10/5/22, 1:15 PM
Hard Wired (170E Series) - Hammond Mfg.
Quality Products. Service Excellence.
Hard Wired 170E Series
Features
Single winding, does not provide isolation, for use where equipment is already isolated
and only voltage change is required.
Flexible world wide applications, 50 or 60 Hz. operation, step down (230VAC to 115 VAC)
or step up (115VAC to 230VAC).
Totally enclosed rear case, includes handy internal grounding bolt.
Extra vacuum varnish for use in high humidity.
Includes a rear mounted (but not wired), standard 115VAC, 3-wire receptacle.
Enclosed case with convenient knockouts and includes two cable clamps allowing for
easy wire connections.
Models 170SE, 170AE, 170BE, 170CE & 170DE are CSA certified (209651)
Connection by flexible leads, 8" minimum length
Remember - These units do NOT convert line frequency
Capacity
Part No.
Overall Dimensions
Weight
VA
A
B
C
D
E
Lbs
170SE
50
3.13
4.00
4.10
2.30
3.10
3.5
170AE
100
3.13
4.00
4.10
2.30
3.10
4
170BE
200
3.13
4.30
4.10
2.30
3.40
5
170CE
300
3.13
4.80
4.10
2.30
3.90
6.5
170DE
500
3.75
5.00
4.90
2.80
4.10
10
170EE
750
3.75
6.00
4.90
2.80
5.10
15
170FE
1000
3.75
6.00
4.90
2.80
5.10
15.5
170GE
1500
4.38
7.00
5.50
3.30
5.90
23.5
170JE
2000
4.38
7.00
5.50
3.30
5.90
24
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
https://www.hammfg.com/electronics/transformers/line/170e
1/2
10/5/22, 1:15 PM
2/2
很抱歉,暂时无法提供与“170BE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+923.342381+119.11353
