-150 X
JAPANESE PRIMARY
1.5
AMP SUPPLY #LK-800EXT
A-480 CCORE
A-0518/ CCORE
AMP SUPPLY #LK-800EXT H/L HD
HIGHER VOLTAGE HIGHER CURRENT MODEL
PWDP13128
AMP SUPPLY #LK-800EXT HI-LO
A-0480/ C-
EXTERNAL TRANSFORMER FOR LK-800 LINEAR
CORE
AMP SUPPLY #LK-800F
EI-150 SQ
FILAMENT TRANSFORMER FOR LK-800 LINEAR
AMP SUPPLY #LK-800F-1
PWDP13080
AMP SUPPLY #LK-800F-1 (with C.T on 13.6 VAC winding)
PWDP13093
AMP SUPPLY #LK-800F-100/200
JAPANESE PRIMARY VOLTAGES
AMP SUPPLY #LK-800F/208
LK-800F WITH 208 VAC PRIMARY
AMP SUPPLY #LK-800P
4
29GAM6
A-0393/ CCORE
EI-150 X
1.5
EI-150 X
1.5
10
10
10
4
4
4
4
A-0393 / CCORE
S2) 5.5 VCT @ 15A CCS
S3) 11 VAC @ 2A CCS
117/234 VAC 60 HZ
1PH
S1) 2135 VAC @ 500MA
CCS
1PH
CCS
100/200 VAC 60 HZ
1PH
CCS
1PH
23
23
0S1) 5.5 VCT @ 30A CCS 8
115/230 VAC 60 Hz
S1) 5.5 VCT @ 30A
1PH
S2) 0-10-18 VAC @ 2A
115/230 VAC 60 HZ
S1) 5.5 VCT @ 50A
1PH
100/200 VAC 60 HZ
23
S2) 12 VAC @ 1.5A CCS
117/234 VAC 60 HZ
115/230 VAC 60 HZ
17
8
14
234 VAC 60 Hz
S1) 1800 VAC @ 1.5A
CCS
46
10
234 VAC 60 HZ 1 PH
S1) 0-1800-2500 VAC @
1.5A CCS
66
10
234 VAC 60 HZ 1 PH
4
4
4
4
ICAS
PH
10
EI-150 SQ
AMP SUPPLY #LK-800P-100/200
120/240 VAC 60 HZ 1
CCS
4
393/MA
CCS
1PH
EI-150 SQ
A-0393/CA-
PH
24
S1) 2080 VAC @ 0.4A
EI-175 X
AMP SUPPLY #LK-500B
AMP SUPPLY #LK-500F-1
4
ICAS
10
10
S1) 0-1800-2135 VAC @
1.3A CCS
117/234 VAC 60 Hz
S1) 13.6 VAC @ 9A
1PH
S2) 12 VAC @ 2A
117/234 VAC 60 Hz
S1) 13.6 VAC @ 9A
1PH
117/234 VAC 60 Hz
1PH
C.T.
S1) 13.6 VAC @ 9A
S2) 12 VAC @ 2A
S1) 13.6 VAC @ 9A
S2) 12 VAC @ 2A
117/234 VAC 60 Hz
S1) 1800 VAC @ 500 MA
1PH
CCS
1PH
8
8
8
1PH
100/200 VAC 60 Hz
46
S1) 13.6 VAC @ 9A - with
100/200 VAC 60 Hz
208 VAC 60 Hz 1PH
8
8
8
23
23
3/31
3/1/22, 12:09 PM
Style
Description
Hammond
(see
Part Number Core
above)
A-0480/ C-
AMP SUPPLY P/N AL27-1.2 G
CORE
A-0480/ C-
AMP SUPPLY P/N AL27-1.2 N
CORE
ARCOS P/N IVS-2700
A-480 C-
POWER TRANSFORMER
CORE
ARRL-001
A-480 C-
PLATE TRANSFORMER
CORE
ARRL-001-01
A-480 C-
PLATE TRANSFORMER WITH 110 VAC PRIMARY
CORE
ARRL-002
PLATE TRANSFORMER
PWDP13253
ARRL-002-1
PLATE TRANSFORMER
10
10
Approx.
Weight
Primary
Secondary
115/230 VAC 60 HZ
S1) 2700 VAC @ 1.2A
1PH
CCS
0-220-240 VAC 60 HZ
S1) 2700 VAC @ 1.2A
1PH
CCS
(lbs)
46
46
S1) 0-1650-1790-1935
10
230 VAC 60 HZ 1 PH
VAC @ 1.5A ICAS
46
S2) 13.5 VAC @ 3A CCS
10
0-220-240 VAC 60 HZ
S1) 2650 VAC @ 1.5A
1PH
ICAS
S1) 0-2000-2300-2650
46
10
110 VAC 60 HZ 1PH
A-480 CCORE
10
0-220-240 VAC 60 HZ
1PH
0-1770-2125-2500 VAC @
46
1.5A ICAS
A-0480/ CCORE
10
110/220 VAC 60 HZ
1PH
S1) 0-1500-2000-2500
VAC @ 1.5A ICAS
46
VAC @ 1.5A ICAS
46
ARRL-002-2
PLATE TRANSFORMER
PWDP13029
A-0480/ CCORE
10
110/220 VAC 60 HZ
1PH
S1) 0-1500-2000-25002750 VAC @ 1.5A ICAS
46
ARRL-002-2 (MODIFIED)
PLATE TRANSFORMER
PWDP13146
A-0480/ CCORE
10
110/220/230/240 VAC
60 HZ 1PH
46
A-0480/ CCORE
10
100/200 VAC 50 HZ
1PH
S1) 0-1770-2125-2500
VAC @ 1.5A ICAS
46
A-0480/ CCORE
10
235 VAC 60 HZ 1PH
S1) 0-1900-2100-26002800 VAC @ 1.5A ICAS
46
15/230 VAC 60 HZ 1
S1) 90 VAC @ 60 MA CCS
S2) 6.3 VAC @ 1A CCS
7
ARRL-002-200
PLATE XFMR WITH 100/200 VAC 50 HZ PRI
ARRL-003
SPECIAL FOR WIRELESS INDUSTRY ASSN
B&W PT2500A ER FILAMENT XFMR
EXACT REPLACEMENT TRANSFORMER
B&W PT2500A FILAMENT XFMR
LARGER THAN ORIGINAL (EI-125 X 2" SN-2)
PWDP13019
PWDF13103
EI-125 X 2"
29GAM6X
EI-150 X 2
2
4
PH
115/230 VAC 60 HZ 1
PH
PWDP13194 2.5"
29GM6X
BTI LK-2000 PLATE/FILAMENT
A-0480/ C-
COMBINATION PLATE & FILAMENT TRANSFORMER
CORE
CENTRAL ELECTRONICS 100V PWR
T-1 SUPPLIES +600, +340, -120 VOLTS DC
4
117 VAC 60 HZ 1 PH
S2) 6.3 VAC @ 1.0A CCS 10
S3) 5.2 VCT @ 30A CCS
CCS
S2) 5.0 VAC @ 3A CCS
12
S3) 2.5 VCT @ 5A CCS
10
115/230 VAC 60 HZ 1
PH
S1) 1250 VAC @ 1.5A
CCS
S2) 7.5 VCT @ 21A CCS
46
S1) 762-450-0-94-450-762
VAC @ 250MA CCS
EI-175 X
2.5 29GA
S1) 90 VAC @ 0.1A CCS
S1) 1000 VCT @ 220 MA
EI-150 X
BC-610 LV FIL/BIAS XFMR T1
5
115 VAC 60 HZ 1 PH
M6
17
S3) 12.6 VCT @ 7A CCS
S4) 6.3 VAC @ 3.6A CCS
S1) 240 VAC @ 0.015 A
S2) 10 VCT @ 5 A CCS
S3) 6.3 VAC @ 0.45 A
CENTRAL ELECTRONICS 600L FILAMENT
MULTIPLE FILAMENT, CHICAGO 25077
PWDF13181 EI
4
120 VAC 60 HZ 1 PH
CCS
10
S4) 6.3 VAC @ 0.3 A CCS
S5) 2.5 VCT @ 4 A CCS
(2,500 VDC INSULATION)
S6) 6.3 VCT @ 4 A CC
CHOKE 10 HY @ 0.35A DC
STYLE #4 VERT BRKT W\SCREW LUGS ON COIL
CHOKE 10 HY @ 0.5A DC
FOR 600 VDC @ 500 MA POWER SUPPLY
EI-150 X 2
4
EI-175 X 2
4
CHOKE 10.0 HY @ 1.0A DC
A-0274/ C-
3000 WVDC, 10 KVDC INSULATION
CORE
CHOKE 10.0 HY @ 1.3A DC
A-0525/ C-
4000 WVDC 1 PH (10 KVDC TEST)
CORE
CHOKE 16.0 HY @ 0.25A DC
A-0036/ C-
1 PH CHOKE FOR 1500 VDC SUPPLY, 5KV TEST
CORE
10 HY @ 350 MA DC
(650 WVDC)
10 HY @ 0.5A DC (600
WVDC)
10
14
10
10.0 HY @ 1.0A DC
37
9
10.0 HY @ 1.3A DC
49
10
16.0 HY @ 0.25A CCS
7
4/31
3/1/22, 12:09 PM
Style
Description
Approx.
Hammond
(see
Part Number Core
above)
Primary
Weight
Secondary
(lbs)
CHOKE 16.0 HY @ 0.4A DC
1500 WVDC, 5 KVDC TEST
A-0016/ CCORE
10
16.0 HY @ 0.4A DC
17
CHOKE 8.0 HY @ 0.175A DC
LV DC FILTER CHOKE, 3 KVDC TEST
EI-100 X 1
1
8.0 HY @ 175 MA DC
2
CHOKE 8.0 HY @ 0.3A
2.5 KV TEST, 800 WVDC
EI-125 X 2
2
8.0 HY @ 0.3A DC (800
WVDC)
7
CHOKE 8.0 HY @ 1.5A
10 KVDC INSULATION, 3000 WVDC
A-0480/ CCORE
10
8.0 HY @ 1.5A DC
(3000 WVDC)
46
EI
2
CHOKE 8.0 HY @ 1.5A
4000 WVDC
PWDI13169
CHOKE 8.0 HY @ 2.0A
A-540 C-
10 KVDC INSULATION, 5200 WVDC 1PH
CORE
CHOKE 9.0 HY @ 0.25A DC
A-0036/ C-
RESONATE WITH 0.2 MFD CAP @ 120 HZ
CORE
CHOKE 9.0 HY @ 0.65A DC
A-0393/ C-
4000 WVDC RESONATE WITH 0.2 MF 10 KV CAP
CORE
CHOKE 9.0 HY @ 1.0A DC
A-0274/ C-
CORE
CHOKE 9.0 HY @ 1.0A DC HP
A-0518/ C-
SLIM & TALLER VERSION
CORE
CHOKE 9.0 HY @ 1.5A DC
5000 WVDC RESONATE WITH 0.2 MF 10 KV CAP
A-0518/ CCORE
10
EI
4
CHOKE 60 HY @ 150 ma. DC
MODULATION REACTOR (CHOKE)
PWDI13132
2.5"
29GAM6
T1 MAIN POWER XFMR, P/N 601-016
PP 6B4G PLATES TO PP 810 GRIDS (T-404)
10
PWDM13041 EI-100 X 1
63
(4000 WVDC)
8.0 HY @ 2.0A DC
92
(5200 WVDC 1PH)
9.0 HY @ 0.25A DC
7
(1500 WVDC 1 PH)
9.0 HY @ 0.65ADC
10
(4000 WVDC 0.2 MF
23
CAP)
9.0 HY @ 1.0A DC
10
(4000 WVDC 0.2 MF
37
CAP)
9
9.0 HY @ 1.0A DC
38
(4500 WVDC)
9.0 HY @ 1.5A DC
(5000 WVDC 0.2 MF
66
CAP)
60 HY @ 150 ma. DC
10
CCS (2 KVDC TEST)
EI-175 X
CLEGG APOLLO SIX T1 POWER
COLLINS KW-1 AUDIO DRIVER
9
8.0 HY @ 1.5A DC
S1) 1050 VAC @ 0.5A
6
5
117 VAC 60 HZ 1 PH
ICAS
17
S2) 380 VCT @ 0.1A ICAS
375 VCT @ 0.1A CCS
S1) 125 VAC @ 0.1A CCS
(2225 OHMS G-G CT)
(5000 OHMS P-P CT)
S2) 125 VAC @ 0.1A CCS
2
(2225 OHMS G-G CT)
COLLINS KW-1 BIAS T-401
-150 VOLT DC BIAS & FILAMENT TRANSFORMER
PWDP13188
EI-112 X
1.125
S1) 300 VCT @ 30 MA
4
115 VAC 60 HZ 1 PH
CCS
3
S2) 5 VAC @ 2A CCS
S1) 400-80-0-80-400 VAC
COLLINS KW-1 LV POWER T-402
EI-175 X 2"
LV POWER (300 VDC @ 325 MA) & FIL WNDGS
29GAM6X
COLLINS KW-1 MODULATION XFMR
PP 810 MODULATORS TO PARALLEL 4-250A'S
COLLINS KW-1 RECT FIL ER
T-501 872A FIL XFMR (EXACT REPLACEMENT)
PWDM13037
EI-175 EESTACK
@ 325 MA CCS
5
10
EI-150 X
1.5
OHMS PP
5
115 VAC 60 HZ 1 PH
5
115 VAC 60 HZ 1 PH
COLLINS KWS-1 HV CHOKE L-501 - Direct Replacement
8 HY @ 0.5A DC TUNED CHOKE REQUIRES THE 0.15
MFD RESONATING CAP
14
1768 VAC @ 283 MA CCS
(6250 OHMS RFPA)
S1) 5.0 VCT @ 15A CCS
(10 KVDC INS)
(10 KVDC INS)
35
6
8
8.0 HY @ 0.5A DC
EI
2
MFD RESONATING CAP
1800/2400
VCT18000/11600
29GRH
T-501 872A FILAMENT TRANSFORMER
S2) 5.0 VAC @ 6A CCS
S3) 5.0 VAC @ 2A CCS
S4) 6.3 VCT @ 7A CCS
EI-150 X
PWDF13255 1.25"
COLLINS KW-1 RECT FILAMENT
"EI" Lamination
115 VAC 60 HZ 1 PH
A-0274/ CCORE
(4000 WVDC, 55
OHMS DC)
8.0 HY @ 0.5A DC
9
(4000 WVDC, 55
OHMS DC)
21
5/31
3/1/22, 12:09 PM
Style
Description
Hammond
Part Number Core
(see
above)
PWDF13061 EI-087 X 1
7
COLLINS KWS-1 HV FILAMENT
REPLACEMENT 866A FIL XFMR (T-502) - BOBBIN
WOUND - EPOXY FILLED BAYS
COLLINS KWS-1 LV DC CHOKE
EI-112 X
+275 VDC FILTER CHOKES, L-502 & L-504
1.125
COLLINS KWS-1 LV POWER XFMR
T-506 P/N 662-0146-00 ORIGINAL WAS STYLE #07 - CAN
EI-150 X
IS NO LONGER
PWDP13171 2.5"
Secondary
115/230 VAC 50/60 HZ S1) 2.5 VCT @ 10A CCS
1 PH
(10 KVDC TEST)
4 HY @ 230MA DC
Weight
(lbs)
2
3
(+275 WVDC)
VAC @ 0.255A CCS
5
120 VAC 60 HZ 1 PH
29GAM6
COLLINS KWS-1 PLATE XFMR
P/N 662-0155-00, E-5017
Primary
S1) 420-200-0-200-420
AVAILABLE
5
Approx.
A-0518/ CCORE
9
115/230 VAC 60 HZ 1
PH
4800 VCT @ 800 MA CCS 38
115/230 VAC 60 HZ 1
S1) 4800 VCT @ 800 MA
PH
CC
EI-100 X
P/N 662-0157-00 T504 - REPLACEMENT IS NOT POTTED PWDP13043 1.25
- SEE PDF DRAWING
29GAM6
COLLINS KWS-1 SCREEN FIL
EI-112 X
SCREEN SUPPLY FILAMENT XFMR (T-505)
1.125
13
S3) 12.6 VAC @ 0.3A CCS
S4) 6.3 VAC @ 9.0A CCS
PWDP13082 EI 29GAM6 9
S2) 5.0 VAC @ 4A CCS
5
120 VAC 60 HZ
5
115 VAC 60 HZ 1 PH
S1) 980 VCT @ 0.050A
CCS
S1) 6.3 VAC @ 3.0A CCS
S2) 5.0 VAC @ 2.0A CCS
39
6
3
S1) 325 VRMS @ 400 MA
CCS
COLLINS PM-2 POWER XFMR
EI-137 X 2
P/N 662-0033-00, BALLASTRAN #BC-2950
4
115/230 VAC 60 HZ
1PH
S2) 230 VRMS @ 150 MA
CCS
8
S3) 110 VRMS @ 15 MA
CCS
S4) 6.3 VAC @ 6A CCS
COLLINS 21E LV CHOKE L114
LV DC FILTER CHOKE, P/N 668-0072-00
COLLINS 30K MODULATION XFMR
P/N 677-0316-00, 200W,+/- 2DB 100-5000HZ
COLLINS 30K PLATE
4-125A RF PA & PP 75T MODULATORS
PWDI13191
EI-175 X 3" 4
EI-150 X
PWDM13203 2.5"
29GM6X
PWDP13256
A-0480/ CCORE
COLLINS 30K-1 FILAMENT T403
2 EA 75TH'S & 1 EA 4-125A (CASED UNIT)
EI-l25 X
1.75
COLLINS 30K-1 HD PLATE
HEAVY DUTY REPLACEMENT TRANSFORMER
COLLINS 30K-5 HIPERSIL PLATE
REPLACES P/N 662-0127-00 (SAME MTG)
COLLINS 30L-1
7
PWDP13170
10
20 HY @ 0.35 A DC
2450 VCT @ 175 MA
(32K OHMS)
19
S1) 1770 VAC @ .150ADC
& .113AAC(16.7K OHM)
12
S2) 248 VAC @ .050ADC
115/230 VAC 60 HZ
2950-2365-0-2365-2950
1PH
VAC @ 750MA CCS
46
0-105-110-115 VAC 60
5.0 VCT @ 20A CCS
HZ 1 PH
6
EI-250 X 4"
4
29G M6X
115/230 VAC 60 HZ 1
PH
VAC @ 350 MA CCS
53
A-0480/ CCORE
115/230 VAC 60 HZ
1PH
VAC @ 0.4A CCS
46
EI-175 X 3"
29G M6X
7
10
2
S1) 650 VAC 0.7A CCS
115/230 VAC 50/60 HZ S2) 120 VAC @ 0.020A
1 PH
CCS
S3) 6.3 VCT @ 16A CCS
19
S1) 550 VAC 0.7A CCS
COLLINS 30L-1-1
MODIFIED SEC 1 VOLTS & SEC 2 CURRENT
EI-175 X 3"
2
29G M6X
115/230 VAC 50/60 HZ S2) 120 VAC @ 0.100A
1 PH
CCS
19
COLLINS 30S-1 ALC XFMR T-102
1:1 RATIO ALC TRANSFORMER
COLLINS 30S-1 BIAS
P/N 662-0353-00
COLLINS 30S-1 CHOKE
REPLACEMENT FOR L-202
COLLINS 30S-1 ER RECT FIL
T-202,P/N 662-0352-00 REPLACEMENT
COLLINS 30S-1 FILAMENT--T101
LOW CAPACITY RF PA FILAMENT TRANSFORMER
EE 24-25
PWDA13244
1
SQ STACK
3.5 HY @ 700 OHMS
115 VAC 50/60 HZ 1
S1) 125 VCT @ 0.1A CCS
PH
S2) 12.6 VAC @ 0.8A CCS
PWDP13042 EI-087 X 1
1
EI-175 X 3
5
8.0 HY @ 0.5A DC (10
KVDC INS)
5
15 VAC 60 HZ 1 PH
(10 KVDC INSULATION)
3
4
105 VAC 60 HZ 1 PH
6.0 VAC @ 12.5A LOW
CAPACITY
8
EI-100 X
PWDP13018 1.25
29GAM6
EI-150 X
1.5
2
19
6/31
3/1/22, 12:09 PM
Description
Hammond
Style
(see
Part Number Core
above)
COLLINS 30S-1 FILTER CHOKE
A-0016/CA-
HEAVY DUTY HIPERSIL DC CHOKE - L202
16
COLLINS 30S-1 FILTER CHOKE-1
A-0016/ C-
FOR 50 HZ WITH 0.15 MFD CAP (L202)
CORE
Approx.
