ISDN SO Miniature SMD Interface Modules
Features
• excellent output characteristics ensure compliance with CCITT.I.430
pulse waveform template when used with recommended IC pairing
• SMD modules are designed for pick and place compatability
• excellent and consistent balance between windings
• modular design maximizes suppression effectivity and transmission
properties
• full compatibility with all common IC's
• manufactured in ISO-9001:2000, TS-16949:2002 and
ISO-14001:2001 certified facility
• fully RoHS compliant and meets lead free reflow level
J-STD-020C
• operating temperature: -40° to 85°C
• storage temperature: -40 to +125°C
Electrical Specifications @ 25°C
Turns Ratio: Bold = IC side windings
Miniature Chip SMD Modules comply with Functional Insulation Level EN60950, UL1950 and UL1459
LP
Turns
LL
CC
RCUP
RCUS
VP
(mH Min)
Ratio
(μH Max)
(pF Max)
(Ohms)
(Ohms)
(Vrms)
MUJ-100A or B-XXX
MUJ-103A or B-XXX
25
25
1:1:1: 1
1:1:2: 2
5
5
50
50
2.7
3.7
3.3
8.4
1500
1500
A or B
A or B
MUJ-105A or B-XXX
25
1:1:2.5: 2.5
5
50
5.2
10.5
1500
A or B
Basic P/N + Suffix
RCU
(Ohms)
Part Number
Schematic
Common Mode Choke
Basic P/N + Suffix
MUJ-100A-000
MUJ-100A or B-500
MUJ-100A or B-101
MUJ-100A or B-501
MUJ-100A or B-502
RCU
(Ohms)
LN
(μH)
No Choke
50
100
500
5000
RCU
(Ohms)
Basic P/N + Suffix
MUJ-103A -000
MUJ-103A or B-500
MUJ-103A or B-101
MUJ-103A or B-501
MUJ-103A or B-502
0.4
0.5
0.4
0.8
No Choke
0.5
0.6
0.6
0.9
MUJ-105A-000
MUJ-105A or B-500
MUJ-105A or B-101
MUJ-105A or B-501
MUJ-105A or B-502
No Choke
0.7
0.9
0.8
1.5
Test Conditions:
Polarity and Turns Ratio: ±1%
Inductance: 25mH minimum, line side windings in series @ 10kHz, 100mV
Leakage Inductance: Line side windings in series, IC side windings short circuited - measurement @ 100kHz, 100mV
Coupling capacitance: IC side windings in series to Line side windings in series @ 10kHz, 100mV
Common Mode Choke Inductance: 100kHz, 20mV
Schematic
Test Voltage: 1.5kV for 2 Sec. - Line side windings in series to IC side windings in series
(Without Choke)
A
Standard Packaging: Tape and Reel
IC
Line
MUJ Miniature Module
0.077
(1.96)
AMGIS
WK/YR
Part Number
0.350
(8.89)
0.504
(12.80)
0.236
(6.00)
0.031
(0.80)
0.050
(1.27)
0° - 8°
0.378 0.346
(9.60) (8.80)
Suggested
Pad Layout
0.394
(10.60)
0.350
(8.89)
1
Surface Coplanarity will be 0.004 (0.10)
Dimensions: Inches (Millimeters)
Tolerance: ±0.010 (0.25) unless specified otherwise
15
14
4
13
5
12
6
7
11
10
8
9
B
A
Line
Pins: 0.016x0.016
(0.40 x 0.40)
16
2
3
Schematics - With Choke
0.079
(2.00)
0.189
(4.80)
1
IC
Line
IC
16
5
2
3
15
14
12
4
13
4
5
12
3
6
7
11
10
13
8
9
6
7
10
9
8
1
11
15
16
2
AMGIS, LLC * 10899 Kinghurst St. Ste. 220 Houston, TX 77099
Phone: 832-775-1319 * Fax: 281-933-9067* email: sales@amgistoroids.com
Toll Free: 877-762-6447 * www.amgistoroids.com
14
Packing and Dimensions
P2 ± 0.1
A
P0 ± 0.1
D0
+ 0 .1
-0 .0
T± 0.05
D1
B0 ± 0.1
F± 0.15
W± 0.3
E± 0.1
Dimensions for carrier tape (Unit : mm)
K0 ± 0.1
A0± 0 .1
P± 0.1
A
SECTION A-A
Dimensions are in mm
Dimensions in mm
Type
MUJ
W
F
E
P2
P0
24.00
11.50
1.75
2.00
4.00
D0
D1
P
Ø1.50 Ø1.50 16.00
A0
B0
T
K0
10.20
13.55
0.35
6.55
Reel
Size
330x24
Quantity
Quantity
(Pcs/Reel) (Reel/Cased)
600
5/3000
很抱歉,暂时无法提供与“MUJ-103A-500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 600+69.68380600+8.58401
- 1200+67.474071200+8.31180
- 国内价格 香港价格
- 1+93.178931+11.47826
- 10+84.0683210+10.35597
- 25+80.6510925+9.93501
- 50+78.1392050+9.62559
- 100+75.69567100+9.32458
- 250+72.56662250+8.93913
