电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
PH-31-G
PH-31-G
    CR
    INDICATOR PANEL SPLASH PROOF GRN
PH-31-G 数据手册
Remote Current Indicator PH Series PH-25 Snap In The Remote Electrical Current Indicators provide an effective method for remote monitoring of electrical current. The remote current sensing transformer is installed around the current-carrying wire and is connected directly to the LED panel indicator. When the current exceeds the turn-on point of the sensing transformer, the LED illuminates to indicate the presence of current. Two sizes of remote current sensing transformers are available for use with either one of two types of LED indicators. The panel indicators are available with either red, green, blue, white, yellow or amber LEDs. PH-31 Splash Proof Model 19 Applications Monitor Status of Heater Elements Observe Remote Loads Indicate Phase Loss Monitor Motor Operation Model 18 (w/ Bracket) Features PART NUMBERS Indicators and Displays E Part Number PH-25-A PH-25-B PH-25-G PH-25-R PH-25-W PH-25-Y PH-31-A PH-31-B PH-31-G PH-31-R PH-31-W PH-31-Y Model 19 Model 18 MB-18 Self Powered Red, Green, Blue, White, Yellow and Amber Indicators Panel Mounting Bracket available LED Color Model 18 Turn On Model 19 Turn On Amber 3.0 AAC 2.5 AAC Blue 2.5 AAC 2.0 AAC Green 3.0 AAC 2.5 AAC Red 2.5 AAC 2.0 AAC White 2.5 AAC 2.0 AAC Yellow 2.5 AAC 2.0 AAC Amber 3.0 AAC 2.5 AAC Blue 2.5 AAC 2.0 AAC Green 3.0 AAC 2.5 AAC Red 2.5 AAC 2.0 AAC White 2.5 AAC 2.0 AAC Yellow 2.5 AAC 2.0 AAC Wire Mount Current Transformer, 7.4mm window Panel Mount Current Transformer, 14mm window Panel Mounting Bracket for Model 18 #22 AWG UL UL STYLE 1213 Specifications Model 18: 100 AAC Max, 600 VAC Max rating Model 19: 25 AAC Max, 600 VAC Max Rating 50 - 1Khz Bandwidth -100C to +850C Operating Temperature Mounting Bracket Non-Magnetic Aluminum Material Weight 0.03 LBS. Regulatory Agencies E235509 Bore Hole Size = 5/16” . .95 (24.1) .29 (7.4)DIA. 12 (304.8) NTS 1.04 (26.4) Bore Hole Size = 1/4” .16 (4.1) MAX. PANEL THICKNESS 12 (304.8) NTS .39 (9.9) DIA .46 (11.7) CURRENT LIMITING RESISTOR Model 19 Dimensions PH31 Dimensions [14] .55 .105 max. (2.7) H1 1.49 [37.8] X1 .875 (22.2) 1.37 (34.8) PH25 Mounting 4) DIA. #6 (M3.5) SCREW NOT FURNISHED .25 (6.4) WASHER .25 (6.4) .750 (19.1) 1.25 (31.08) MB-18 Dimensions #4-40 FLAT HEAD SCREW FURNISHED The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System X2 0.95 [24.1] 1.33 [33.8] 12 (304.8) NTS #20 AWG UL STYLE 1015 0.79 [28.1] [6.2] 0.25 0.19 [4.8] #4-40 INSET 0.17 DEEP 0.25 [609.6] [13.2] 0.52 Model 18 Dimensions CURRENT LIMITING RESISTOR PH25 Outline 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 80 E-mail: sales@crmagnetics.com
PH-31-G 价格&库存
很抱歉,暂时无法提供与“PH-31-G”相匹配的价格&库存,您可以联系我们找货