Weight
Primary
Secondary
(lbs)
8.33 HY @ .5A CCS
10
(3000 WVDC 1PH
FWCT)
17
16.7 HY @ .5A CCS
10
(3000 WVDC 1PH
FWCT)
17
S1) 6320 VCT @ 350MA
COLLINS 30S-1 PLATE XFMR
STANDARD REPLACEMENT TRANSFORMER
EI-300 X
PWDP13017
3.375
4
115/230 VAC 60 HZ
1PH HI-LO TAPS
CCS (HI Primary Tap)
S2) 245 VAC @ 350MA
67
COLLINS 30S-1 RECT FILAMENT
T-202, P/N 662-0352-00
EI-100 X 1
5
115 VAC 60 HZ 1 PH
COLLINS 30S-1 SCREEN CHOKE
L-201, P/N 668-0356-00, STD SCREEN CHOKE
EI-150 X
1.5
5
3.5 HY @ 500 MA DC
(300 WVDC SUPPLY)
EI-175 X
1.75
4
115 VAC 60 HZ 1PH
HI-LO TAPS
COLLINS 30S-1 SCREEN POWER
350/250 VAC @ 400 MA CCS
PWDP13149
COLLINS 30S-1-J PLATE XFMR JAPANESE 100/200 VAC
EI-300 X
50 HZ PRIMARY
3.375
4
2.5 VCT @ 10A CCS (10
KVDC INSULATION)
8
S1) 350 VAC @ 400 MA
CCS
100/200 VAC 50/60 HZ CCS
1PH HI-LO TAPS
2
S2) 245 VAC @ 350MA
CCS
12
67
COLLINS 30S-1-50 PLATE XFMR
50 HZ VERSION OF 30S-1 PLATE XFMR
EI-300 X
PWDP13124
3.375
4
115/230 VAC 50/60 HZ CCS
1PH HI-LO TAPS
S2) 245 VAC @ 350MA
67
CCS
COLLINS 30S-1M-J PLATE XFMR
EI-300 X
SPECIAL 100/200 VAC 50/60 HZ PRIMARY
3.375
COLLINS 30S-1M-50 PLATE XFMR
50 HZ VERSION OF 30S-1M PLATE XFMR
EI-137 X
1.375
4
4
100/200 VAC 50 HZ
1PH HI-LO TAPS
220 VAC 60 HZ 1 PH
CCS
S2) 365 VAC @ 350MA
CCS
S1) 120 VAC @ 500 MA
CCS
67
6
S1) 1360 VCT @ 60 MA
CCS
S2) 600/150 VCT @ 70
COLLINS 310B POWER XFMR
EI-150 X 2
BIAS/LV/HV/FILS FOR COLLINS 310B EXCITER
6
115 VAC 60 HZ 1 PH
MA CCS
S3) 5.0 VAC @ 3A CCS
10
S4) 5.0 VAC @ 3A CCS
S5) 6.3 VAC @ 4A CCS
COLLINS 32V-1/2/3 LV POWER
LV POWER XFMR FOR 32V-1, 32V-2 OR 32V-3
PWDP13005
EI-150 X
1.5
S1) 850 VCT @ 175 MA
CCS
4
115 VAC 60 HZ 1 PH
S3) 5.0 VAC @ 4A CCS
4
115 VAC 50/60 HZ 1
PH W/VCTAP
4
115/230 VAC 45/70 HZ CCS (FWCT)
1 PH
S2) 5.0 VAC @ 2A CCS
8
S4) 6.3 VAC @ 9A CCS
COLLINS 32V3 HV
POWER TRANSFORMER T302, P/N 662-0014-00
EI-162 X 2
S1) 1370 VCT @ 500 MA
CCS
15
S1) 700 VCT @ 200 MA
COLLINS 51J4 POWER
ALSO USED IN COLLINS R-388 (51J-3) RECEIVER
EI-150 X
PWDP13063
1.5
COLLINS 516F-1 POWER XFMR
P/N 662-0252-00 MODEL 164
EI-150 X
PWDP13075
1.5
8
S3) 6.3 VAC @ 7A CCS
COLLINS 516F-2 CHOKE (L1/L2)
8 HY @ 175MA DC 200 OHMS P/N 668-0300-00
COLLINS 516F-2 CHOKE (L3)
1.0 HY @ 180MA DC FILTER CHOKE
PWDI13251
COLLINS 516F-2HD POWER
P/N 662-0434-00 ADVERTISED UNIT - OLDER VERSION
(120 VAC ONLY)
PWDP13199
S1) 920-0-920 VAC @
250MA ICAS
5
115 VAC 60 HZ 1PH
EI-100 X 1
6
8 HY @ 175MA DC
2
EI-075 X 1
3
1.0 HY @ 180 MA DC
1
EI-175 X 3"
29G M6X
8
S1) 1000-425-123-0-4251000 VAC @ 250MA CCS
2
120 VAC 60 HZ 1 PH
S2) 6.3 VAC @ 11A CCS
19
7/31
3/1/22, 12:09 PM
Description
Hammond
Part Number Core
Style
(see
above)
Primary
Secondary
Approx.
Weight
(lbs)
S1) 1000-425-123-0-425COLLINS 516F-2HD POWER G
P/N 662-0249-010 120/240 PRIMARY - NEWER VERSION
COLLINS 516F-2HD-100 POWER
100 VAC 60 HZ ONLY PRIMARY
PWDP13200
PWDP13201
EI-175 X 3"
29 GA M6
EI-175 X 3"
29GA M6
2
1 PH
19
2
100 VAC 60 HZ 1 PH
19
COLLINS 62S-1 POWER XFMR
T3, P/N 662-0035-00, STANCOR P/N 30064
EI-125 X 2"
6
29GM6RH
COLLINS 75A-1, 75A-2, 75A-3, 75A-4 (L29) FILTER
CHOKE (#1)
P/N 668-0020-00
S1) 315 VAC @ 125 MA
CCS
115 VAC 60 HZ 1 PH
S2) 90 VAC @ 100 MA
7
CCS
S3) 6.3 VAC @ 6.5A CCS
3 HENRY 120 MA DC
PWDI13161
EI
3
CHOKE (#2)
P/N 668-0019-00
PWDI13158
EI
3
COLLINS 75A-2/3 POWER
P/N 662-0017-00 WITH ADDED 234V
EI-125 X
PWDP13233
1.75
COLLINS 75A-1, 75A-2, 75A-3, 75A-4 (L30) FILTER
600V WORKING
VOLTAGE
2
5 HENRY 80 MA DC
600V WORKING
VOLTAGE
2
S1) 700 VCT @ 150 MA
5
117/234 VAC 50/60 HZ CCS
6
1 PH
S3) 6.3 VAC @ 6.0A CCS
COLLINS 75A-4 NB POWER XFMR
P/N 662-0431-00
EI-087 X
.875
5
117 VAC 60 HZ 1 PH
S1) 135 VAC @ 0.1A CCS
2
S2) 6.3 VAC @ 3A CCS
S1) 350-160-0-350 VAC @
COLLINS 75A-4 POWER
P/N 662-0145-00
COLLINS 75S-1, 75S-3, 75S-3A POWER XFMR
P/N 662-0301-00, T-4 (75S-1), T-8 (75S-3, 75S-3A)
EI-125 X
PWDP13053
1.75
PWDP13115
COLLINS 75S-3B AUDIO OUTPUT
P/N 667-0302-00
COLLINS 75S-3B, 75S-3C POWER XFMR
MAIN POWER XFMR (T-8) P/N 662-0250-010
HEAVY DUTY REPLACEMENT POWER TRANSFORMER
1.5
4
EI-050 X .5 1
117 VAC 60 HZ 1 PH
PWDP13090
EI-112 X
1.5
5
EI-ll2 X 1.5
5
150 MA CCS
6
117 VAC 50/60 HZ 1
S1) 220 VCT @ 0.1A CCS
PH
S2) 6.3 VAC @ 6.0A CCS
70 VAC 100-3000 HZ
2500 OHMS (PLATEB+)
COLLINS 75S-3B-100 POWER
100 VAC 60 HZ PRIMARY ONLY
COMMANDER HF-2500 POWER XFMR
EI-112 X
5
115/230 VAC 60 HZ
1PH
100 VAC 60 HZ 1PH
4
S1) 0-2.8-31.3 VAC, 4/500
OHMS @ 1.9 WATTS
S1) 290 VCT @ 125MA
CCS
4
S2) 6.3 VAC @ 5.5A CCS
S1) 290 VCT @ 125MA
CCS
4
PWDP13011
EI-250 X 4"
29G M6X
COMMANDER HF-2500-50S XFMR
EI-250 X 4"
50 HZ VERSION
29G M6X
2
230 VCT 60 HZ 1 PH
S1) 900 VRMS @ 2.0A
ICAS
53
S2) 6.3 VRMS @ 1A CCS
2
230 VCT 50 HZ 1 PH
S1) 900 VRMS @ 2.0A
ICAS
53
2
117/234 VAC 60 HZ
1PH
S1) 0-640-1010 VAC @
DENTRON CLIPPERTON-L
POWER TRANSFORMER
EI-162 X
PWDP13002
3.5
600 MA CCS
S2) 12 VAC @ 2A CCS
24
S3) 6.3 VAC @ 16A CCS
DENTRON CLIPPERTON-L (Late Production)
POWER TRANSFORMER MODIFIED (Filament winding
EI-162 X
includes C.T.)
PWDP13123
3.5
We believe this power transformer was also used in the later
CLIPPERTON QRO
2
117/234 VAC 60 HZ
1PH
600 MA CCS
S2) 12 VAC @ 2A CCS
S3) 6.3 VAC C.T. @ 16A
CCS
24
8/31
3/1/22, 12:09 PM
Style
Description
Hammond
Part Number Core
(see
above)
Approx.
Primary
Secondary
Weight
(lbs)
DENTRON CLIPPERTON-L F
CLIPPERTON-L POWER XFMR WITH 110/220 PRI
DENTRON CLIPPERTON-L-50
50 HZ VERSION
EI-162 X
3.5
2
110/220 VAC 60 HZ
1PH
2
117/234 VAC 50 HZ
1PH
DENTRON CLIPPERTON-LX
A-516 C-
OUTBOARD POWER TRANSFORMER
CORE
EI-162 X
3.5"
DENTRON DTR-1200L POWER XFMR
A-0480/ C-
OUTBOARD POWER XFMR FOR DTR-2000L
CORE
DENTRON GLA-1000B
EI-175 X 2
600 MA CCS
S2) 12 VAC @ 2A CCS
24
10
2
29GM6X
DENTRON DTR-2000L-X1
24
EI-162 X
PWDP13001 3.5 29G
M6X
600 MA CCS
S2) 12 VAC @ 2A CCS
10
2
117/234 VAC 60 HZ
1PH
117/234 VAC 60 HZ 1
PH
115/230 VAC 60 HZ 1
PH
115/230 VAC 60 HZ
1PH
S1) 0-640-1060 VAC @
3.0A CCS
S2) 12 VAC @ 2A CCS
58
S1) 775 VAC @ 0.8A CCS
S2) 10 VAC @ 1.0A CCS
24
S3) 6.3 VCT @ 8A CCS
S1) 0-900-1200 VAC @
2.0A CCS
S2) 5.0 VAC @ 11A CCS
S3) 12 VAC @ 1.5A CCS
46
S1) 800 VAC @ 0.3A CCS
S2) 6.3 VAC @ 6A CCS
S3) 12 VAC @ 1A CCS
14
S1) 0-600-800 VAC @
DENTRON MLA-2500B
POWER TRANSFORMER
PWDP13102
EI-162 X 3"
29GAM6X
2
1 PH
0.9A CCS
S2) 12.6 VAC @ 4.0A CCS
21
S3) 6.3 VAC @ 8A CCS
S4) 120 VAC @ 0.1A CCS
DENTRON MLA-2500B-1
MODIFIED MLA-2500B TRANSFORMER
PWDP13249
EI-162 X 3"
29G M6X
2
115/230 VAC 60 HZ 1
PH
S1) 800 VAC @ 0.9A CCS
S2) 12.6 VCT @ 4.0A CCS
S3) 6.0 VAC @ 9A CCS
21
S1) 985 VAC @ 1.0A ICAS
DENTRON 160-10L POWER
EXACT REPLACEMENT FOR 160-10L AMPLIFIER
EI-162 X 3"
PWDP13048
4
29GAM6X
DRAKE AC-4 POWER XFMR
EI-150 X 3"
DRAKE AC-4 POWER SUPPLY USED WITH "4" LINES (T- PWDP13137
2
29GAM6X
4, T-4X AND TR-4)
115/230 VAC 60 HZ 1
PH
1 PH
OR 0.65A CCS
21
S2) 9.5 VAC @ 1.0A CCS
S1) 265 VAC @ 750 MA
CCS
S2) 90 VAC @ 350 MA
CCS
S3) 95 VAC @ 100 MA
14
CCS
S4) 12.6 VAC @ 5.5A CCS
DRAKE L4B FILAMENT
PWDF13238 EI-137 X 2
6
DRAKE L4B-6
DIRECT REPLACEMENT WITH 6 TERMINAL PRI
PWDP13241 EI-212 X 3
2
EI-212 X 3
2
PWDP13087 EI-212 X 3
PWDP13054 EI-212 X 3
DRAKE L4B-6-1
DIRECT REPLACEMENT WITH 6 TERM 50 HZ PRI
DRAKE L4B-7 and L7 PS
DIRECT REPLACEMENT WITH 7 TERMINAL PRI
DRAKE L4B-7-1
DIRECT REPL WITH 100/200 VAC 50 HZ 7 TP
DRAKE L4B 3CX1200A7 X 2 FIL - NOTE: REQUIRES
EXTENSIVE POWER SUPPLY AND RF AMP MODS
FIL XFMR FOR 2 EA 3CX1200A7'S IN L4B
HZ 1 PH
S2) 22 VAC @ 1A CCS
120/240 VAC 60 HZ
1PH HI-LO TAPS
S1) 1065/780 VAC @
0.81A CCS
120/240 VAC 50/60 HZ S1) 780/1065 VAC @
8
29
29
1PH HI-LO TAPS
0.68A CCS
2
120/240 VAC 60 HZ
1PH HI-LO TAPS
S1) 1065/780 VAC @
0.81A CCS
29
2
120/240 VAC 60 HZ
1PH HI-LO TAPS
S1) 1170/878 VAC @
0.81A CCS
29
EI-212 X 3"
2
29GM6X
100/200 VAC 50 HZ
1PH HI-LO TAPS
S1) 1065/780 VAC @
0.81A CCS
29
DRAKE L4B-7-SP and L7 PS
1170 VAC SECONDARY WITH 7 TERMINAL PRI - NOTE:
REQUIRES POWER SUPPLY AND RF AMP MODS
0-115/0-62-115 VAC 60 S1) 5.0 VCT @ 30A CCS
EI-150 X
PWDF13243 2.5"
29GM6X
4
0-120/0-62-120 VAC 60 S1) 7.5 VCT @ 42A CCS
HZ 1 PH
S2) 22 VAC @ 1A CCS
12
9/31
3/1/22, 12:09 PM
Style
Description
Hammond
Part Number Core
(see
above)
DRAKE R-4, R-4A, R-4B POWER XFMR T15
POWER XFMR FOR DRAKE R-4, R-4A AND R-4B
EI-100 X
PWDP13202 1.5"
5
RECEIVER ONLY
DRAKE R-4C POWER XFMR T14
POWER XFMR FOR DRAKE R-4C RECEIVER ONLY
DRAKE 1A POWER TRANSFORMER
FOR R.L. DRAKE MODEL 1A RECEIVER
DRAKE 2-C POWER TRANSFORMER
EXACT REPLACEMENT
29GM6X
EI-100 X
PWDP13178 1.5"
29GM6X
Primary
PWDP13219
EI-100 X 1"
29GAM6X
EI-100 X 1
L16
EICO 720 POWER XFMR
EI-150 X 2"
90 WATT CW TRANSMITTER POWER TRANSFORMER
29GAM6X
ELDICO MODEL 1000 FIL/BIAS
EI-l25 X
W/O 866A FIL WINDING (NEED SS 866A'S)
1.25
PWDI13257
C-CORE
Secondary
S1) 260 VCT @ 0.15A
CCS
1 PH
S2) 12.6 VCT @ 2A CCS
S1) 250 VCT @ 0.13A
20/240 VAC 50/60 HZ 1 CCS
PH
EI-100 X
PWDP13210 1.25
29GM6X
EICO 720 DC CHOKE
ENERGY-ONIX CHOKE P/N 376-056
5
Approx.
