170EE
170EE
    HAMMONDMANUFACTURING
    TRANSFORMR AUTO 115-230VAC 750VA
170EE 数据手册
10/5/22, 1:15 PM Hard Wired (170E Series) - Hammond Mfg. Quality Products. Service Excellence. Hard Wired 170E Series Features Single winding, does not provide isolation, for use where equipment is already isolated and only voltage change is required. Flexible world wide applications, 50 or 60 Hz. operation, step down (230VAC to 115 VAC) or step up (115VAC to 230VAC). Totally enclosed rear case, includes handy internal grounding bolt. Extra vacuum varnish for use in high humidity. Includes a rear mounted (but not wired), standard 115VAC, 3-wire receptacle. Enclosed case with convenient knockouts and includes two cable clamps allowing for easy wire connections. Models 170SE, 170AE, 170BE, 170CE & 170DE are CSA certified (209651) Connection by flexible leads, 8" minimum length Remember - These units do NOT convert line frequency     Capacity Part No. Overall Dimensions Weight VA A B C D E Lbs 170SE 50 3.13 4.00 4.10 2.30 3.10 3.5 170AE 100 3.13 4.00 4.10 2.30 3.10 4 170BE 200 3.13 4.30 4.10 2.30 3.40 5 170CE 300 3.13 4.80 4.10 2.30 3.90 6.5 170DE 500 3.75 5.00 4.90 2.80 4.10 10 170EE 750 3.75 6.00 4.90 2.80 5.10 15 170FE 1000 3.75 6.00 4.90 2.80 5.10 15.5 170GE 1500 4.38 7.00 5.50 3.30 5.90 23.5 170JE 2000 4.38 7.00 5.50 3.30 5.90 24 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/line/170e 1/2 10/5/22, 1:15 PM Hard Wired (170E Series) - Hammond Mfg. https://www.hammfg.com/electronics/transformers/line/170e 2/2
170EE 价格&库存
很抱歉,暂时无法提供与“170EE”相匹配的价格&库存,您可以联系我们找货
