175A-NA
175A-NA
    HAMMONDMANUFACTURING
    TRANSF AUTO 230-115V 100VA USA
175A-NA 数据手册
10/6/22, 4:21 AM Step-Down (230VAC to 115VAC) (175 Series) - Hammond Mfg. Quality Products. Service Excellence. Step-Down (230VAC to 115VAC) 175 Series Plug-In Features Single winding, does not provide isolation, for use where equipment is already isolated and only voltage change is required. World wide applications, 50 or 60 Hz. operation, step down (230VAC to 115 VAC). Input is circuit breaker protected. Hi-pot tested to 2 KV RMS. Input is a standard 250V North American, 3-wire, grounded plug (can also be used with adaptors for proper grounding). Input on "-NA" version - connected to a 5 foot cord & grounded North American 250V plug (NEMA 6-15P). Output connected to a one foot long "pig tail" cord with standard North American 115V - 3 wire grounded receptacle (NEMA 5-15R). North American Mark of Safety - C UL & UL listed (File #E211544). Indoor use only. Remember - These units do NOT convert line frequency. Gallery             Capacity Part No. VA https://www.hammfg.com/electronics/transformers/line/175     Overall Dimensions A B C D E Wt. Lbs. 1/2 10/6/22, 4:21 AM Step-Down (230VAC to 115VAC) (175 Series) - Hammond Mfg. Capacity Overall Dimensions Part No. VA A B C D E Wt. Lbs. 175A-NA 100 3.16 4.25 3.81 2.50 2.94 3.5 175B-NA 200 3.16 4.50 3.81 2.50 3.19 4.5 175C-NA 300 3.16 5.00 3.81 2.50 3.69 6 175D-NA 500 3.80 6.00 4.68 3.00 4.38 10 175E-NA 750 3.80 7.06 4.68 3.00 5.38 14 175F-NA 1000 3.80 7.06 4.68 3.00 5.38 14.5 175G-NA 1500 4.40 6.63 5.39 3.50 6.09 22 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/line/175 2/2
175A-NA 价格&库存
很抱歉,暂时无法提供与“175A-NA”相匹配的价格&库存,您可以联系我们找货