S2) 26 VCT @ 0.65A CCS
S3) 6.3 VAC @ 2A CCS
Weight
(lbs)
3
3
S1) 525 VCT @ 50 MA
2
5
1
6
5
115 VAC 60 HZ 1 PH
115/230 VAC 60 HZ 1
PH
CCS
S2) 12.6 VAC @ 2A CCS
S1) 208 VCT @ .075A
CCS
S2) 22.8 VCT @ 0.4A CCS
S3) 13.3 VCT @ 0.8A CCS
8.0 HY @ 150 MA DC
PH
115 VAC 60 HZ 1 PH
S1) 1400 VCT @ 170 MA
CCS
S2) 5 VAC @ 2A CCS
S3) 6.3 VAC @ 3A CCS
S1) 6.3 VAC @ 6.5A CCS
S2) 250 VCT @ 0.1A CCS
PR) 2.0 HY @ 1.7A DC
(6400 WVDC 1 PH)
10
2
2
(600 WVDC)
PR) 117 VAC 60 HZ 1
3
10
4
37
S1) 860 VAC @ 250 MA
GALAXY V POWER TRANSFORMER
EI-175 X 2
2
117 VAC 60 HZ
CCS
S2) 285 VAC @ 175 MA
CCS
S3) 80 VAC @ 50 MA CCS
S4) 24 VCT @ 500 MA
14
CCS
S5) 12.6 VAC @ 6A CCS
40 HENRY 600 MA DC
GATES BC-1 MODULATION REACTOR
PWDI13065
GATES/HARRIS CHOKE
476-0420-000
PWDI13211
GLOBE CHAMPION LV POWER T1
LV, BIAS, FIL VOLTS FOR MODELS 300 & 350
GLOBE CHAMPION 175 POWER T3
THORDARSON P/N T-21P93
C-CORE
EI-150 X
2.5"
29GM6X
EI-162 X
1.625
GLOBE KING 500A LV POWER
THORDARSON T-21P89
EI-125 X 2
GLOBE KING 500A/B MOD XFMR
PP 811A'S TO SINGLE 4-250A/4-400A RF PA
GLOBE KING 500B PLATE
1800 VDC @ 400 MA CCS FWB CHOKE INPUT
60
S1) 900 VCT @ 250 MA
CCS
S2) 110 VAC @ 0.1A CCS
EI-150 X
PWDP13217 2.5"
29GAM6
PP 809 MODULATORS TO PARALLEL 9909 RF PA
1000 VDC FOR 811A'S & 400 VDC FOR 6L6G
10KV WORKING
VOLTAGE
5H 2 2.5A, 5600 VDC
GLOBE CHAMPION 300 MOD XFMR
GLOBE KING 500A MOD POWER
10
5
PR) 115 VAC 60 HZ 1
PH
S3) 12.6 VCT @ 3A CCS
12
S4) 5 VAC @ 3A CCS
S5) 6.3 VCT @ 6A CCS &
6.3 VAC @ 6A CCS
S6) 2.5 VCT @ 10A CCS
5
4
117 VAC 60 HZ 1 PH
S1) 2150/1000 VCT @
95/125 MA CCS FWCT
11,000 OHMS P-P (PP 2830 OHMS (920 VDC @
12
13
809'S) (1280 VCT)
325 MA, 650 VRMS)
5
115 VAC 60 HZ 1 PH
1160 VCT @ 150 MA CCS 7
PWDP13052 EI-162 X 2
2
117 VAC 60 HZ 1 PH
EI-150 X
PWDM13086 3.5"
5
1465 VCT @ 0.246A
1275 VAC @ 0.283A CCS
16
CCS (7400 OHMS P-P) (1800 VDC @ .4A)
5
115 VAC 60 HZ 1 PH
29GM6X
PWDP13074 EI-175 X 5
1160-350-0-350-1160 VAC
@ 450 MA ICAS
S1) 4000 VCT @ 400 MA
ICAS (FWCT)
15
31
10/31
3/1/22, 12:09 PM
Description
GLOBE KING 500B PLATE (MODIFIED)
Hammond
Style
(see
Part Number Core
above)
Primary
5
120/240 VAC 60 HZ 1
PH
10
115 VAC 60 HZ 1 PH
1
25 HY @ 0.050A DC
(400 WVDC)
PWDP13108 EI-175 X 5
GLOBE KING 500B-X PLATE
A-0274/ C-
HEAVY DUTY EXTERNAL PLATE TRANSFORMER
CORE
GLOBE KING 500C SCREEN CHOKE
CH1 SCREEN SUPPLY DC FILTER CHOKE
EI-075 X
.75
Approx.
Weight
Secondary
(lbs)
31
S1) 4400/4000 VCT @ 400
MA CCS (FWCT)
37
1
S1) 1200 VCT @ 0.2A
GLOBE SCOUT 65A POWER XFMR
WRL MODEL 65A GLOBE SCOUT TRANSMITTER
EI-150 X 2"
PWDP13162
5
29G M6X
GONSET G-50 POWER XFMR
6 METER COMMUNICATOR
EI-137 X 2"
PWDP13028
5
29GAM6X
115 VAC 60 HZ 1 PH
115 VAC 60 HZ 1 PH
CCS (500 VDC FWCT)
10
S2) 6.3 VAC @ 3.5A CCS
S3) 5 VAC @ 3A CCS
S1) 770 VCT @ 250 MA
CCS
8
S3) 6.3 VAC @ 9A CCS
GONSET G-76 POWER XFMR
T-1, MAIN POWER TRANSFORMER
EI-175 X
PWDP13247 2.5"
29GM6X
6
115 VAC 60 HZ 1 PH
S1) 1300/540 VCT @ 0.3A
CCS
S3) 12.6 VAC @ 5A CCS
17
S1) 720-260-0-130-260GONSET GSB-100 POWER
ADVERTISED UNIT
PWDP13106 EI-150 X 2
4
117 VAC 60 HZ 1 PH
720 VAC @ 150 MA CCS
10
S4) 6.3 VAC @ 10A CCS
GONSET GSB-101 ALT PLATE C
ALT XFMR ON EI-175 LAMS WITH 117 VAC PRI
EI-175 X 5"
4
29G M6X
GONSET GSB-101 ALT PLATE J
EI-175 X 5"
ALT XFMR ON EI-175 LAMS WITH 220 VAC PRI
29G M6X
GONSET GSB-101 ER PLATE C
EXACT REPLACEMENT UNIT WITH 117 VAC PRI
GONSET GSB-101 ER PLATE J
EXACT REPLACEMENT UNIT WITH 220 VAC PRI
EI-162 X
PWDP13101 3.5"
S1) 3600 VCT @ 500 MA
CCS
31
4
220 VAC 60 HZ 1 PH
4
117 VAC 60 HZ 1 PH
3600 VCT @ 500 MA CCS 24
4
220 VAC 60 HZ 1 PH
CCS
5
25 HY @ 75 MA TO 5
HY @ 450 MA DC
10
10
117 VAC 60 HZ 1 PH
3600 VCT @ 600 MA CCS 30
4
120/240 VAC 60 HZ
1PH
2500 VAC @ 1.0A ICAS
(0.3A CCS)
120/240 VAC 60 HZ 1
S1) 1705 VAC @ 500 MA
PH
CCS
CCS
31
29GM6X
EI-162 X
3.5"
29GM6X
GONSET GSB-101 FILTER CHOKE
EXACT REPLACEMENT
EI-150 X 2
GONSET GSB-101 PLATE
A-0203/ C-
HEAVY DUTY HIPERSIL REPLACEMENT XFMR
CORE
GONSET GSB-201 MK IV POWER
EI-175 X 5
29G M-6
GONSET GSB-201 POWER
EI-175 X 5"
ADVERTISED UNIT
29G M6X
HALLICRAFTERS FPM-300-MKII
EI-150 X
POWER TRANSFORMER
2.5
POWER TRANSFORMER
117 VAC 60 HZ 1 PH
EI-150 X
2.5
4
6
6
120/240 VAC 60 HZ 1
PH
PR) PRI "1" 117/234
PRI "2" 18.7 VCT
CCS
S2) 6.3 VAC @ 20A CCS
S1) 215 VAC @ 250MA
S2) 320 VAC @ 250MA
S3) 12 VAC @ 1A
24
31
31
31
12
S4) 6.3-0-103 VAC @ 4A0-100MA
S1) 490-360-0-75-360-490
HALLICRAFTERS HT-30 POWER
POWER XFMR FOR HT-30 MARK I EXCITER
HALLICRAFTERS HT-32 DC CHOKE
L-25, P/N 056-300259
EI-150 X
2.5"
6
117 VAC 60 HZ 1 PH
29GAM6
EI-087 X 1
VAC @ 0.25A CCS
S2) 5 VAC @ 3A CCS
12
S3) 5 VAC @ 3A CCS
1
9.0 HY @ 135 MA DC
2
11/31
3/1/22, 12:09 PM
Description
HALLICRAFTERS HT-32 MARK I
T4 MAIN POWER TRANSFORMER
Hammond
Style
(see
Part Number Core
above)
PWDP13141 EI-175 X 3
6
Approx.
Weight
Primary
Secondary
117 VAC 60 HZ
S1) 880-270-90-0-270-880
VAC @ 300MA CCS
19
(lbs)
S1) 880-270-140-0-270-
HALLICRAFTERS HT-32A POWER
MAIN POWER TRANSFORMER T4
PWDP13245
EI-175 X 3
29G M-6
880 VAC @ 300MA CCS
=6
17 VAC 60 HZ
19
S1) 880-270-140-0-270880 VAC @ 300MA CCS
HALLICRAFTERS HT-32B POWER
MAIN POWER TRANSFORMER T103
EI-175 X 3
HALLICRAFTERS HT-33 SPECIAL
EI-212 X 4
HALLICRAFTERS HT-33A PLATE
EI-212 X
REPLACEMENT (2700 VDC FOR PL-172)
4.625
6
0-75-117 VAC 60 HZ
19
4
120 VAC 60 HZ 1PH
4
120 VAC 60 HZ 1 PH
S1) 4500 VCT @ 500MA
CCS
S1) 6000 VCT @ 0.350A
CCS (FWCT LC RECT)
38
43
S1) 350 VCT @ 100MA
HALLICRAFTERS HT-33A/B FIL
EI-137 X
HT-33A OR HT-33B FILAMENT TRANSFORMER
1.375
HT-33A OR HT-33B FILAMENT TRANSFORMER MODIFIED FOR SOLID STATE
PWDF13180
EI-137 X
1.375
CCS
5
120 VAC 60 HZ 1 PH
S3) 2.5 VAC @ 10A CCS
(10 KVDC INS)
S1) 350 VCT @ 100MA
5
120 VAC 60 HZ 1 PH
PWDP13071
EI-212 X
4.625
CCS
17
S2) 6.0 VAC @ 7.8A CCS
RECTIFIERS (2.5 VAC WINDING ELIMINATED)
HALLICRAFTERS HT-33B PLATE
S2) 6.0 VAC @ 7.8A CCS 6
4
120 VAC 60 HZ 1 PH
6000 VCT @ 0.350A CCS
(FWCT LC RECT)
43
HALLICRAFTERS HT-37 POWER
MAIN POWER TRANSFORMER - SAME AS HT-32 MARK 1 PWDP13141 EI-175 X 3
6
0-75-117 VAC 60 HZ
(ABOVE)
19
HALLICRAFTERS HT-41 PLATE
EI-212 X 4
1800 VDC @ 400 MA CCS FROM FWCT RECT
A-516 C-
HALLICRAFTERS HT-45 BRIDGE
CORE
2
9
117 VAC 60 HZ 1 PH
S1) 4200 VCT @ 400MA
CCS (FWCT)
115/230 VAC 60 HZ
S1) 3500 VRMS @ 0.5A
1PH
CCS
38
33
HALLICRAFTERS HT-45 PLATE
TO PRODUCE 2700 VDC @ 400 MA CCS
A-516 CCORE
9
120/240 VAC 60 HZ 1
PH
S1) 6000 VCT @ 400 MA
CCS (FWCT)
33
HALLICRAFTERS P-20A PLATE
EI-212 X
3.5
5
115 VAC 60 HZ STATIC SHIELD-
3300 VCT @ 350MA DC
34
HALLICRAFTERS P-20A POWER
EI-150 X 2
2
HALLICRAFTERS P-26 POWER
EI-175 X 2
5
110/220 VAC 50/60 HZ 46 VCT @ 8A CCS 10%
W/+OR-10% BUCK
117 VAC 60 HZ
BUCK-BOOST
860-230-0-130-230-860 @
300MA
10
14
S1) 630 VCT @ 450 MA
HALLICRAFTERS PS-150-120
POWER TRANSFORMER FOR HT-44 POWER SUPPLY
CCS
PWDP13092 EI-175 X 2
6
117 VAC 60 HZ 1 PH
S2) 120 VAC @ 20 MA
14
CCS
S3) 12.6 VAC @ 4.5A CCS
S1) 600 VCT @ 0.6A CCS
HALLICRAFTERS PS-500A-AC
POWER TRANSFORMER, T201
EI-175 X
2.5
6
117/234 VAC 60 HZ 1
PH
S2) 135 VAC @ 0.05A
CCS
17
S3) 12.6 VAC @ 5.0A CCS
HALLICRAFTERS SR-2000 PLATE TRANSFORMER
(PLATE & SCREEN) VOLTAGES
PWDP13022
EI-175 X 4"
29G M6
2
117/234 VAC HI-LO
S1) 1080 VRMS @ 0.91
AMPS CCS
TAPS 60 HZ 1PH
S2) 450 VRMS @ 0.070
25
AMPS CCS
12/31
3/1/22, 12:09 PM
Style
Description
Hammond
Part Number Core
HALLICRAFTERS SR-2000 SCREEN
SCREEN CHOKE L301
EI-75 SQ.
1.25"
29GM6
POWER XFMR FOR SX-117 RECEIVER
AUDIO OUTPUT
PWDA13083
REPLACES P/N P26305-1, 115 VAC PRI ONLY
HAMMARLUND HQ-180A POWER (FOR OVERSEAS)
15 HY @ 100MA
5
120 VAC 60 HZ 1 PH
.75
1
9K OHMS P-P
6
117 VAC 60 HZ 1 PH
Weight
(lbs)
1
S1) 360 VCT @ 0.1A CCS
100/500/5000 OHMS
3
1
S2) 5.0 VAC @ 3.0A CCS 10
S3) 6.3 VAC @ 8.0A CCS
S1) 500 VCT @ 90 MA
EI-112 X
1.5
T-9
EI-075 X
EI-150 X 2
HAMMARLUND HQ-100C POWER
T13 MAIN POWER TRANSFORMER
1
Secondary
S1) 520 VCT @ 0.3A CCS
HALLICRAFTERS SX-62A POWER
T30, MAIN POWER TRANSFORMER
HAMMARLUND HQ-145A POWER
Primary
EI-100 X
HALLICRAFTERS SX-117 POWER
HALLICRAFTERS SX-28 AUDIO
Approx.
(see
above)
6
117 VAC 60 HZ 1 PH
29M6RH
EI-112 X
PWDP13094 1.5
6
29GM6RH
PWDP13021
EI-125 X
1.75
EI-125 X
PWDP13165 1.75
6
115/230 VAC 60 HZ 1
PH
115 VAC 60 HZ 1 PH
S1) 420 VCT @ 200 MA
CCS
6
220 VAC 50/60 HZ 1
PH
EI-150 X
2.5"
29GM6R
MAIN POWER XFMR, P/N 26726-1 (6DQ5 PA)
4
4
6
29GAM6
HAMMARLUND HX-50 POWER
CCS
6
117 VAC 60 HZ 1 PH
CCS
6
S1) 700-425-20-0-425-700
VAC @ 200MA CCS
12
S3) 6.3 VAC @ 10A CCS
S1) 900-320-110-0-320-
HAMMARLUND HX-500 POWER
T16 MAIN POWER XFMR, P/N K42351-1
900 VAC @ 175MA CCS
PWDP13096 EI-150 X 3
6
117 VAC 60 HZ 1 PH
5
120/240 VAC 60 HZ 1
PH
S2) 12.6 VAC @ 1.2A CCS 14
(5 KV TEST)
HAMMARLUND HXL-1 PLATE
"EI" REPLACEMENT TRANSFORMER
PWDP13153 EI 29M6
A-393 C-
HIPERSIL REPLACEMENT TRANSFORMER
CORE
HEATH AT-1 POWER XFMR
P/N 54-21
EI-125 X
PWDP13114 1.25"
10
115/230 VAC 60 HZ 1
PH
EI-100 X
1.25
HEATH CHIPPEWA PLATE XFMR
REPLACES BASLER ELECTRIC P/N BE-7129
A-0516/ CCORE
HEATH DX-100 DRIVER
EI-050 X
AUDIO DRIVER, P/N 51-23
.625
900 VAC @ 1.0A CCS
23
S1) 860 VCT @ 0.1A CCS
5
115 VAC 60 HZ 1 PH
5
117 VAC 60 HZ
29GM6
HEATH BR-2
S1) 900 VAC @ 1.0A CCS 30
(FWCT)
S1) 440 VCT @ 75MA
S2) 5 VAC @ 2A
4
3
S3) 12.6 VAC @ 0.6A
9
3
115/230 VAC 60 HZ 1
PH
2500 OHMS @ 20 MA
DC
S1) 7000 VCT @ 0.5A
ICAS (FWCT)
33
S1) 2000 OHMS C.T.
S1) 317-60-0-60-317 VAC
@ 250 MA CCS
HEATH DX-100 LOW VOLTAGE
HEATH P/N 54-31
EI-150 X 2
4
117 VAC 60 HZ
S2) 5 VAC @ 4A (3 KV
INSULATION)
10
S3) 5 VAC @ 2A
S4) 12.6 VCT @ 4A
HEATH DX-100 MOD
DX-100 MODULATION TRANSFORMER
PWDM13136
EI-112 X
1.5
HEATH DX-100 PLATE
EI-150 X
HEATH P/N 54-30 POTTED TYPE
2.5
5
7
8000 OHMS PP C.T.
845 VCT
117 VAC 60 HZ 1 PH
500/2800 O @
250MA(88W) 500 VAC @
4
.176A
1830 VCT @ 400 MA
ICAS
12
13/31
3/1/22, 12:09 PM
Hammond
Style
(see
Description
Part Number Core
above)
HEATH DX-100 PLATE OF
OPEN FRAME VERSION
EI-175 X 2"
PWDP13234
4
29GM6X
HEATH DX-20 POWER
MAIN POWER TRANSFORMER FOR HEATH DX-20
EI-125 X
PWDP13109
1.75
Approx.
