IS1000HG
IS1000HG
    TRIPPLITE
    TRANSF ISO 1000W 4OUT HOSP GRADE
IS1000HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Isolator Series 120V 1000W UL 60601-1 MedicalGrade Isolation Transformer with 4 HospitalGrade Outlets MODEL NUMBER: IS1000HG Highlights ● Complete line isolation and noise filtering ● Hospital-grade plug and receptacles ● Lowers cumulative leakage current of connected equipment to under 100 A ● Floating AC output prevents noise coupling ● TAA-compliant Package Includes Description Isolator Series UL 60601-1 Listed Medical-Grade Isolation Transformers offer line isolation and continuous noise filtering. An internal low-impedance isolation transformer component offers 100% isolation from the input AC line. Full UL 60601-1 medical-grade listing with hospital-grade plug and outlet receptacles makes Isolator medical-grade transformers ideal for protecting sensitive electronic equipment in patient-care areas. Faraday shield reduces the cumulative leakage current of the Isolator and connected equipment to levels less than 100 microamps. Removes EMI/RFI noise, utility switching transients and harmonics generated by other on-site loads. Reduces impact of utility-related surge conditions. Transformer filtering provides continuous common-mode noise rejection with no wearable parts. Reduces 6000V IEEE587 Category A & B ring wave and combination wave test surges to only 0.5V common mode. Includes four widely spaced NEMA 5-15R hospital-grade output receptacles, 10-ft. (3.05 m) power cord, hospital-grade input plug, circuit breaker overload protection, lighted power switch and rugged all-metal housing. Ships ready for placement in any industrial, medical, office or network environment. PLUG/OUTLETS: Input - NEMA 5-15P Hospital Grade; Output - 4 NEMA 5-15R Hospital Grade ELECTRICAL: 120V AC, 60 Hz, 8.3A (requires NEMA 5-15R wall receptacle). Features ● Offers line isolation and continuous noise filtering ● Internal low-impedance isolation transformer with Faraday shield offers 100% isolation from the input AC line ● Full UL 60601-1 medical-grade listing with hospital-grade plug and outlet receptacles for the protection of sensitive electronic equipment in patient-care areas ● Reduces cumulative leakage current of the Isolator and connected equipment to levels less than 100 A ● Floating AC output prevents noise coupling from noisy hospital ground circuits and meets agency requirements ● Inexpensive alternative to dedicated circuits and site electrical upgrades ● Removes EMI/RFI noise, utility switching transients, load-generated harmonics and ground loops ● Transformer filtering offers continuous common-mode noise rejection with no wearable parts ● Reduces 6000V IEEE587 Cat A & B ring wave and combination wave test surges to only 0.5V common mode ● Includes 4 widely spaced NEMA 5-15R hospital-grade output receptacles, 10-ft. (3.05 m) power cord, 1/3 ● IS1000HG Isolation Transformer ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States hospital-grade input plug, circuit breaker overload protection, lighted power switch and rugged all-metal unit housing ● Ships ready for upright tower placement in any industrial, medical, office or network environment Specifications OVERVIEW UPC Code 037332116215 Efficiency 96% Let-through Voltage (Combination Wave) L-N: 250V Let-through Voltage (Ring Wave) L-N: 20V Nominal Voltage / Frequency 120V / 60Hz VA / Watt Capacity 1000 Transformer Type Medical-grade, low impedance transformer-based line isolation transformer L-G: 250V L-G: 20V N-G: 0.5V N-G: 0.5V INPUT Input Plug Type NEMA 5-15P-HG Total Harmonic Distortion Less than 1% Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Receptacles (4) 5-15R-HG Output Amp Capacity 8.8 ISOLATION Leakage Current Less than 100 microamps SURGE / NOISE SUPPRESSION Noise Suppression Rating 35-65 DB PHYSICAL Cooling Method Convection Form Factors Supported Tower Shipping Dimensions (hwd / in.) 10.40 x 10.70 x 12.80 Shipping Dimensions (hwd / cm) 26.42 x 27.18 x 32.51 Shipping Weight (lbs.) 37.70 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 17.10 Unit Dimensions (hwd / in.) 7.250 x 7.250 x 10.500 Unit Dimensions (hwd / cm) 19.66 x 18.42 x 26.67 FEATURES & SPECIFICATIONS Over Current Protection 1 x Thermal, 2 pole, 10 amp STANDARDS & COMPLIANCE Product Certifications UL 60601-1 Product Compliance RoHS; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
IS1000HG 价格&库存
很抱歉,暂时无法提供与“IS1000HG”相匹配的价格&库存,您可以联系我们找货
