Remote Current Indicator
PH Series
PH-25 Snap In
The Remote Electrical Current Indicators provide an effective method for remote monitoring of electrical current. The
remote current sensing transformer is installed around the
current-carrying wire and is connected directly to the LED
panel indicator. When the current exceeds the turn-on point
of the sensing transformer, the LED illuminates to indicate the
presence of current. Two sizes of remote current sensing
transformers are available for use with either one of two
types of LED indicators. The panel indicators are available
with either red, green, blue, white, yellow or amber LEDs.
PH-31 Splash Proof
Model 19
Applications
Monitor Status of Heater Elements
Observe Remote Loads
Indicate Phase Loss
Monitor Motor Operation
Model 18 (w/ Bracket)
Features
PART NUMBERS
Indicators and Displays
E
Part Number
PH-25-A
PH-25-B
PH-25-G
PH-25-R
PH-25-W
PH-25-Y
PH-31-A
PH-31-B
PH-31-G
PH-31-R
PH-31-W
PH-31-Y
Model 19
Model 18
MB-18
Self Powered
Red, Green, Blue, White, Yellow and Amber Indicators
Panel Mounting Bracket available
LED Color Model 18 Turn On Model 19 Turn On
Amber
3.0 AAC
2.5 AAC
Blue
2.5 AAC
2.0 AAC
Green
3.0 AAC
2.5 AAC
Red
2.5 AAC
2.0 AAC
White
2.5 AAC
2.0 AAC
Yellow
2.5 AAC
2.0 AAC
Amber
3.0 AAC
2.5 AAC
Blue
2.5 AAC
2.0 AAC
Green
3.0 AAC
2.5 AAC
Red
2.5 AAC
2.0 AAC
White
2.5 AAC
2.0 AAC
Yellow
2.5 AAC
2.0 AAC
Wire Mount Current Transformer, 7.4mm window
Panel Mount Current Transformer, 14mm window
Panel Mounting Bracket for Model 18
#22 AWG UL
UL STYLE 1213
Specifications
Model 18: 100 AAC Max, 600 VAC Max rating
Model 19: 25 AAC Max, 600 VAC Max Rating
50 - 1Khz Bandwidth
-100C to +850C Operating Temperature
Mounting Bracket Non-Magnetic Aluminum Material
Weight 0.03 LBS.
Regulatory Agencies
E235509
Bore Hole Size = 5/16”
. .95 (24.1)
.29 (7.4)DIA.
12 (304.8)
NTS
1.04 (26.4)
Bore Hole Size = 1/4”
.16 (4.1) MAX.
PANEL
THICKNESS
12 (304.8)
NTS
.39 (9.9) DIA
.46 (11.7)
CURRENT LIMITING RESISTOR
Model 19 Dimensions
PH31 Dimensions
[14]
.55
.105 max.
(2.7)
H1
1.49
[37.8]
X1
.875 (22.2)
1.37 (34.8)
PH25 Mounting
4) DIA.
#6 (M3.5) SCREW
NOT FURNISHED
.25 (6.4)
WASHER
.25 (6.4)
.750 (19.1)
1.25 (31.08)
MB-18 Dimensions
#4-40 FLAT HEAD
SCREW FURNISHED
The Professional
Energy Monitoring
Company
M N TI
ISO 9001:2008 Quality Management System
X2
0.95
[24.1]
1.33 [33.8]
12 (304.8)
NTS
#20 AWG
UL STYLE 1015
0.79
[28.1]
[6.2]
0.25
0.19
[4.8]
#4-40 INSET
0.17 DEEP
0.25 [609.6]
[13.2]
0.52
Model 18 Dimensions
PH25 Outline
3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119
Web: http://www.crmagnetics.com
80
E-mail: sales@crmagnetics.com
很抱歉,暂时无法提供与“PH-31-R”相匹配的价格&库存,您可以联系我们找货