Weight
Primary
Secondary
(lbs)
117 VAC 60 HZ 1 PH
1830 VCT @ 400 MA
ICAS
14
S1) 1200 VCT @ 120 MA
5
117 VAC 60 HZ 1 PH
CCS
S2) 6.3 VAC @ 2A CCS
6
HEATH DX-35/40
POWER TRANSFORMER
S1) 750-0-750 VAC @ 150
MA ICAS (FWCT)
EI-125 X
PWDP13105 1.75
5
117 VAC 60 HZ 1 PH
29GAM6
S2) 6.3 VAC @ 3.25A CCS
6
S4) 6.3 VAC @ 0.65A CCS
S1) 260 VAC @ 500MA
HEATH DX-60 POWER
EI-137 X 2"
STYLE #6 HALFSHELL TYPE XFMR
29G M6RH
HEATH HA-10 WARRIOR PLATE
EI-175 X 4"
TO PRODUCE 1500 VDC @ 0.5A CCS FWCT
29GM6RTM
HEATH HA-14-X
EI-162 X 3"
HEAVY DUTY OUTBOARD POWER TRANSFORMER
29G M6X
6
115/230 VAC 60 HZ
1PH
CCS
S2) 110 VAC @ 30MA
8
CCS
HEATH HL-2200 FILAMENT XFMR
REPLACEMENT TRANSFORMER (SAME AS SB-220 / SB- PWDF13057
221)
EI-137 X
1.375
6
2
5
HEATH HL-2200 POWER XFMR
SAME EXACT REPLACEMENT FOR SB-220 / SB-221 / HL- PWDP13034 EI
2
2200
HEATH HL-2200 PLATE
EXTRA HD REPLACEMENT WITH 7 MIL C-CORE (SAME
AS SB-220 / SB-221 / HL-2200)
REQUIRES MODIFICATION TO CHASSIS
B-0393/
PWDP13026 (SIDE
10
MOUNT)
115/230 VAC 60 HZ 1
S1) 3400 VCT @ 0.5A
PH
CCS (FWCT)
24 VCT 250 HZ (PP
S1) 0-2400-2800 VAC @
TRANSISTOR
0.5A CCS
DRIVEN)
S2) 120 VAC @ 0.1A CCS
120/240 VAC 50/60 HZ S1) 5.0 VCT @ 30A CCS
1 PH
S2) 90 VAC @ 0.1A CCS
117/234 VAC 60 HZ HI- 860/1171 VAC @ 0.7A
LO TAPS
CCS
117/234 VAC 60 HZ HI- S1) 860/1171 VAC @ 1.3A
LO TAPS
CCS
25
21
6
23
23
S1) 282 VAC @ 0.25A
HEATH HP-23A/B POWER XFMR
FOR HP-23A OR HP-23B POWER SUPPLY
EI-137 X
PWDP13135 2.5"
6
29GM6X
120/240 VAC 60 HZ 1
PH
CCS
S2) 0-95-125 VAC @ 0.1A 10
CCS
S3) 12.6 VCT @ 6A CCS
S1) 550 VAC @ 50 MA
CCS
S2) 200 VAC @ 100 MA
HEATH IO-102 SCOPE XFMR
EI-137 X 2"
HEATH P/N 54-258
29GAM6X
5
1 PH
CCS
S3) 26 VAC @ 250 MA
8
CCS
S4) 7.88 VAC @ 1A CCS
S5) 0.35 VAC @ 1A CCS
S1) 0-325-650-11751175.625 @
HEATH I0-10 SCOPE POWER
EI-l25 X
P/N 54-105-24
1.75
2
60MA,5MA,0.3A
S2) 120 VAC @ 60MA
S3) 6.3 VAC @ 0.6A
6
S4) 6.3 VCT @ 3.6A
S1) 120 VAC @ 50MA
(PURPLE)
S2) 180 VAC @ 300MA
HEATH OP-1 SCOPE
EI-125 X
2.625
5
117 VAC 60 HZ
(RED)
S3) 6.6 VCT @ 3A
9
(GREEN)
S4) 6.6 VAC @ 2A (BLUE)
S5) 0-1840-1841.35 (IMA)
(@0.2A) (YELLOW)
14/31
3/1/22, 12:09 PM
Description
Hammond
Style
(see
Part Number Core
above)
Approx.
Weight
Primary
Secondary
(lbs)
S1) 1200 VAC @ .005A
CCS
S2) 0.625 VAC @ 0.3A
HEATH P/N 54-130
HO-13 & HO-10 MONITOR SCOPE POWER XFMR
EI-100 X
PWDP13126
1.5
5
117 VAC 60 HZ 1 PH
CCS (5 KVDC INS)
S3) 220 VAC @ .050A
3
CCS
S4) 6.3 VAC @ 0.6A CCS
S5) 6.3 VAC @ 3.6A CCS
S1) 125 VCT @ 6A CCS
EI-162 X
HEATH P/N 54-884
3.5" 29G
STEREO POWER AMPLIFIER POWER TRANSFORMER
5
120 VAC 60 HZ 1 PH
M6
(+ & - 91 VDC)
S2) 54 VCT @ 0.5A CCS
(+15,-15,+12,+35 VDC)
24
S3) 6 VAC @ 0.5A CCS
(METER LIGHTS)
HEATH PS-23 DC CHOKE (L1)
EI-100 X 1
6 HY @ 175 MA DC (350/275 VDC)
1
6 HY @ 175 MA DC
2
(350 WVDC)
HEATH RX-1 - MOHAWK PLATE
SUGGESTED HAMMOND REPLACEMENT PART
NUMBER 272JX
REQUIRES PLATE DROPPING RESISTOR (1K OHM, 20
272JX
WATT)
SEE ARTICLE BY JOHN TREICHLER (KJ6SAV) IN
ELECTRIC RADIO (AUGUST 2017) ISSUE FOR DETAILS
HEATH SB-1000 POWER XFMR
HEATH P/N 54-1061
EI-175 X
PWDP13073 3.5" 29G
4
M6
HEATH SB-200
T-1 MAIN POWER TRANSFORMER - SB-200 / SB-221
S1) 1100 VAC @ 0.5A
PWDP13227
60 HZ ONLY
EI-175 X 3"
29G M-6
2
120/240 VAC 60 HZ 1
CCS
PH
S2) 5.2 VCT @ 15A CCS
S3) 10.5 VAC @ 0.5A CCS
120/240 VAC 60 HZ 1
S1) 800 VAC @ 500MA
CCS
PH
S2) 6.3 VCT @ 8A CCS
22
19
S3) 120 VAC @ 0.1A CCS
S1) 900 VAC @ 500 MA
HEATH SB-200-1
HIGHER VOLTAGE MODEL
PWDP13142 EI-175 X 3
2
110/220 VAC 60 HZ 1
CCS
PH
19
HEATH SB-220 - FILAMENT XFMR 50 HZ
EI-137 X
1.375
HEATH SB-220 / SB-221 - FILAMENT XFMR
HEATH SB-220 POWER XFMR
EXACT REPLACEMENT FOR SB-220 / SB-221 / HL-2200
HEATH SB-220-3-7
EXTRA HD REPLACEMENT FOR SB-220 / SB-221 / HL2200
REQUIRES CHASSIS MODIFICATION TO INSTALL
PWDF13057
EI-137 X
1.375
PWDP13034 EI
5
5
PH
1 PH
6
6
2
117/234 VAC 60 HZ HI- S1) 860/1171 VAC @ 0.7A
23
LO TAPS
CCS
10
23
LO TAPS
CCS
B-0393/
PWDP13026 (SIDE
120/240 VAC 50 HZ 1
MOUNT)
HEATH SB-220-X
2-3 TUBE OUTBOARD - POWER TRANSFORMER
A-0480/ CCORE
10
117/234 VAC 60 HZ
WITH HI-LO TAPS
S1) 925/1175 VAC @
2.13A CCS
HEATH SB-220-X2
OUTBOARD - POWER TRANSFORMER (4-6 3-500Z)
A-518 CCORE
10
117/234 VAC 60 HZ
WITH HI-LO TAPS
S1) 925/1175 VAC @ 3.5A
66
CCS
117/234 VAC 60 HZ
S1) 0-1850-2400 VAC @
WITH HI-LO TAPS
1.75A CCS
HEATH SB-220-X2B
OUTBOARD - USE WITH FULL WAVE BRIDGE
RECTIFIER
HEATH SB-220-X2BS
OUTBOARD - X2 FOR BRIDGE RECT WITH HI/LO SEC
TAPS
A-518 CCORE
A-0518/ CCORE
HEATH SB-221-X
A-0480/ C-
CORE
10
10
10
230 VAC 60 HZ 1PH
0-1850-2400 VAC @ 2.0A
CCS
117/234 VAC 60 HZ
S1) 925/1175 VAC @
WITH HI-LO TAPS
2.13A CCS
46
66
66
46
15/31
3/1/22, 12:09 PM
Description
Hammond
Style
(see
Part Number Core
above)
Approx.
Weight
Primary
Secondary
(lbs)
S1) 800 VAC @ 0.4A CCS
HEATH SB-230 POWER
PLATE, BIAS, & FIL POWER FOR 8873
PWDP13015 EI-150 X 3
5
120/240 VAC 60 HZ
S2) 95 VAC @ 0.045A
1PH
CCS
14
S3) 6.3 VAC @ 3.5A CCS
S1) 600 VAC @ 0.020A
CCS
HEATH SB-610 SCOPE XFMR
P/N 54-168, T-601 MONTIOR SCOPE POWER
PWDP13070
EI-100 X
1.5
5
120 VAC 60 HZ 1 PH
S2) 215 VAC @ 0.050A
CCS
3
S3) 6.3 VAC @ 1.5A CCS
(5 KVDC TEST)
S4) 6.3 VAC @ 2.5A CCS
EI-100 X
1.5"
HEATH SB-614 SCOPE XFMR
P/N 54-182, STATION MONTIOR SCOPE POWER
CCS
S2) 210 VAC @ 0.050A
5
120 VAC 60 HZ 1 PH
29GM6X
CCS
S3) 6.3 VAC @ 0.6A CCS
(5 KVDC TEST)
3
(16 VDC @ 55 MA)
CCS
HEATH SB-614/620 SCOPE XFMR
EI-100 X
PWDP13099 1.5"
5
120 VAC 60 HZ 1 PH
29GM6X
CCS
3
(5 KVDC TEST)
(16 VDC @ 55 MA)
S1) 0-390-780 @ 80MA
HEATH SCOPE
EI-ll2 X 1.5
P/N 54-25
5
117 VAC 60 HZ
S2) 780-1440 @ 3MA
S3) 1440-1440.625 @
600MA
4
S4) 6.3 VAC @ 3.5A
S5) 6.3 VAC @ 0.6A
S1) 300-120-0-120-300
HEATH TX-1 LV POWER APACHE
EI-150 X
(54-65)
2.5
4
117 VAC 60 HZ
VAC 175MA
S2) 5.0 VAC @ 4A
S3) 6.3 VAC @ 3.5A
12
S4) 6.3 VAC @ 9.0A
S5) 5.0 VAC @ 2.0A
S1) 1600 VCT @ 150 MA
HEATH VHF-1 SENECA POWER
EI-150 X 2"
P/N 54-73
29GM6X
CCS
S2) 800 VCT @ 100 MA
5
117 VAC 60 HZ 1 PH
CCS
10
S4) 5.0 VAC @ 2A CCS
S5) 6.3 VAC @ 8A CCS
HEATH W4-AM POWER XFMR
P/N 54-29, OPTION - Electrically similar substitute - our
stock Hammond P/N 374X
HEATH W5M POWER P/N 54-32
OPTION - Electrically similar substitute - our stock
374X
379X
Hammond P/N 379X
HENRY TEMPO 2000
EI-175 X 4"
2
29GAM6X
120/240 VAC 60 HZ 1
PH HI/LO TAPS
980/760 VAC @ 1.0A
ICAS
25
S1) 330 VAC @ 0.5A CCS
HENRY TEMPO 2020
T101 ON SCHEMATIC
A-0036/ CCORE
10
0-100-110-117/0-100110-117 VAC 60 HZ
S2) 0-80-250 VAC @ 100
MA CCS
S3) 0-10-20-23 VAC @ 6A 7
(13.8 VDC PRI)
S4) 4.5 VCT @ 250 MA
CCS (BASE FEEDBACK)
16/31
3/1/22, 12:09 PM
Style
Description
Hammond
(see
Part Number Core
above)
Approx.
Weight
Primary
Secondary
(lbs)
HENRY TEMPO 2020 (C)
A-36 C-
T101 ON SCHEMATIC -- 117 VAC PRI ONLY
CORE
10
117 VAC 60 HZ 1PH
MA CCS
(13.8 VDC PRI)
CCS (BASE FEEDBACK)
S1) 2250 VAC @ 200 MA
HENRY 1KD-5 POWER XFMR
T1, P/N ECA-1111, DIRECT REPLACEMENT
PWDP13033
EI-175 X 3"
29G M6X
4
1PH
19
S2) 5.0 VCT @ 15A CCS
HENRY 1KD-5X
A-480 C-
CORE
HENRY 2K CHOKE
RESONATES WITH 0.1 MFD 7500 VDC CAP
EI-175 X 4"
4
29G M6X
17.6 HY @ 500 MA
CCS (700 MA ICAS)
EI-250 X
115/230 VAC 60 HZ
HENRY 2K CLASSIC
HENRY 2K CLASSIC DC CHOKE
L101 HEAVY DUTY REPLACEMENT FOR ECA 5023
PWDP13016
3.125
10
4
EI-162 X
PWDI13024
HENRY 2K FILAMENT BIAS
4
120/240 VAC 60 HZ
5
120/240 VAC 60 HZ
1PH
PWDP13221
EI-212 X 4
4
A-0518/ CCORE
9
HENRY 2K-2 POWER
PWDP13215 EI
HENRY 2K-2 POWER
HIPERSIL CORE TYPE REPLACEMENT XFMR
PWDP13222
4
A-0480/ CCORE
9
HENRY 2K-3 DC FILTER CHOKE
EI-19 X 2
4
HENRY 2K-3/4 ER PLATE
EI-250 X
3.125
HENRY 2K-4 CHOKE
EI-175 X 4
EXACT REPLACEMENT (USE WITH 0.1 MFD CAP)
29G M6X
HENRY 2K-4-XM
SPECIAL OUTBOARD POWER TRANSFORMER
A-516 CCORE
HENRY 2K-4-1
A-518 C-
CORE
4
4
10
10
S1) 2250 VAC @ 0.7A
CCS
S1) 0-2700-3600 VAC @
0.5A
S2) 10 VCT @ 15A
PH
120/240 VAC 60 HZ 1
PH
120/240 VAC 60 HZ 1
PH
120/240 VAC 60 HZ 1
PH
S1) 5.5 VCT @ 30A
S2) 90 VAC @ 0.1A
S1) 6000 VCT @ 0.5A
CCS (FWCT)
62
S1) 3500 VAC @ 0.8A
CCS
38
S2) 10.2 VCT @ 15A CCS
S1) 3500 VAC @ 0.4A
ICAS
S1) 3500 VAC @ 0.4A
ICAS
26
22
TO 10 HY @ 0.7A DC
PH
10
2400 VRMS @ 0.45A CCS 38
17.6 HY @ 0.050A DC
115/230 VAC 60 HZ 1
42
18
MFD 7.5 KVDC CAP)
115/230 VAC 60 HZ 1
46
25
8 HY @ 0.8A DC (0.1
EI-150 X 2
LONGER AVAILABLE
HENRY 2K-2 MODIFIED
1PH
4
PWDP13155 EI
HENRY 2K ULTRA
1PH
2.5"
29GM6X
HENRY 2K PLATE TRANSFORMER
ORIGINAL LAMINATION SIZE AND STEEL CASE IS NO
S1) 3500 VAC @ 0.4A
CCS
42
10.0 HY @ 500 MA
25
CCS (700 MA ICAS)
120/240 VAC
S1) 3500 VAC @ 1A CCS
58
S2) 10.2 VCT @ 30A
120/240 VAC 60 HZ
S1) 4500 VAC @ 800MA
1PH
S2) 10.2 VCT @ 15A
HENRY 2KD-2 POWER XFMR
T1, P/N 70398, DIRECT REPLACEMENT
PWDP13218
EI-212 X 3"
4
29G M6X
115/230 VAC 60 HZ
1PH
HENRY 2KD-5 POWER XFMR
T1, P/N FDN-7497, DIRECT REPLACEMENT
EI-212 X 3"
PWDP13121
4
29G M6X
115/230 VAC 60 HZ
1PH
66
S1) 2800 VAC @ 400 MA
CCS
29
S2) 10.0 VCT @ 15A CCS
S1) 0-1780-2250 VAC @
400 MA CCS
29
HENRY 3K ER PLATE
EXACT REPLACEMENT, TRIAD P/N 70400
EI-250 X 5"
4
29GM6XRH
230 VAC 60 HZ HI-LO
TAP
S1) 3800/2800 VAC @
600MA CCS
65
17/31
3/1/22, 12:09 PM
Style
Approx.
