IS500HG
IS500HG
    TRIPPLITE
    TRANSF ISO 500W 4OUT HOSP GRADE
IS500HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Isolator Series 120V 500W UL 60601-1 MedicalGrade Isolation Transformer with 4 HospitalGrade Outlets MODEL NUMBER: IS500HG Highlights ● Complete line isolation & noise filtering ● Hospital-grade plug and receptacles ● Lowers cumulative leakage current of connected equipment to under 100 A ● Floating AC output prevents noise coupling ● TAA-compliant Package Includes Description Isolator Series UL 60601-1 Listed Medical-Grade Isolation Transformers offer line isolation and continuous noise filtering. An internal low-impedance isolation transformer component offers 100% isolation from the input AC line. Full UL 60601-1 medical-grade listing with hospital-grade plug and outlet receptacles makes Isolator medical-grade transformers ideal for protecting sensitive electronic equipment in patient-care areas. Faraday shield reduces the cumulative leakage current of the Isolator and connected equipment to levels less than 100 microamps. Removes EMI/RFI noise, utility switching transients and harmonics generated by other on-site loads. Reduces impact of utility-related surge conditions. Transformer filtering provides continuous common-mode noise rejection with no wearable parts. Reduces 6000V IEEE587 Category A & B ring wave and combination wave test surges to only 0.5V common mode. Includes four widely spaced NEMA 5-15R hospital-grade output receptacles, 10-ft. (3.05 m) power cord, hospital-grade input plug, circuit breaker overload protection, lighted power switch and rugged all-metal housing. Ships ready for placement in any industrial, medical, office or network environment. PLUG/OUTLETS: Input - NEMA 5-15P Hospital Grade; Output - 4 NEMA 5-15R Hospital Grade ELECTRICAL: 120V AC, 60 Hz, 4.2A (requires NEMA 5-15R wall receptacle). Features ● Offers line isolation and continuous noise filtering ● Internal low-impedance isolation transformer with Faraday shield offers 100% isolation from the input AC line ● Full UL 60601-1 medical-grade listing with hospital-grade plug and outlet receptacles for the protection of sensitive electronic equipment in patient-care areas ● Reduces cumulative leakage current of the Isolator and connected equipment to levels less than 100 A ● Floating AC output prevents noise coupling from noisy hospital ground circuits ● Inexpensive alternative to dedicated circuits and site electrical upgrades ● Removes EMI/RFI noise, utility switching transients, load-generated harmonics and ground loops ● Transformer filtering offers continuous common-mode noise rejection with no wearable parts ● Reduces 6000V IEEE587 Cat A & B ring wave and combination wave test surges to only 0.5V common mode ● Includes 4 widely spaced NEMA 5-15R hospital-grade output receptacles, 10-ft. (3.05 m) power cord, hospital-grade input plug, circuit breaker overload protection, lighted power switch and rugged all-metal 1/3 ● IS500HG Isolation Transformer ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States unit housing ● Ships ready for upright tower placement in any industrial, medical, office or network environment Specifications OVERVIEW UPC Code 037332115898 Efficiency 96% Let-through Voltage (Combination Wave) L-N: 250V Let-through Voltage (Ring Wave) L-N: 20V Nominal Voltage / Frequency 120 /60Hz VA / Watt Capacity 500 Transformer Type Medical-grade, low impedance transformer-based line isolation transformer L-G: 250V L-G: 20V N-G: 0.5V N-G: 0.5V INPUT Input Plug Type NEMA 5-15P-HG Total Harmonic Distortion Less than 1% Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Receptacles (4) 5-15R-HG Output Amp Capacity 4.2 ISOLATION Leakage Current Less than 100 microamps SURGE / NOISE SUPPRESSION Noise Suppression Rating 35-65 DB PHYSICAL Cooling Method Convection Form Factors Supported Tower Shipping Dimensions (hwd / in.) 8.50 x 9.00 x 11.50 Shipping Dimensions (hwd / cm) 21.59 x 22.86 x 29.21 Shipping Weight (lbs.) 23.20 Shipping Weight (kg) 10.52 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 5.750 x 6.250 x 9.250 Unit Dimensions (hwd / cm) 14.61 x 15.88 x 23.50 FEATURES & SPECIFICATIONS Over Current Protection 1 X THERMAL, 2 POLE, ROCKER STANDARDS & COMPLIANCE Product Certifications UL 60601-1 Product Compliance RoHS; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
IS500HG
- 物料型号: IS500HG - 器件简介: 这是一个医用级别的隔离变压器,提供线路隔离和持续的噪声过滤功能。它拥有一个内部低阻抗隔离变压器组件,提供100%的输入交流线路隔离。它完全符合UL 60601-1医疗级标准,配有医疗级插头和插座,适用于保护患者护理区域内的敏感电子设备。 - 引脚分配: 输入 - NEMA 5-15P医疗级;输出 - 4个NEMA 5-15R医疗级 - 参数特性: 120V AC, 60 Hz, 4.2A(需要NEMA 5-15R墙壁插座)。效率96%,输入线长10英尺(3.05米),输出容量4.2安培,泄漏电流小于100微安培。 - 功能详解: 该变压器通过法拉第屏蔽减少累积漏电流,消除电磁干扰/射频干扰噪声、公用事业开关瞬变、负载产生的谐波和接地回路。变压器过滤提供连续的共模噪声抑制,无磨损部件。它将6000V IEEE587类别A和B的环形波和组合波测试浪涌减少到仅为0.5V共模。 - 应用信息: 适用于工业、医疗、办公室或网络环境中的任何地方,准备直立塔式放置。 - 封装信息: 包括4个广泛分隔的NEMA 5-15R医疗级输出插座,10英尺(3.05米)电源线,医疗级输入插头,带有断路器过载保护的电源开关和坚固的全金属外壳。
IS500HG 价格&库存
很抱歉,暂时无法提供与“IS500HG”相匹配的价格&库存,您可以联系我们找货