Hammond
(see
Part Number Core
above)
Primary
9
10 HY @ 700 MA DC
A-0518/ CCORE
9
230 VAC 60 HZ HI-LO
TAP
S1) 4000/3000 VAC @
600MA CCS
38
HENRY 3K-A-M
HEAVY DUTY PLATE TRANSFORMER
A-516 CCORE
10
230 VAC 60 HZ 1 PH
HI-LO TAPS
4000/3000 VAC @ 1.0A
CCS
58
HENRY 3K-A-MC PLATE
A-0518/ C-
SPECIAL HENRY 3K-A PLATE WITH SEC TAPS
CORE
9
230 VAC 60 HZ 1 PH
HENRY 3K-CLASSIC X PLATE
A-0525/ C-
PLATE XFMR FOR EXPORT MODEL
CORE
HENRY 3K-CLASSIC X-1 PLATE
A-0525/ C-
PLATE XFMR FOR EXPORT MODEL W/HI/LO PRI
CORE
HENRY 3002A-M PLATE
A-0516/ CCORE
10
HENRY 4K ULTRA CHOKE
EI-212 X 4
4
Description
HENRY 3K-A DC FILTER CHOKE
A-0203/ C-
RESONATES WITH 0.1 MFD 7500V CAPACITOR
CORE
HENRY 3K-A PLATE
HIPERSIL REPLACEMENT FOR HENRY 3K-A
HENRY 4K ULTRA DC CHOKE
RESONANT CHOKE - REQUIRES 0.2 MFD 10 KVDC CAP
PWDP13084
PWDI13097
A-0518/ CCORE
10
10
9
HENRY 4K ULTRA PLATE
REPLACEMENT XFMR WITH 20% PRI CUTBACK TAP
PWDP13147 EI
4
FOR MODERN PRI VOLTAGES
HENRY 4K-2 DC FILTER CHOKE
EI-175 X 4"
REPLACES TRIAD P/N 16113
29GA M6X
HENRY 4K-2 SCREEN/BIAS XFMR
EI-137 X
1.75
HENRY 8K ULTRA XHD DC CHOKE
A-0525/ C-
EXTRA HEAVY DUTY DC FILTER CHOKE
CORE
HUNTER 2000A
A-0459/ C-
POWER TRANSFORMER
CORE
Weight
Secondary
17
0-2800-3500-4000 VAC @
0.6A CCS
0-200-210-220-230
S1) 0-3000-4000 VAC @
VAC 60 HZ 1 PH
1.5A ICAS
230 VAC 60 HZ HI LO- 4000/3000 VAC @ 1.5A
TAP
(lbs)
ICAS
38
86
86
0-220-230-240 VAC 60 0-3000-4400 VAC @ 1.0A
58
HZ 1 PH
CCS
4 HY @ 1.5A CCS OR
38
2.0A ICAS
9.0 HY @ 1.0A DC
38
(4500 WVDC)
0-244-294 VAC 60 HZ 1 0-3500-4200 VAC @ 1.0A
PH
ICAS
102
8.8 HY @ 0.7A DC
2
(RESONATE WITH 0.2
25
MF)
S1) 0-500-700-900 VAC @
5
230 VAC 60 HZ 1 PH
0.1A CCS
7
S2) 175 VAC @ 0.1A CCS
9
9
8.0 HY @ 1.5A CCS
49
120/240 VAC 60 HZ 1
S1) 0-450-700-900 VAC @
1.0A CCS
PH
S2) 6.3 VCT @ 16A CCS
23
S3) 6.3 VAC @ 1A CCS
S1) 0-800-860-920 VAC @
HUNTER 2000B
A-0459/ C-
POWER TRANSFORMER
CORE
HUNTER 2000C
EI-225S X
POWER TRANSFORMER
3"
9
6
120/240 VAC 60 HZ 1
1.0A CCS
PH
117/234 VAC 60 HZ
1PH
23
S2) 7.0 VAC @ 1.0A CCS 35
S3) 6.0 VCT @ 25A CCS
S1) 0-265-530 VAC @
0.25A CCS
S2) 0-130-260 VAC @
HY-GAIN 3750 POWER XFMR
EI-150 X 2
STYLE NO. 5 HORIZONTAL ENDBELL TYPE
29 M6
5
0-100-110-120/0-100110-120 VAC 60HZ
0.1A CCS
S3) 80 VAC @ 0.1A CCS
S4) 0-7-14 VAC @ 3.5A
10
CCS
S5) 6.3 VAC @ 4.5A CCS
S6) 12.6 VAC @ 0.7A CCS
S1) 1060 VCT @ 150 MA
JOHNSON ADVENTURER POWER
VIKING ADVENTURER POWER TRANSFORMER
EI-l25 X
PWDP13068
1.75
4
115 VAC 60 HZ 1 PH
CCS
6
JOHNSON CHALLENGER POWER
EFJ P/N 22.1501, T1 MAIN POWER XFMR
PWDP13206 EI-150 X 2
4
115 VAC 60 HZ 1 PH
S1) 1300 VCT @ 275 MA
CCS (FWCT)
S2) 6.3 VAC @ 5A CCS
10
18/31
3/1/22, 12:09 PM
Style
Description
Hammond
(see
Part Number Core
above)
Approx.
Weight
Primary
Secondary
(lbs)
S1) 300 VCT @ 150 MA
JOHNSON DESK KW BIAS
T-200 (WILL FIT, BUT NEED NEW MTG HOLES)
PWDP13058 EI-125 X 2
JOHNSON DESK KW FILTER CHOKE
A-0393/ C-
HV FILTER CHOKE, L300
CORE
JOHNSON DESK KW MOD
PWDM13037
EI-175 EESTACK
JOHNSON DESK KW MOD FILAMENT
EI-137 X
FILAMENT XFMR FOR PP 810 MODULATORS
1.375
JOHNSON DESK KW PLATE
EI-287 X 5"
P/N P-2126
STACK
JOHNSON DESK KW PLATE (HR)
PWDP13051
JOHNSON DESK KW RECT FIL
872A RECTIFIER FILAMENT XFMR, T-301
JOHNSON DESK KW SCREEN
T-201, EFJ P/N 22.1069
JOHNSON INVADER 2000 L301
DC FILTER CHOKE, 4-10 HY @ 500 MA DC
PWDP13192
PWDI13231
5
10
115 VAC 60 HZ 1 PH
1800/2400 VCT,
18000/11600 OHMS
PP
5
115 VAC 60 HZ 1 PH
10.0 VCT @ 10A CCS
115/230 VAC 60 HZ 1
2900-2325-0-2325-2900
PH
VAC @ 600 MA CCS
(6250 OHMS RFPA)
35
6
100
A-0480/ CCORE
10
115/230 VAC 60 HZ 1
PH
VAC @ 600 MA CCS
46
EI-150 X 2
4
115 VAC 60 HZ 1 PH
S1) 5.0 VCT @ 20A CCS
10
115 VAC 60 HZ 1 PH
1350 VCT @ 125MA OR
(HI-LO TAPS)
1060 VCT @ 130MA
EI-125 X
1.25
EI-175 X 2
5
5
10 HY @ 90 MA TO 4
.875
JOHNSON INVADER 2000 PLATE
MAIN PLATE TRANSFORMER
EI-225 X 3"
6
29G M6X
117/234 VAC 60 HZ 1
PH
JOHNSON INVADER 2000 SCREEN
EI-l25 X 2"
0-105-117 VAC 60 HZ 1
T-303, SNC P/N P4215, EFJ P/N 22-1643
29G M6X
1
4
EI-100 X 1
4
EI-175 X 2
4
5 HY @ 100 MA DC
2
(600 WVDC)
PH
115 VAC 60 HZ 1 PH
4
14
HY @ 500 MA DC
EI-87 X
JOHNSON THUNDERBOLT DC CHOKE
L101 HIGH VOLTAGE DC FILTER CHOKE
8
5
7
23
(2500 WVDC 1 PH)
DC SCREEN CHOKE, 5 HY @ 100 MA DC
866A HIGH VOLTAGE FILAMENT TRANSFORMER
6.0 HY @ 800MA DC
JOHNSON INVADER 2000 L302
JOHNSON INVADER 2000 T302
CCS
5000 VCT @ 400 MA
ICAS
33
S1) 1060 VCT @ 130 MA
CCS
S2) 5.3 VAC @ 2A CCS
S1) 2.5 VAC @ 10A CCS
(5 KVDC TEST)
7
2
25 HY @ 80 MA TO 5
PWDI13205
HY @ 500 MA 2200
14
VDC
S1) 5.0 VAC @ 15A CCS
(4-400A FILAMENT)
JOHNSON THUNDERBOLT FILAMENT
T-102, SNC P/N P3389, EFJ P/N 22.789-1
EI-150 X
1.5
2
115 VAC 60 HZ 1 PH
S2) 5.0 VAC @ 15A CCS
(4-400A FILAMENT)
8
(866A FILAMENTS)
S1) 783-219-0-219-783
JOHNSON THUNDERBOLT LV T-103
SCREEN & BIAS TRANSFORMER, P/N 22.1421
PWDP13250
EI-l25 X
1.75
4
JOHNSON THUNDERBOLT PLATE
DIRECT REPLACEMENT - PLATE TRANS (SAME AS T302 - JOHNSON 500 PLATE)
PWDP13046 EI
JOHNSON VALIANT DRIVER XFMR
EI-062 X
P/N 22.1286, T4
.75
5
0-110-120 VAC 60 HZ 1 VAC @ 0.1A CCS
PH
115/230 VAC 60 HZ 1
PH
230 OHMS DC (12AU7
1
AUDIO DRIVER
PLATE)
S3) 6.3 VAC @ 1.6A CCS
6
4800 VCT @ 500 MA CCS 33
800 OHMS CT (PP 6146
MODULATOR GRIDS)
1
S1) 310-215-0-215-310
VAC @ 250 MA CCS
JOHNSON VALIANT LOW VOLTAGE
EI-150 X 2
POWER TRANSFORMER, (T-2) SNC P/N 3068
5
117 VAC 60 HZ
S2) 6.3 VAC @ 12A CCS
10
JOHNSON VALIANT LV CHOKE
EI-100 X 1
5V4 +300 VDC FILTER CHOKE, L-44
JOHNSON VALIANT MOD XFMR
EFJ P/N 22.1285, SNC P/N P2998
PWDM13044
EI-125 X
1.5
3
5
10 HY @ 100 MA DC
2
(300 WVDC)
840 VCT @ 0.212A
S1) 450 VCT @ 0.300A
CCS (7300 OHMS P-P) CCS (2100 OHMS RF PA)
5
19/31
3/1/22, 12:09 PM
Style
Description
(see
Part Number Core
above)
Primary
5
120 VAC 60 HZ 1 PH
3.5"
FOR JOHNSON VALIANT TRANSMITTER
HV DC FILTER CHOKE
JOHNSON VIKING COURIER PLATE
TO DELIVER 1500 VDC @ 335 MA
JOHNSON VIKING II AUDIO DR
SNC P/N 1503 EFJ P/N 22.753
Weight
EI-150 X
JOHNSON VALIANT PLATE
JOHNSON VIKING COURIER CHOKE
Approx.
Hammond
29GM6X
PWDI13055
PWDP13056
EI-137 X 2"
29G M6X
EI-175 X 3"
5
Secondary
S1) 1520 VCT @ 400MA
CCS
PR) 10 HY @ 0.35A
(lbs)
16
8
CCS (1500 WVDC)
S1) 3600 VCT @ 237 MA
5
115 VAC 60 HZ 1 PH
PWDA13076 EI-62 SQ.
3
100 VAC @ .030A CCS S1) 84 VCT @ .036A CCS
1
(SINGLE 6AU6 PLATE) (PP 807 GRIDS)
EI-62 SQ.
3
100 VAC @ .030A CCS 84 VCT @ .036A CCS (PP
1
(SINGLE 6AU6 PLATE) 807 GRIDS)
EI-150 X 2
5
115 VAC 60 HZ 1 PH
JOHNSON VIKING II AUDIO DR-1
SNC P/N 1503 EFJ P/N 22.753 * NO AIR GAP
JOHNSON VIKING II HV XFMR
SNC P/N #1781, EFJ P/N 23.1002-1
29GAM6X
CCS
865-0-865 VAC @ 250MA
CCS
19
10
S1) 298-70-0-70-298 VAC
JOHNSON VIKING II LV POWER
T-2, P/N 22.752, P/N P1893
@ 250MA CCS
PWDP13225 EI-125 X 2
5
115 VAC 60 HZ 1 PH
S2) 6.3 VAC @ 7A CCS
S3) 5 VAC @ 2A CCS
EI-112 X
PWDM13220
1.875
5
795 VCT @ 100 MA PP S1) 500 VAC @ 250 MA
807 @ 7000 OHMS P-P DC (RP = 2800 OHMS)
PWDI13014
1
7
S4) 5 VAC @ 2A CCS
JOHNSON VIKING II MOD XFMR
T4, SNC P/N P1992 PP 807'S TO PAR 6146
JOHNSON VIKING RANGER CHOKE
P/N 22.749, SNC P/N P1501, LV DC CHOKE
JOHNSON VIKING RANGER AUDIO DR
EI-087 X 1
PWDA13076 EI-62 SQ
3
15.0 HY @ 95 MA DC
2
(DCR = 290 OHMS)
100 VAC @ .030A CCS
5
(PP 1614 / 6L6 GRIDS)
1
S1) 19.8 VAC @ 0.050A
JOHNSON VIKING RANGER II MOD
SNC P/N P2429, T2, PP 7027A'S, 32 WATTS
PWDM13007 EI-087 X 1
1
10600 OHM PP, 695
CCS (4% FEEDBACK)
VCT @ .072A CCS
S2) 495 VCT @ .065A AC
& .130A DC
2
S1) 670-420-140-0-140JOHNSON VIKING RANGER PLATE
SNC P/N 2793, EFJ P/N 22.985
EI-150 X
PWDP13183
2.5
5
117 VAC 60 HZ
2
10 HY @ 200MA DC
(350 WVDC)
420-670 VAC @ 0.260A
S2) 6.3 VAC @ 10A CCS
12
JOHNSON VIKING 500 L302
10 HY @ 200MA, P/N 22.1264
JOHNSON VIKING 500 L303
EFJ P/N 22.1265 25HY@.08A TO 5 HY @ 0.5A
JOHNSON VIKING 500 MOD
VIKING 500 MODULATION TRANSFORMER
JOHNSON VIKING 500 PLATE
DIRECT REPLACEMENT - PLATE TRANS (T-302)
PWDI13131
PWDI13036
EI-112 X
1.5
EI-175 X 2"
29GAM6X
5
PWDM13062 EI-212 X 3
4
PWDP13046 EI CORE
5
4
25 HY @ 80 MA TO 5
14
HY @ 0.5A * 2200 VDC
S1) 8000 OHMS
23000 OHMS P-P 2400
(2000VDC @
VCT (200-3500 HZ)
250MA)1414VAC 250W
115/230 VAC 60 HZ 1
PH
29
S1) 960 VCT @ 200MA
CCS
JOHNSON VIKING 500 T-301
LV POWER TRANSFORMER, P/N 22.1266
PWDP13025
EI-175 X
1.75
5
115 VAC 60 HZ 1 PH
S2) 560 VCT @ 100MA
CCS
S3) 6.4 VCT @ 9A CCS
12
S4) 2.5 VCT @ 10A CCS
S5) 5.0 VCT @ 3A CCS
JOHNSON VIKING 500 T102
AUDIO DRIVER 4W 6B4 TO PP 6146'S
JOHNSON 6N2 T-BOLT FILAMENT
FILAMENT TRANSFORMER, T-102
JOHNSON 6N2 T-BOLT PLATE
T101 PLATE TRANSFORMER
EI-75 X 1
1
EI-125 X
1.75
5
EI-212 X 4
2
LOUDENBOOMER MK 2
A-0393/ C-
PLATE TRANSFORMER
CORE
76 VAC @ .050A (170
76 VCT @ .050A (180
OHMS DC)
OHMS DC)
1
115 VAC 60 HZ 1 PH
S2) 6.0 VAC @ 6A CCS
6
S3) 115 VAC @ 0.1A CCS
10
115/230 VAC 60 HZ 1
S1) 4800 VCT @ 0.5A
PH
CCS
115/230 VAC 60 Hz
S1) 6570 VCT @ 300 MA
CCS FWCT CHK INPUT
38
23
20/31
3/1/22, 12:09 PM
Style
Description
Hammond
(see
Part Number Core
above)
Approx.
Weight
Primary
Secondary
(lbs)
S1) 0-1600-2000 VAC @
MCABEE A-518-10 MULTI-SEC-#1
A-0518/ C-
PLATE/SCREEN/BIAS/FILAMENT TRANSFORMER
CORE
10
0-220-240 VAC 60 HZ 1
PH
2.0A CCS
S2) 6.0 VAC @ 21A CCS
(8 EA 4CX250R'S)
66
S3) 280 VCT @ 0.25A
CCS
S4) 90 VAC @ 0.1A CCS
MFJ P/N 406-1418-X
SPECIAL HEAVY DUTY MODEL FOR AL-1500
A-0480/ CCORE
MFJ P/N 406-1418-1DX
A-0516/ C-
EXTRA HEAVY DUTY AL-1500 TRANSFORMER
CORE
MFJ P/N 406-1418-1DX-J
A-0516/ C-
EXTRA HD AL-1500 XFMR, 100/200 VAC PRI
CORE
MFJ P/N 406-1418-1J
"J" IS JAPANESE VERSION FOR AL-1200
A-274/C C10
CORE
MOD TRANSFORMER 1200 WATT
A-550/C C-
PP 304TL'S @ 12,000 OHMS P-P
CORE
MOD TRANSFORMER 30 WATT
EI-175 X
1.75 29G
SINGLE 807 @ 450 VDC @ 150MA DC THRU SEC
10
10
10
9
4
M6
MOD TRANSFORMER 300 WATT
A-0518/ C-
PP 4CX150A'S @ 17600 OHMS P-P
CORE
MOD TRANSFORMER 500 WATT
PP 813'S TO SINGLE 813 @ 2000 VDC @ .25A
A-0525/ CCORE
0-220-240 VAC 60 HZ
1PH
60 HZ 1PH
1PH
S1) 2570 VAC @ 1.0A
CCS
46
58
58
100/200 VAC 50/60 HZ 2570 VAC @ 800MA ICAS 37
2872 VCT @ 0.34A
1768 VAC @ 0.39A CCS
CCS (12,000 OHMS P(2500 VDC @ .55A)
P)
16.4 VAC @ 2.0A CCS S1) 318 VAC @ 0.106A
(8 OHMS)
CCS (3000 OHMS)
137
12
9
2100 VCT @ 0.17A
1414 VAC @ 0.18A CCS
CCS (17,600 OHMS P(2000 VDC @ .25A)
P)
38
9
1768 VCT @ 0.2A CCS 1414 VAC @ 0.25A DC
(PP 813'S 16K PP)
(2000 VDC @ 0.25A)
49
S1) 550 VCT @ 200 MA
NATIONAL HRO-60 POWER (R)
NOT EXACT REPLACEMENT BUT WILL FIT IN
PWDP13224 EI-150 X 2
5
115/230 VAC 60 HZ 1
PH
CCS
10
S3) 0-6.3-13.3 VAC @ 6A
CCS
NATIONAL NC-183 POWER
PWDP13122 EI
NATIONAL NCL-2000 FIL/BIAS
EI-087 X
T2 (FILAMENT & BIAS), P/N C51440
2.250
6
115/230 VAC 60 HZ 1
8
PH
S1) 130 VCT @ 50 MA
5
115 VAC 60 HZ 1 PH
CCS
2
NATIONAL NCL-2000 POWER
TRANSFORMER (PLATE & SCREEN) VOLTAGES
PWDP13091 EI-175 X 4
2
117/234 VAC HI-LO
AMPS CCS
TAPS 60 HZ 1PH
25
AMPS CCS
S1) 1100 VAC @ 0.36A
NATIONAL NCX-1000 POWER
PLATE, DRIVER PLATE & SCREEN VOLTAGES
PWDP13003
EI-175 X
2.5
2
117/234 VAC 60 HZ 1
PH
CCS
17
S2) 0-240-480 VAC @
0.20A CCS
S1) 310 VRMS @ 1.0 AMP
PALOMAR 300A POWER
PWDP13148
EI-150 X 2
1/2"
5
117 VAC 60 HZ 1 PH
CCS
S2) 14 VRMS @ 8 AMPS
CCS
PITTENGER JP1815
A-480 C-
FOR AMP IN AUG 84 ISSUE OF HAM RADIO
CORE
PITTENGER P/N FT-800A7
DUAL 3CX800A7 FILAMENT TRANSFORMER
PITTENGER P/N JP3315 PLATE
FOR J. PITTENGER 8877 AMP IN SEPT 86 QST
PITTENGER P/N PT-2475
FOR K8RA AMPS DESCRIBED IN ARRL HANDBOOK
PWDP13166
PWDP13239
10
240 VAC 60 HZ 1 PH
1800 VRMS @ 1.5A CCS
46
EI-100 X 1
1
120 VAC 60 HZ 1 PH
13.5 VAC @ 3.0A CCS
2
A-0518/ CCORE
10
230 VAC 60 HZ 1 PH
0-2300-2600-3300 VAC @
66
1.5A CCS
117/234 VAC 60 HZ 1
0-1770-2125-2475 VAC @
PH
1.5A CCS
117/234 VAC 60 HZ 1
0-1414-1770-2125-2475
PH
VAC @ 1.5A CCS
A-0518/ CCORE
PITTENGER P/N PT-2475-01
A-0518/ C-
ADDITIONAL SEC TAP @ 1414 VAC
CORE
10
10
66
66
21/31
3/1/22, 12:09 PM
Style
Description
Hammond
Part Number Core
PITTENGER P/N PT-2475-1
A-0516/ C-
1.35 AMP CCS VERSION OF PT-2475
CORE
PRIME INST P/N AL1800T
A-393 C-
PLATE TRANSFORMER
CORE
PRIME INST P/N AL2080
A-274 CCORE
PRIME INST P/N AL2080A
A-393 CCORE
PRIME INST P/N AL2400
A-0393/ C-
PLATE TRANSFORMER
CORE
(see
above)
10
10
10
10
10
Approx.
Primary
Secondary
117/234 VAC 60 HZ 1
PH
1.35A CCS
117/234 VAC 60 HZ
0-1200-1650-1800 VAC @
1PH
500 MA CCS
120/240 VAC 60 HZ
Weight
(lbs)
58
23
2080 VAC @ 0.8A ICAS
37
120/240 VAC 60 HZ
1PH
2080 VAC @ 0.5A CCS
23
117/234 VAC 60 HZ
S1) 0-1700-2400 VAC @
1PH
500 MA CCS
1PH
23
S1) 970 VAC @ 700 MA
PRIME INST P/N AL8A
PRIME INST P/N AL84T
PRIME INST P/N AL88T
EI-162 X
3.5
A-0016/ CCORE
A-0393/ CCORE
4
10
10
117/234 VAC 60 HZ 1
CCS
PH
S3) 12 VAC @ 2A CCS
117/234 VAC 60 HZ 1
PH
24
S1) 0-600-850 VAC @
1.0A ICAS
S2) 6.0 VAC @ 8A CCS
117/234 VAC 60 HZ
0.5A
1PH
S2) 10 VAC @ 2.0A
17
23
S3) 5 VAC @ 10A
PRIME INST P/N AR-418
A-0274/ CCORE
PRIME INST P/N AR-418-M
PLATE TRANSFORMER
A-274 CCORE
PRIME INST P/N AR418-1J
A-274/C C-
CORE
SIGNAL ONE CX7A
A-0371/ CCORE
SIGNAL ONE 1030
A-0371/ C-
MILSPEC 1030 TRANSCEIVER POWER XFMR
CORE
10
1 PH
10
0-220-240 VAC 50/60
HZ 1 PH
10
9
117/234 VAC 60 HZ 1
PH
9
120/240 VAC 60 HZ 1
PH
S1) 2570 VAC @ 800MA
37
S1) 2872 VAC @ 800 MA
ICAS
37
ICAS
37
S1) 230 VAC @ 0.1A CCS
S2) 43 VCT @ 1.0A CCS
8
S3) 575 VAC @ 0.2A CCS
S1) 22.0 VAC @ 20 AMPS 8
S1) 650 VCT @ 300 MA
STANCOR P-8339
EI-150 X
2.5
CCS
5
117 VAC 60 HZ 1 PH
S3) 12.6 VCT @ 5.25A
12
CCS
STANCOR P-8339-1
EI-150 X
2.5
5
117 VAC 60 HZ 1 PH
S1) 600 VCT @ 300 MA
CCS
S2) 12.6 VCT @ 5.25A
12
CCS
STANCOR P/N P-8031
A-518/C C-
HIPERSIL VERSION OF STANCOR P/N P-8031
CORE
STANCOR P/N PC-8417
30 VA LV RECTIFIER POWER TRANSFORMER
EI-100 X 1
10
5
115/230 VAC 60 HZ 1
S1) 2075-1775-0-1775-
PH
2075 VAC @ 0.5A CCS
S1) 440 VCT @ 0.050A
0-110-115 VAC 60 HZ 1 CCS
PH
S2) 6.3 VAC @ 0.6A CCS
66
2
S3) 25.2 VAC @ 0.5A CCS
SVETLANA 4CX800A FIL XFMR
EI-150 X
FIL & BIAS XFMR FOR 2 TUBES
1.5
SVETLANA 4CX800A FIL, BIAS, SCREEN XFMR
FIL & BIAS XFMR FOR 2 TUBES WITH HIGHER SCREEN PWDP13193
VOLTAGE
EI-150 X
1.5
SVETLANA 4CX800A PLATE XFMR
A-0274/ C-
2500 VDC @ 1.0A ICAS FROM FWC CAP INPUT
CORE
4
0-115-120-125 VAC 60 S1) 12.6 VAC @ 8A CCS
HZ 1 PH
S2) 150 VAC @ 0.1A CCS
8
S2) 70 VAC @ 150 MA
4
10
CCS
HZ 1 PH
S3) 250 VAC @ 0.25A
CCS
0-230-240-250 VAC 60 S1) 1770 VAC @ 1.5A
HZ 1 PH
ICAS
8
37
22/31
3/1/22, 12:09 PM
Style
Description
Hammond
Part Number Core
(see
above)
SWAN MARK I POWER
POWER TRANSFORMER FOR SWAN MARK I LINEAR
EI-162 X 3"
PWDP13012
6
29GAM6X
Approx.
Primary
Secondary
Weight
(lbs)
S1) 0-568-1065 VAC @
120/240 VAC 60 HZ 1
PH
0.5A CCS
21
S3) 12 VAC @ 1A CCS
S1) 0-500-1000 VAC @
A-480 C-
SWAN MARK VI OUTBOARD POWER
CORE
10
120/240 VAC 60 HZ
2.0A CCS
1PH
46
S3) 12.0 VAC @ 2A CCS
S1) 588/1123 VAC @ 1.2A
SWAN MK II 3 TUBE OUTBOARD
A-274 C-
MUST RUN FILAMENTS IN SERIES
CORE
SWAN MK-I-X
A-480 C-
CORE
SWAN MK-I-X2
A-0518/ C-
CORE
10
117/234 VAC 60 HZ
CCS
S2) 15 VCT @ 15A CCS
S3) 12.6 VAC @ 2A CCS
37
10
117/234 VAC 60 HZ 1
1.5A CCS
PH
S2) 10.0 VCT @ 30A CCS
S3) 12 VAC @ 1A CCS
46
10
117/234 VAC 60 HZ 1
3.0A CCS
PH
66
S3) 12 VAC @ 1A CCS
SWAN 117-B/C FILTER CHOKE
P/N 274-001, 3946524 (2 EA SWAN 400 PS)
EI-62 X .75 1
3.5 HY @ 80 MA DC
(+275 VDC SUPPLY)
1
S1) 0-320-640 VAC @ 360
MA CCS
SWAN 117-B/C POWER
EI-150 X 2
FOR SWAN 400 AC POWER SUPPLY
6
117 VAC 60 HZ 1 PH
S2) 90 VAC @ 140 MA
CCS
10
S3) 12.6 VAC @ 3.69A
CCS
S1) 0-9.6-14.4-19.2 VAC
@ 6A CCS (DC PRI)
S2) 427 VAC @ 300 MA
SWAN 117-XC POWER
FOR SWAN 350 AC POWER SUPPLY
PWDP13023 EI-150 X 2
4
117 VAC 60 HZ 1 PH
CCS
(AC PRIMARY)
S3) 230 VAC @ 300 MA
CCS
10
S4) 90 VAC @ 140 MA
CCS
@ 6A CCS (DC PRI)
SWAN 230-XC POWER
EI-150 X 2"
PWDP13027
4
29G M-6
1 PH (AC PRIMARY)
10
CCS
S4) 90 VAC @ 140 MA
CCS
TEN-TEC 422 & 422B - HV TRANSFORMER
FOR TEN-TEC MODEL 422 CENTURION LINEAR
AMPLIFIER
Page 3-1 of the Ten-Tec Centurion Manual (Section 3-1.4) is
incorrect.
PWDP13045
B-0393/ CCORE
10
115/230 VAC 60 HZ 1 P 2225 VAC @ 0.5A CCS
23
The stock unit was not a 2.5KVA unit nor did it weigh 35 lbs
(it weighs 23 lbs.)
Special thanks to Steve - KD8ZBG for reporting this.
S1) 1270 VAC @ 1.0A
CCS
TEN-TEC 425 TITAN POWER XFMR
T1, MAIN POWER TRANSFORMER
PWDP13039
A-0480/ CCORE
10
120/240 VAC 50/60 HZ S2) 570 VAC @ 1.0A CCS
1 PH
S3) 13.5 VAC @ 6A CCS
46
S4) 20 VAC @ 6A CCS
S5) 20 VAC @ 2A CCS
23/31
3/1/22, 12:09 PM
Style
Description
THOMAS LV POWER #01
THORDARSON P/N T-11M77
125-300 WATT MULTI-MATCH MODULATION XFMR
Hammond
(see
Part Number Core
above)
EI-150 X
1.5
4
EI
5
Approx.
Weight
Primary
120/240 VAC 60 HZ 1
PH
2.5"
5
S2) 60 VAC @ 0.3A CCS
@ 225 MA DC
29GM6X
8
S3) 6.3 VCT @ 10A CCS
VDC
117 VAC 60 HZ 1 PH
(lbs)
S1) 290 VCT @ 0.3A CCS
PP 811A'S @ 1000
EI-150 X
Secondary
S1) 2150/1000 VCT @
95/125 MA CCS FWCT
26
12
S1) 12.6 VCT @ 10.8A
TIBBETTS LV POWER #01
(3) 4CX800A FIL/BIAS/SCREEN XFMR
CCS
EI-150 X
1.5"
4
29GAM6
120/240 VAC 60 HZ 1
S2) 270 VCT @ .025A
PH
CCS
S3) 570 VCT @ .080A
8
CCS
S1) 850 VAC @ 0.5A CCS
TOKYO HY POWER LABS HL-1K
EI-175 X 3"
T1, (NEED MTG BRKTS FROM OLD XFMR)
29G M6X
2
0-100-110-117/0-100-
S2) 280 VAC @ 0.1A CCS
110-117 VAC 60 HZ
S3) 100 VAC @ 0.1A CCS
19
S4) 12 VAC @ 3A CCS
TRANSWORLD P/N 410012
T9, T10, T11 OR T12 IN TRANSWORLD SS AMP
TRIAD P-11A
WILL YIELD 600 VDC @ 250 MA FROM FWCT
TRIAD P-216AL
PLATE TRANSFORMER (WITHOUT END COVERS)
TRIAD P-217AL
PLATE TRANSFORMER
EI-125 X
PWDP13167 1.25"
2
120 VAC 60 HZ 1 PH
EI-150 X 2
5
115 VAC 60 Hz
EI-212 X 3
4
EI-175 X
PWDP13040 2.5"
EI-175 X
POWER TRANSFORMER
1.75
POWER TRANSFORMER
5
29GAM6
TRIAD P-3A
TRIAD P-9A
15.1 VAC @ 8A CCS
4
29GM6
5
S1) 1455 VCT @ 250 MA
CCS
115/230 VAC 60 HZ
S1) 2430 VCT @ 500 MA
1PH
CCS (FWCT)
115/230 VAC 50/60 HZ 2880 VCT @ 0.25A DC
1 PH
(FWCT)
115 VAC 60 HZ 1 PH
S1) 600/300 VCT @ 0.3A
CCS
10
29
17
12
S1) 1236 VCT @ 500 MA
EI-175 X 3" 5
115 VAC 60 HZ 1 PH
CCS (FWCT)
19
S2) 5 VAC @ 6A CCS
TRIAD P/N 70581
EI-250 X
HENRY 2K-4 REPLACEMENT POWER TRANSFORMER
3.125
4
115/230 VAC 60 HZ 1
PH
S1) 3500 VAC @ 0.4A
CCS
42
S1) 700 VCT @ 125 MA
TRIAD R-14A POWER XFMR
EI-l25 X 1.5 5
115 VAC 60 HZ 1 PH
CCS
5
S3) 6.3 VCT @ 4.5A CCS
S1) 800 VCT @ 70 MA DC
CCS
TRIAD R-83A
EI-ll2 X
O-12 OSCILLOSCOPE POWER TRANSFORMER
1.875
S2) 650 VAC @ 3 MA DC
5
115 VAC 60 HZ 1 PH
CCS
5
S3) 1.25 VAC @ 0.3A CCS
S4) 6.3 VCT @ 3.5A CCS
S5) 6.3 VAC @ 0.6A CCS
UTC CVM-2
60W MULTI-MATCH MOD XFMR IN RC-150 CASE
EI
5
18K-2K OHMS P-P
S1) 30K-200 OHMS RF PA
CENTER TAPPED
(60 WATTS AUDIO OUT)
11
S1) 1240 VAC @ 0.4A
VECTRONICS HF600-QSK POWER
SINGLE 3-500Z IN GROUNDED GRID
CCS
EI-200RX
2"
4
29GAM6X
0-120 & 0-80-100-120
VAC 60 HZ 1 PH
S2) 21 VAC @ 0.2A CCS
18
S3) 5.8 VCT @ 15A CCS
VR GLOBE KING 500 MOD XFMR
EI-150 X
3.5"
5
29GM6X
https://www.hammfg.com/electronics/transformers/classic/pwdahl
1465 VCT @ 0.246A
S1) 1275 VAC @ 0.283A
CCS (7400 OHMS P-P) CCS (1800 VDC @ .4A)
16
24/31
3/1/22, 12:09 PM
Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg.
Style
Description
Hammond
(see
Part Number Core
above)
EI-112 X
YAESU FL-2000B LV PWR T2
1.5"
FILAMENT & CONTROL VOLTAGE TRANSFORMER
2
29GAM6
Approx.
Weight
Primary
Secondary
0-100-110-117 & 0-100- S1) 6.5 VCT @ 8A CCS
110-117 VAC 60 HZ
S2) 13 VAC @ 1A CCS
(lbs)
4
S1) 0-425-620-850 VAC @
YAESU FL-2100B POWER XFMR
EI-175 X 3"
P/N 21002, T1, FOR PAIR OF 572B'S
29GAM6X
6
0-100-110-117 & 0-100- 1A ICAS
110-117 VAC 60 HZ
S2) 6.5 VCT @ 8A CCS
19
S3) 13 VAC @ 1A CCS
YAESU FT-901 POWER XFMR
EI-137 X
WITHOUT DC WINDINGS & DUAL PRIMARY
2.5
6
0-100-110-117 VAC 60
HZ 1 PH
S1) 320 VCT @ 0.5A CCS
S2) 0-120-190-250 VAC @
0.1A CCS
10
S3) 11.5-0-11.5-12.6 VAC
@ 2A CCS
S1) 0-240-460-600 VAC @
0.275A CCS
EI-150 X
YAESU TEMPO AC ONE PWR XFMR
TEMPO AC ONE POWER SUPPLY WITH SPEAKER
2.5"
6
29GM6X
0-100-110-117 & 0-100- S2) 270 VCT @ 0.2A CCS
12
110-117 VAC 60 HZ
S4) 6.3 VAC @ 6A & 6.3
VAC @ 6A
7.5VCT @ 75A FILAMENT
PWDF13207
0-220-240VAC, 60HZ
7.5VCT @ 100A FILAMENT
PWDF13185
115/230 VAC, 50/60 HZ 7.5VCT @ 100A CCS
10.0 VCT @ 10A DUAL CCS G
DUAL 10 VCT 10A FIL FOR PP 833A'S
EI-150 X 2
10.0 VCT @ 10A E
EI-150 X
FIL XFMR FOR 810'S, 813'S OR SINGLE 833A
1.5
10.0 VCT @ 15A CCS R
EI-125 X
1.25"
11.8 VAC 180-1000 HZ PRIMARY
10.0 VCT @ 17.5A
3CX5000A FILAMENT TRANSFORMER
10.0 VCT @ 20A CCS G
5
2
2
29GM6
EI-150 X 2
5
EI-150 X 2
5
10.5 VCT @ 140A CCS M
A-0274/ C-
FILAMENT TRANSFORMER, 4CX20000A/8990
CORE
1000 VAC @ 1.0A CCS
A-0393/ C-
PLATE TRANSFORMER
CORE
1000 VAC @ 1.75A CCS K
PLATE TRANSFORMER
A-274 CCORE
1100 VAC @ 1.2A CCS I
A-274 C-
ADVERTISED UNIT
CORE
1100 VAC @ 1.5A CCS I
A-274 C-
PLATE TRANSFORMER
CORE
1100 VAC @ 2.8A ICAS I
A-0459/ C-
ADVERTISED UNIT
CORE
1100 VAC @ 600 MA CCS H
A-0016/ C-
BERKSHIRE P/N 6181
CORE
1171 VAC @ 1.0A CCS G
B-0393/ C-
PLATE TRANSFORMER
CORE
1175 VAC @ 3.5A CCS N
A-0518/ C-
PLATE TRANSFORMER
CORE
1200 VAC @ 0.5A CCS & FIL
A-393 C-
WITH 6.3 VCT @ 16A FILAMENT WINDING
CORE
1250 VAC @ 1.5A CCS G
A-0480/ C-
PLATE TRANSFORMER
CORE
13.5 VCT @ 3A CCS N
EI-125 X
1.25
13.5 VCT @ 5A & 18 VAC @ 2A
EI-137 X
3CX800A7 FIL & CONTROL XFMR (3 TUBES)
1.375
10
115/230 VAC 60 HZ
S1) 10.0 VCT @ 10A CCS
1PH
S2) 10.0 VCT @ 10A CCS
0-105-117 VAC 60 Hz 1 S1) 10.0 VCT @ 10A CCS
PH
1 PH
S1) 10.0 VCT @ 17.5A
CCS
115/230 VAC 60 HZ
1PH
10
230 VAC 60 HZ 1 PH
10
120/240 VAC 60 Hz
10
10
10
120/240 VAC 60 HZ 1
PH
CCS
S1) 1000 VAC @ 1.0A
CCS
S1) 1100 VAC @ 1.2A
CCS
1100 VAC @ 1.5A CCS
120/240 VAC 60 HZ 1
S1) 1100 VAC @ 2.8A
PH
ICAS
117/234 VAC 60 HZ 1
S1) 1100 VAC @ 600 MA
PH
CC
115/230 VAC 60 HZ 1
S1) 1171 VAC @ 1.0A
PH
CCS
0-220-240 VAC 60 HZ 1 S1) 1175 VAC @ 3.5A
PH
8
10
S1) 10.0 VCT @ 20A CCS 10
0-208-220-230-240-250 S1) 10.5 VCT @ 140A
VAC 60 HZ 1 PH
10
S1) 10.0 VCT @ 15A CCS 4
1PH
115 VAC 60 HZ 1 PH
10
115/230 VAC 60 HZ
10
10
7.5 VCT @ 75A CCS
CCS
37
23
37
37
37
40
17
23
66
S1) 1200 VAC @ 0.5A
10
115 VAC 60 HZ 1 PH
CCS
23
10
4
5
115/230 VAC 60 HZ
PH
S1) 1250 VAC @ 1.5A
CCS
S1) 13.5 VCT @ 3A CCS
0-210-220-230-240-250 S1) 13.5 VAC @ 5A CCS
VAC 60 HZ 1 PH
S2) 18 VAC @ 2A CCS
46
4
6
25/31
3/1/22, 12:09 PM
Style
Description
Hammond
(see
Part Number Core
above)
13.5 VCT @ 5A G
EI-137 X
3CX800A7 FILAMENT TRANSFORMER (3 TUBES)
1.375
1300/1175/1050/925V @ 2A CCS
A-0480/ C-
1296 MHZ EME AMP POWER SUPPLY XFMR
CORE
14 VAC @ 100A CCS F
15 VAC @ 25A CCS OR 35A ICAS
FOR 13.8 VDC REGULATED POWER SUPPLY
4
Approx.
Weight
Primary
115/230 VAC 60 HZ 1
PH
10
34 VAC 60 HZ 1 PH
A-0203/ CCORE
10
110/220 VAC 60 HZ 1
PH
EI-162 X 2
2
115 VAC 60 HZ 1 PH
2
120 VAC 60 HZ 1 PH
15.0 VCT @ 15A CCS D
EI-175 X
3CX10000B7 FILAMENT TRANSFORMER
1.75
15.0 VCT @ 15A CCS SP LO-PRO
EI-150 X 2"
LO-PROFILE FILAMENT TRANSFORMER
29GAM6X
1500 VAC @ 0.5A & 7 VCT @ 8A
A-393 C-
POWER XFMR FOR DUAL 572B LINEAR AMP
CORE
4
0-115-120-125-130
VAC 60 HZ 1 PH
Secondary
(lbs)
S1) 13.5 VCT @ 5A CCS
6
S1) 0-925-1050-1175-1300
VAC @ 2.0A CCS
46
S1) 14 VAC @ 100A CCS 30
S1) 15 VAC @ 25A CCS
OR 35A ICAS
15
S1) 15.0 VCT @ 15A CCS 12
S1) 15.0 VCT @ 15A CCS 10
S1) 1500 VAC @ 0.5A
10
120 VAC 60 HZ 1 PH
CCS
23
S2) 7.0 VCT @ 8A CCS
S1) 1500 VAC @ 0.5A
1500 VAC @ 0.5A CCS & S/B/F
W/FIL, SCREEN & BIAS VOLTAGE SECONDARIES
A-0393/ CCORE
1500 VAC @ 1.0A CCS
A-0274/ C-
PLATE TRANSFORMER
CORE
10
120/240 VAC 60 HZ 1
PH
CCS
S2) 300 VAC @ 0.1A CCS
23
1500 VAC @ 1.0A CCS
PLATE TRANSFORMER
PWDP13100 EI
1600 VAC @ 0.5A CCS H
A-0393/ C-
PLATE TRANSFORMER
CORE
1600 VAC @ 1.5A CCS N
PLATE TRANSFORMER
A-480 CCORE
1650/1515/1375V @ 1.2A CCS K
FOR 2000 VOLT SUPPLY IN ARRL HANDBOOK
PWDP13078
A-0480/ CCORE
1770 VAC @ 2.0A CCS
A-0518/ C-
PLATE TRANSFORMER
CORE
18 VAC @ 25A CCS OR 35A ICAS
EI-162 X 2
18/16 VAC @ 100A CCS A
A-0274/ C-
LV POWER XFMR WITH HI/LO PRIMARY TAPS
CORE
1800 VAC & 1.5A CCS LV & FIL
PLATE XFMR WITH LV & FILAMENT WINDINGS
A-0518/ CCORE
10
4
0-220-240 VAC 60 HZ 1 S1) 1500 VAC @ 1.0A
PH
CCS
PH
CCS
117/234 VAC 60 HZ 1
S1) 1600 VAC @ 0.5A
PH
CCS
10
0-220-240 VAC 60 HZ
S1) 0-1600 VAC @ 1.5A
CCS
10
234 VAC 60 HZ 1 PH
10
10
0-1375-1515-1650 VAC @
1.2A CCS
0-230-240-250 VAC 60 S1) 1770 VAC @ 2.0A
HZ 1 PH
2
115 VAC 60 HZ 1 PH
10
110 VAC 60 HZ 1 PH
CCS
S1) 18 VAC @ 25A CCS
OR 35A ICAS
0-16-18 VAC @ 100A CC
37
45
23
46
46
66
15
37
S1) 1800 VAC @ 1.5A
10
240 VAC 60 HZ 1 PH
CCS
66
S2) 500 VCT @ 0.1A CCS
S3) 6.3 VCT @ 12A CCS
1800 VAC @ 0.6A & 5 VCT @15A
A-0274/ C-
PLATE & FIL XFMR TRANSFORMER
CORE
1800 VAC @ 1.5A CCS K
A-0480/ C-
PLATE TRANSFORMER
CORE
1800 VAC @ 1A CCS G
A-0274/ C-
PLATE TRANSFORMER
CORE
1800 VAC @ 2A CCS KN
A-0518/ C-
PLATE TRANSFORMER
CORE
1800 VCT @ 3A CCS
A-525 CCORE
1800/1200 VAC @ 0.5A CCS
A-0393/ C-
PLATE TRANSFORMER
CORE
1800/1600/1500V @ 1.5A CCS N
PLATE TRANSFORMER WITH 2 SEC TAPS
A-0480/ CCORE
S1) 1800 VAC @ 0.6A
10
117 VAC 60 HZ 1 PH
CCS
37
10
10
10
10
230 VAC 60 HZ 1 PH
115/230 VAC 60 HZ 1
PH
HZ 1 PH
S1) 1800 VAC @ 1.5A
CCS
46
S1) 1800 VAC @ 1A CCS 37
1800 VAC @ 2A CCS
0-115 & 0-115 VAC 60
0-900-1800 VCT @ 3.0A
HZ
CCS
0-1200-1800 VAC @ 0.5A
10
120 VAC 60 HZ 1 PH
10
0-220-240 VAC 60 HZ 1 S1) 0-1500-1600-1800
PH
VAC @ 1.5A CCS
CCS
66
86
23
46
S1)1800VAC @ 175 MA
1800VCT @ 175 MA
PWDP13048 EI CORE
120VAC, 60 HZ
S2) 560 VAC @ 800 MA
S3) 5V @ 2A
S4) 5V @ 4A
26/31
3/1/22, 12:09 PM
Style
Description
Hammond
(see
Part Number Core
above)
19/18/17/16/15 VAC @ 30A CCS
A-16 C-
WITH 115 VAC VCB PRIMARY TAPS
CORE
2.5 VCT @ 10A B (15 KV INS)
EI-150 X
PR 866A RECTIFIER FILAMENT TRANSFORMER
1.5
2000 VAC @ 0.5A CCS N
A-0274/ C-
PLATE TRANSFORMER
CORE
2000 VAC @ 1.0A CCS I
PLATE TRANSFORMER
A-0480/ CCORE
2000 VAC @ 1.0A CCS N
A-0480/ C-
PLATE TRANSFORMER
CORE
2000 VAC @ 1.0A ICAS J
A-0274/ C-
3CX800A7 PLATE TRANSFORMER
CORE
A-0480/ C-
2000 VAC @ 1.5 AMP CCS
CORE
2000 VAC @ 2A CCS N
A-518 C-
PLATE TRANSFORMER
CORE
2000 VAC @ 2.5A CCS
PLATE TRANSFORMER
PWDP13059 EI CORE
2000 VAC @ 3.0A CCS N
A-525 C-
PLATE TRANSFORMER
CORE
2000 VAC @ 500 MA CCS G
A-0393/ C-
HIGH VOLTAGE TRANSFORMER
CORE
2000 VCT @ 0.5A CCS L
PLATE TRANSFORMER FOR FWB
A-0274/ CCORE
2000/1300 VAC @ 3.0A CCS N
A-0525/ C-
PLATE TRANSFORMER WITH SEC TAP
CORE
2250/2000/1500 VAC @ 1A CCS
A-480 C-
PLATE TRANSFORMER
CORE
2300 VCT @ 0.55A CCS D
A-274 C-
PLATE TRANSFORMER
CORE
2300 VCT @ 2.0A CCS
PLATE TRANSFORMER
PWDP13190 EI
2350/1800/1700 VAC @ 1.0A CS
A-0480/ C-
PLATE TRANSFORMER
CORE
24 VCT @ 25A CCS
A-16 C-
LOW VOLTAGE POWER TRANSFORMER
CORE
2400 VAC @ .4A & 5 VCT @ 15A
PLATE & FIL XFMR FOR SINGLE 3-500Z
PWDP13004
PLATE TRANSFORMER
29GAM6X
A-0393/ C-
2400 VAC @ 0.5A CCS
2400 VAC @ 1.0A CCS I
EI-162 X 3"
CORE
PWDP13209
A-0480/ CCORE
10
5
10
10
10
Approx.
Weight
Primary
Secondary
115 VAC 60 HZ WITH 4 S1) 19/18/17/16/15 VAC @
CB TAPS
115 VAC 60 HZ 1 PH
PH
120/240 VAC 60 HZ 1
PH
30A CCS
2.5 VCT @ 10A CCS (15
KVDC TEST)
2000 VAC @ 1.0A CCS
46
0-220-240 VAC 60 HZ 1 S1) 2000 VAC @ 1.0A
10
220 VAC 60 HZ 1 PH
2000 VAC @ 1.0A CCS
10
230 VAC 60 HZ 1PH
10
10
10
10
10
2000 VAC @ 1.5 AMP
CCS
CCS
240 VAC 60 HZ 1 PH
2000 VAC @ 2.5A CCS
84
2000 VAC @ 3.0A CCS
86
PH
115/230 VAC 60 HZ 1
PH
240 VAC 60 HZ 1 PH
2000 VCT @ 0.5A CCS
0-220-240 VAC 60 HZ 1 0-1300-2000 VAC @ 3.0A
PH
CCS
0-220-240 VAC 60 HZ 1 0-1500-2000-2250 VAC @
37
86
46
PH
1.0A CCS
10
120 VAC 60 HZ 1 PH
2300 VCT @ 550 MA CCS 37
2
220 VAC 60 HZ 1 PH
2300 VCT @ 2.0A CCS
10
0-230-240-250 VAC 60 0-1700-1800-2350 VAC @
HZ 1 PH
1.0A CCS
10
115 VAC 60 HZ 1 PH
24 VCT @ 25A CCS
4
117 VAC 60 HZ 1 PH
85
46
17
S1) 2400 VAC @ 0.4A
ICAS
21
10
10
120/240 VAC 60 HZ
S1) 2400 VAC @ 0.5A
1PH
CCS
120/240 VAC 60 HZ 1
S1) 2400 VAC C.T. @ 1.0A
PH
CCS
A-0480/ C-
PLATE XFMR FOR PAIR OF 3-500Z'S W/TB'S
CORE
2400 VAC @ 2.0A CCS N
A-0518/ C-
ADVERTISED UNIT
CORE
2400 VCT @ .5A & 5 VCT @ 15A
EI-162 X 3"
4
29GAM6X
117 VAC 60 HZ 1 PH
A-0393/ C-
120/240 VAC 60 HZ
S1) 2400 VCT @ 0.5A
1PH
CCS
10
10
10
10
10
110/220 VAC 60 HZ 1
PH
CCS
S2) 5.0 VCT @ 45A CCS
0-220-240 VAC @ 60
S1) 2400 VAC @ 1.5A
HZ 1 PH
ICAS
0-220-240 VAC 60 Hz
23
46
S1) 2400 VAC @ 1.5A
2400 VAC @ 1.5A ICAS N
CORE
66
2000 VAC @ 500 MA CCS 23
CORE
A-0518/ C-
46
S1) 2000 VAC @ 2.0A
WITH 5.0 VCT @ 45A CCS FILAMENT WINDING
2400/1800 VAC @ 1.5A CCS N
37
PH
A-0518/ C-
CORE
46
220/240 VAC 60 HZ 1
2400 VAC @ 1.5A CCS & FIL F
2400 VCT @ 0.5A CCS
8
37
CCS
2
17
2000 VAC @ 0.5A CCS
PH
10
(lbs)
S1) 2400 VAC @ 2.0A
CCS
66
46
66
S1) 2400 VCT @ 0.5A
ICAS
21
0-220-240 VAC 60 HZ
S1) 0-1800-2400 VAC @
1.5A CCS
23
66
27/31
3/1/22, 12:09 PM
Style
Description
Hammond
(see
Part Number Core
above)
2400/1800 VAC @ 1.5A ICAS G
A-0480/ C-
CORE
2400/1800 VAC @ 1.5A ICAS N
A-0480/ C-
CORE
A-0518/ C-
2400/1800 VAC @ 2.0A CCS N
CORE
A-0525/ C-
2400/2000 VAC @ 3A CCS
CORE
2500 VAC @ 0.3A CCS L
A-0393/ C-
PLATE TRANSFORMER
CORE
2500 VAC @ 0.5A ICAS D
A-0393/ C-
PLATE TRANSFORMER
CORE
2500 VAC @ 1.0A CCS D
A-480 C-
PLATE TRANSFORMER
CORE
2500 VAC @ 1.0A CCS N
PLATE TRANSFORMER
A-0480/ CCORE
2500 VAC @ 1.5A CCS H
A-518/C C-
PLATE TRANSFORMER WITH 117/234 VAC PRI
CORE
2500 VAC @ 1.5A CCS N
A-518/C C-
PLATE TRANSFORMER
CORE
2500 VCT @ 1.5A CCS N
A-518/C C-
PLATE TRANSFORMER
CORE
2500 VCT @ 2.5A CCS N
PLATE TRANSFORMER
FOR FWB RECTIFIER
CORE
2500/1750 VAC @ 0.8A CCS G
A-0274/ C-
PLATE TRANSFORMER
CORE
2600 VAC @ 1.5A CCS N
A-0518/ C-
PLATE XFMR FOR 3-4 EA 3-500Z (3250 VDC)
CORE
2600/2400/1800 VAC @ 2A CCS
PLATE XFMR FOR 4 EA 3-500Z'S
A-0525/ CCORE
2650/1800 VAC @ 1.5A CCS N
A-0518/ C-
PLATE XFMR FOR 3-4 EA 3-500Z (3300 VDC)
CORE
EI-212 X 4
2800/2000 VAC @ 1.0A CCS
A-0480/ C-
PLATE TRANSFORMER
CORE
2800/2700/2600 VAC @ 1.5A ICAS
PLATE TRANSFORMER
PWDP13182 EI
2800/2400 VAC @ 2.5A CCS N
PLATE TRANSFORMER
A-0525/ CPWDP13077
CORE
2850/1750 VAC @ 1.5A ICAS G
A-0480/ C-
PLATE TRANSFORMER
CORE
2850/2150/1450V @ 1.5A ICAS
A-0480/ C-
SPECIAL FOR Q-PRODUCTS WITH EXTRA TAP
CORE
290 VAC @ 0.1A CCS N
400 VDC 100 MA DC SCREEN SUPPLY XFMR
EI-125 X
1.25
3000 VAC @ 1.0A CCS N
A-0518/ C-
PLATE TRANSFORMER
CORE
3000 VAC @ 1.5A CCS HI/LO
PRI LO TAP TO PROVIDE 2000 VAC
10
Weight
Primary
A-518
3000 VAC @ 2 AMP CCS
A-0525/ C-
WITH 2650 VAC TAP & 220-230-240-250V PRI
CORE
3000/1800 VAC @ 1.0A CCS N
A-0518/ C-
PLATE TRANSFORMER WITH HI/LO SEC TAPS
CORE
3000/2000 VCT @ 0.35A CCS
SPECIAL FOR C&N SERVICES
A-393 CCORE
Secondary
115/230 VAC @ 60 HZ S1) 0-1800-2400 VAC @
1 PH
1.5A ICAS
220/240 VAC @ 60 HZ S1) 0-1800-2400 VAC @
1 PH
1.5A ICAS
0-220-240 VAC 60 HZ 1 0-1800-2400 VAC @ 2.0A
PH
CCS
0-2000-2400 VAC @ 3.0A
10
0-220-240 VAC 60 HZ
10
240 VAC 60 HZ 1 PH
10
120 VAC 60 HZ 1 PH
10
120 VAC 60 HZ 1 PH
10
0-220-240 VAC 60 HZ 1 S1) 2500 VAC @ 1.0A
PH
CCS
10
10
10
10
10
10
10
10
2
10
CCS
S1) 2500 VAC @ 0.3A
CCS
S1) 2500 VAC @ 500 MA
ICAS
S1) 2500 VAC @ 1.0A
CCS
117/234 VAC 60 HZ 1
S1) 2500 VAC @ 1.5A
PH
CCS
0-220-240 VAC 60 HZ 1 S1) 2500 VAC @ 1.5A
PH
CCS
PH
120/240 VAC, 60 HZ
A-0393/ C-
PLATE TRANSFORMER
10
PWDP13228
2500 VCT @ 400 MA CCS B
2800 VCT @ 400 MA CCS
10
Approx.
115 VAC 60 HZ 1 PH
CCS
S1) 2500 VCT @ 400 MA
CCS (FWB)
S1) 0-1750-2500 VAC @
PH
0.8A CCS
0-220-240 VAC 60 HZ 1 S1) 2600 VAC @ 1.5A
CCS
0-220-240 VAC 60 HZ 1 0-1800-2650 VAC @ 1.5A
PH
CCS
120/240 VAC 60 HZ 1
S1) 2800 VCT @ 400 MA
PH
CCS
0-220-240 VAC 60 HZ 1 S1) 2800 VAC @ 1.0A
PH
CCS
10
10
10
10
10
10
86
23
23
46
46
66
66
66
23
37
66
38
46
1.5A ICAS
115/230 VAC 60 HZ 1
S1) 0-1750-2850 VAC @
PH
1.5A ICAS
0-220-240 VAC 60 HZ 1 S1) 0-1450-2150-2850
PH
66
0-2600-2700-2800 VAC @
0-220-240 VAC 60 HZ 1 S1) 0-2400-2800 VAC @
PH
2.5A CCS
4
66
0-220-230-240 VAC 60 0-1800-2400-2600 VAC @
86
Hz
2A CCS
0-240 VAC 60 HZ 1 PH
10
46
CCS
2
10
46
S1) 2500 VAC @ 2.5A
115/230 VAC 60 HZ 1
PH
(lbs)
VAC @ 1.5 AMP ICAS
86
46
46
S1) 290 VAC @ 0.1A CCS 4
PH
0-220-240 VAC 60 HZ 1 S1) 3000 VAC @ 1.0A
PH
CCS
220 VAC 60 HZ WITH
3000/2000 VAC @ 1.5
HI/LO TAPS
AMP CCS
0-220-230-240-250
S1) 0-2650-3000 VAC @ 2
VAC 60 HZ
AMPS CCS OR 3A ICAS
0-220-240 VAC 60 HZ 1 S1) 0-1800-3000 VAC @
PH
1.0A CCS
120 VAC 60 HZ 1 PH
1500-1000-0-1000-1500
VAC @ 0.35A CCS
66
66
86
66
23
28/31
3/1/22, 12:09 PM
Style
Description
Hammond
Part Number Core
3000/2000 VCT @ 0.5A CCS
A-274 C-
CORE
3000/2400 VAC @ 1.5A CCS JKL
A-518 C-
PLATE TRANSFORMER
CORE
3000/2500/2000 VAC @ 1A CCS
A-0518/ C-
PLATE TRANSFORMER
CORE
3000/2800/2600V @ 1.5A CS JL
PLATE TRANSFORMER
A-518 CCORE
3100/2700/2300V @ 1.5A CCS
PLATE TRANSFORMER
PWDP13104
A-518 CCORE
PROP PITCH PWR XFMR WITH 220 VAC 50/60HZ
2.5"
29GM6X
3200 VAC @ 1.0A CCS SP
A-0518/ C-
PLATE XFMR FOR 4000 VDC @ 0.8A FWB CAP-I
CORE
3200 VAC @ 1.5A CCS JK
A-0518/ C-
PLATE TRANSFORMER
CORE
EI-162 X 3
A-0518/ C-
CCS PLATE XFMR WITH SCREW LUGS ON COIL
CORE
PWDP13035
A-0525/ CCORE
3500 VAC @ 1.0A CCS
A-518 C-
PLATE TRANSFORMER
CORE
3500 VAC @ 1.0A ICAS G
A-0480/ C-
ADVERTISED UNIT
CORE
3500 VAC @ 1.5A CCS JK
A-0518/ C-
PLATE TRANSFORMER
CORE
3500 VAC @ 1.5A ICAS N
A-0518/ C-
PLATE TRANSFORMER
CORE
3500/2000 VAC @ 1.5A CCS JK
A-0518/ C-
PLATE TRANSFORMER
CORE
3500/3200/3000 VAC @ 1A ICAS
A-0480/ C-
PLATE TRANSFORMER
CORE
3600 VAC @ 1.0 AMP CCS G
A-0518/ C-
WITH TAPS AT 1900-2000-2600 VAC
CORE
3600 VAC @ 1.5A ICAS N
A-0518/ C-
PLATE TRANSFORMER
CORE
3600 VAC @ 2.0A ICAS J
A-0525/ C-
PLATE TRANSFORMER
CORE
A-518 C-
3750 VAC @ 1.0A CCS G
CORE
3800/3500/2800V @ 1.0A CCS N
A-0518/ C-
PLATE TRANSFORMER
CORE
PLATE TRANSFORMER
3904 VAC @ 1.6A CCS
PLATE TRANSFORMER
PWDP13196 EI
PWDP13214
A-0525/ CCORE
4000 VAC @ 1.0A CCS N
A-0518/ C-
PLATE TRANSFORMER
CORE
4000 VAC @ 500 MA CCS
120 VAC 60 HZ 1 PH
10
10
10
10
2
10
10
VAC @ 0.5A CCS
0-220-230-240 VAC 60 0-2400-3000 VAC @ 1.5A
HZ 1 PH
CCS
115/230 VAC 60 HZ 1
S1) 0-2000-2500-3000
PH
VAC @ 1.0 AMP CCS
Weight
(lbs)
37
66
66
0-220-240 VAC 60 HZ 1 0-2600-2800-3000 VAC @
66
PH
1.5A CCS
0-220-230-240 VAC 60 0-2300-2700-3100 VAC @
HZ 1 PH
1.5A CCS
220 VAC 50/60 HZ 1
S1) 0-24-28-32 VAC @
PH
15A CCS
0-100-110-120 VAC 60 S1) 3200 VAC @ 1.0A
HZ 1 PH
CCS
0-220-230 VAC 60 HZ 1 S1) 3200 VAC @ 1.5A
PH
CCS
66
18
66
66
4
117 VAC 60 HZ 1 PH
ICAS
21
3200/2800/2400 VAC @ 1.3A CS
3904 VAC @ 1.6A CCS
10
Secondary
S1) 3200 VCT @ 0.4A
3200 VCT @ .4A & 5 VCT @ 15A
3300/2300 VAC @ 2.0A CCS KL
PLATE TRANSFORMER
Primary
EI-162 X
32/28/24 VAC @ 15A CCS
Approx.
(see
above)
A-0480/ CCORE
4000 VCT @ 1.0A CCS N
A-0518/ C-
PLATE TRANSFORMER
CORE
10
0-220-240 VAC 60 HZ 1 S1) 0-2400-2800-3200
PH
VAC @ 1.3A CCS
10
0-230-240 VAC 60 HZ 1 S1) 0-2300-3300 VAC @
PH
2.0A CCS
10
220 VAC 60 HZ 1PH
10
10
10
10
10
10
10
10
10
10
S1) 3500 VAC @ 1.0A
PH
ICAS
0-220-230 VAC 60 HZ 1 S1) 3500 VAC @ 1.5A
PH
PH
PH
1.5A CCS
0-230-240 VAC 60 HZ 1 0-3000-3200-3500 VAC @
PH
115/230 VAC 60 HZ 1
PH
1.0A ICAS
PH
220 VAC 60 HZ 1 PH
3600 VAC @ 1.0 AMP
ICAS
S1) 3600 VAC @ 2.0A
ICAS
S1) 3750 VAC @ 1.0A
PH
CCS
0-220-240 VAC 60 HZ 1 S1) 0-2800-3500-3800
VAC @ 1.0A CCS
S1) 0-3904 VAC @ 1.6A
CCS
CCS
0-220-240 VAC 60 HZ 1 S1) 4000 VAC @ 1.0A
PH
CCS
230 VAC 50/60 HZ 1
S1) 4000 VAC @ 500 MA
PH
CCS
0-220-240 VAC 60 HZ 1 S1) 4000 VCT @ 1.0A
PH
66
46
66
66
66
46
66
CCS
115/230 VAC 60 HZ 1
PH
86
S1) 0-1900-2000-2600-
0-220-240 VAC 60 HZ 1 S1) 3600 VAC @ 1.5A
ICAS
0-220-230 VAC 60 HZ 1 S1) 0-2000-3500 VAC @
10
10
CCS
0-220-240 VAC 60 HZ 1 S1) 3500 VAC @ 1.5A
10
CCS
115/230 VAC 60 HZ 1
4
10
S1) 3500 VAC @ 1.0A
66
CCS
66
86
66
66
128
86
66
46
66
29/31
3/1/22, 12:09 PM
Style
Description
Hammond
(see
Part Number Core
above)
4200 VAC @ 2.0A ICAS F
A-0525/ C-
PLATE TRANSFORMER
CORE
4200 VCT @ 0.6A CCS I
A-0480/ C-
PLATE TRANSFORMER
CORE
4600/4000 VAC @ 1.5A ICAS K
A-0518/ C-
PLATE TRANSFORMER
CORE
5.0 VCT @ 10.5 AMP CCS D
10
10
10
Approx.
Weight
Primary
Secondary
110/220 VAC 60 HZ 1
S1) 4200 VAC @ 2.0A
PH
ICAS
120/240 VAC 60 HZ 1
S1) 4200 VCT @ 0.6A
PH
CCS
230 VAC 60 HZ 1 PH
I-125 X 1.25 2
120 VAC 60 HZ 1 PH
5.0 VCT @ 15A CCS F
FILAMENT TRANSFORMER (3-500Z OR 4-400A)
EI-137 X
1.375
110/220 VAC 60 HZ 1
PH
5.0 VCT @ 20A CCS JKL
EI-175 X
RECT FIL XFMR (10 KVDC)
1.75
5.0 VCT @ 20A CCS L
EI-150 X
10 KVDC INSULATION
1.75
5.0 VCT @ 30A & 12 VAC @ 2A
EI-150 X 2
5.0 VCT @ 30A G
EI-150 X
ADVERTISED UNIT (FIL XFMR PAIR 3-500Z'S)
1.5
5.0 VCT @ 30A W/BIAS G
EI-150 X
FIL XFMR FOR PR 3-500Z'S, WITH 90V BIAS
1.5
5.0 VCT @ 4A 10 KVDC FIL
EI-087 X
RECT FIL XFMR FOR 2 EA 816'S IN SERIES
.875
120 VAC 60 HZ PRIMARY (SINGLE 8877)
5.0 VCT @ 60A CCS SP
SPECIAL +5,0,-5,110,125 VAC TAPPED PRI
5.0 VCT @ 60A W/B&F H
90 VAC @ 0.2A BIAS & 12.6 VAC @ 1A LV
2
4
4
4
1
4
EI-175 X 2
5
EI-150 X 5"
FITS UNDER 4" CHASSIS, SPCL TERRY GAISER
29GAM6X
EI-175 X 3
FILAMENT TRANSFORMER FOR 6 EA 3-500Z'S
2
EI-175 X 2
5.0 VCT @ 90A CCS LO PROFILE
5.0 VCT @ 90A W/BIAS G
4
4
4
5.5 VCT @ 17.5A STP
EI-150 X
FIL XFMR WITH SPECIAL TAPPED PRIMARY
1.5
5000 VCT @ 500MA CCS I
A-480 C-
GENERAL PURPOSE PLATE XFMR FOR FWCT
CORE
5000/4500 VAC @ 1.5A ICAS K
4500 VDC OR 4000 VDC @ 1.5A ICAS
A-525/C C10
CORE
550 VCT @ 0.3A CCS D
EI-150 X
POWER TRANSFORMER
1.5
5600 VCT @ 1.5A CCS SP
A-0525/ C-
FWCT PLATE TRANSFORMER
CORE
5800 VCT @ 1.0A CCS FWCT G
A-518 C-
2.9 KVA FWCT PLATE TRANSFORMER
CORE
6.3 VCT @ 10A CCS G
EI-137 X
1.375
6.3 VCT @ 100A D
EI-162 X
3.5
6.3 VCT @ 16A & 24 VCT @ 3A
EI-150 X 2
FILAMENT & CONTROL TRANSFORMER
6.3 VCT @ 160A CCS N
3CX15000A7 FILAMENT TRANSFORMER
6.3 VCT @ 20A D
FILAMENT TRANSFORMER -- ADVERTISED UNIT
6.3 VCT @ 30A CCS (G)
PWDF13127
A-0393/ CCORE
4
10
2
10
10
4
2
5
10
EI-150 X
1.5
2
EI-150 X 2
4
6.3 VCT @ 50A CCS JKL
EI-175 X 2"
STYLE #5 WITH POTTED END BELLS
29GAM6X
5
S1) 0-4000-4600 VAC @
1.5A ICAS
S1) 5.0 VCT @ 10.5
AMPS CCS
S1) 5.0 VCT @ 15A CCS
0-220-230-240 VAC 60 S1) 5.0 VCT @ 20A CCS
HZ 1 PH
240 VAC 60 HZ 1 PH
(10 KVDC INSULATION)
5.0 VCT @ 20A CCS (10
KVDC INSULATION)
120/240 VAC 60 HZ 1
PH
S2) 12.0 VAC @ 2A CCS
115/230 VAC 60 HZ 1
PH
115/230 VAC 60 HZ 1
PH
S2) 90 VAC @ 0.2A CCS
115 VAC 60 HZ 1 PH
PR) +5,0,-5,110,125
VAC 60 HZ 1 PH
117/234 VAC 60 HZ 1
PH
0-220-230-240-250
VAC 60 HZ 1 PH
115/230 VAC 60 Hz
0-110-115-120-125
VAC 60 HZ 1 PH
120/240 VAC 60 HZ
S1) 5.0 VCT @ 4A CCS
(10 KVDC TEST)
S1) 5.0 VCT @ 60A CCS
(lbs)
86
46
66
4
6
12
9
4
8
8
2
14
14
S3) 12.6 VAC @ 1A CCS
S1) 5.0 VCT @ 90A CCS
S2) 90 VAC @ 200 MA
23
19
S1) 5.5 VCT @ 17.5A CCS 8
S1) 5000 VCT @ 500MA
CCS
46
230 VAC 60 HZ 1 PH
0-4500-5000 VAC @ 1.5A
86
ICAS
120 VAC 60 HZ 1 PH
S1) 550 VCT @ 0.3A CCS 8
0-220-240-260 VAC 60 S1) 2800-0-2800 VAC @
HZ 1 PH
1.5A CCS
115/230 VAC 60 HZ 1
S1) 5800 VCT @ 1.0A
PH
CCS FWCT
115/230 VAC 60 HZ 1
PH
S1) 6.3 VCT @ 10A CCS
86
66
6
120 VAC 60 HZ 1PH
S1) 6.3 VCT @ 100A CCS 24
115/230 VAC 60 HZ 1
S1) 6.3 VCT @ 16A CCS
PH
S2) 24 VCT @ 3A CCS
0-220-240 VAC 60 HZ
1PH
120 VAC 60 HZ 1 PH
115/230 VAC 60 HZ 1
PH
HZ 1 PH
10
6.3 VCT @ 160A CCS
23
6.3 VCT @ 20A CCS
8
S1) 6.3 VCT @ 30A CCS
10
S1) 6.3 VCT @ 50A CCS
14
30/31
3/1/22, 12:09 PM
Style
(see
Hammond
Description
Part Number Core
6000 VCT @ 0.8A CCS G
PLATE TRANSFORMER FOR FWCT RECTIFIER
A-0480/ CCORE
6000/5000/4000/3000V @ 0.9A
A-0525/ C-
CCS PLATE TRANSFORMER
CORE
7.0 VCT @ 160A CCS I
A-0274/ C-
DUAL 3CX6000A7/YU-148 FILAMENT XFMR
CORE
7.0 VCT @ 85A N
YU-148 FILAMENT TRANSFORMER
PWDF13050 EI-162 X 3
7.5 VCT @ 100A CCS D
EI-162 X
3.5
7.5 VCT @ 100A G
PWDF13185
7.5 VCT @ 21A ABD
4-1000A OR 3-1000Z FILAMENT TRANSFORMER
7.5 VCT @ 21A E
7.5 VCT @ 21A LO PROFILE
7.5 VCT @ 24A & 5.0 VCT @ 8A
FIL XFMR FOR 2 EA #450TL & 1 EA #254
EI-162 X
3.5
10
46
10
10
2
2
2
5
EI-125 X 2
4
EI-175 X 2
4
EI-175 X 2"
FILAMENT TRANSFORMER WITH SPECIAL PRI
29GAM6X
2
5
PWDF13081 EI-162 X 2
2
EI-162 X 3
2
EI-162 X 3
2
7.5 VCT @ 75A G
ADVERTISED UNIT
7.5 VCT @ 75A N
220/240 VAC TAPPED PRIMARY
120/240 VAC DUAL PRIMARY
(lbs)
S1) 6000 VCT @ 0.8A
CCS (FWCT RECTIFIER)
EI-150 X 2
7.5 VCT @ 42A CCS SP
7.5 VCT @ 110A CCS FILAMENT TRANSFORMER
Secondary
115/230 VAC 60 HZ 1
PH
5
2.5"
29GAM6
ADERVTISED UNIT
Primary
EI-150 X 2
LO PROFILE SPECIAL PRIMARY FOR T. GAISER
7.5 VCT @ 55A G
above)
EI-150 X
7.5 VCT @ 42A CCS LP SP
PWDF13038
EI-162 X
3.5
7.5/6.3 VCT @ 160A CCS D
A-0274/ C-
DUAL VOLTAGE FIL XFMR WITH 120V PRI TAPS
CORE
7.5/6.3 VCT @ 160A CCS L
A-0274/ C-
DUAL VOLTAGE FIL XFMR WITH 240V PRI TAPS
CORE
7.5/6.3 VCT @ 26A & 26V @ 1A
EI-175 X
SPECIAL 3CX1200 & YU-121 FIL XFMR
1.75
7000 VCT @ 0.9A CCS N
A-0525/ C-
4900 VDC @ 0.9A FWCT 4-1000A PLATE XFMR
CORE
850 VAC @ 1.0A CCS D
A-0393/ C-
120 VAC PRIMARY & WIRE LEADS
CORE
Approx.
Weight
2
10
10
4
0-220-240 VAC 60 HZ 1 S1) 0-3000-4000-5000PH
120/240 VAC 60 HZ 1
PH
PH
120 VAC 60 HZ 1PH
1PH
0-110-115-120 VAC 60
HZ 1 PH
PH
10
S1) 7.0 VCT @ 85A CCS
0-115-125 VAC 60 HZ 1
PH
0-228-230-232 50 HZ 1
PH
115/230 VAC 60 HZ 1
PH
115/230 VAC 60 HZ 1
PH
PH
120/240 VAC 60 HZ 1
PH
0-120-143 VAC 60 HZ 1
PH
0-240-286 VAC 60 HZ 1
PH
S1) 7.5 VCT @ 100A CCS 24
S1) 7.5 VCT @ 21A CCS
10
10
S2) 5.0 VCT @ 8A CCS
PH
14
12
14
S1) 7.5 VCT @ 55A CCS
15
S1) 7.5 VCT @ 75A CCS
21
21
S1) 7.5 VCT @ 110A CCS 24
7.5/6.3 VCT @ 160A CCS 37
12
S2) 26 VAC @ 1A CCS
0-220-240 VAC 60 HZ 1 S1) 7000 VCT @ 0.9A
PR) 120 VAC 60 HZ 1
7
PR)
S1) 7.5/6.3 VCT @ 26A
+45,0,220,228,236,244 CCS
PH
21
0-220-230-240 VAC 60 S1) 7.5 VCT @ 24A CCS
HZ 1 PH
86
S1) 7.0 VCT @ 160A CCS 37
PH
VAC 60 HZ 1 PH
10
6000 VAC @ 0.9A CCS
CCS (FWCT)
86
S1) 850 VAC @ 1.0A CCS 23
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
31/31
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hammond:
PWDP13026 PWDI13024 PWDI13158 PWDI13161
