176E
176E
    HAMMONDMANUFACTURING
    TRANSFORMER AUTO STEP UP/PLG IN
176E 数据手册
10/4/22, 4:50 AM Step-Up (115VAC to 230VAC) (176 Series) - Hammond Mfg. Quality Products. Service Excellence. Step-Up (115VAC to 230VAC) 176 Series Plug-In Features Single winding, does not provide isolation, for use where equipment is already isolated and only voltage change is required. World wide applications, 50 or 60 Hz. operation, step up (115VAC to 230VAC). Input is circuit breaker protected. Hi-pot tested to 2 KV RMS Input is a standard 3-wire, grounded plug (can also be used with adaptors for proper grounding). Input is connected to a 5 foot cord & standard grounded North American plug (NEMA 515P) Output - Due to U.L changes in 2007 - NEW production with the European (Shuko) parts would no longer be U.L. listed. Therefore, we replaced this output receptacle with a one foot long "pig tail" cord with a standard North American 3-wire, 250V receptacle (NEMA 6 15R) for any production after the first part of 2008. North American Mark of Safety - C UL & UL listed (File #E211544). Indoor use only. Remember - These units do NOT convert line frequency Gallery             https://www.hammfg.com/electronics/transformers/line/176     1/2 10/4/22, 4:50 AM Step-Up (115VAC to 230VAC) (176 Series) - Hammond Mfg. Part Part No. No. Capacity VA VA A A Overall Dimensions B C D B C D 176A 100 3.16 4.25 3.81 176B 200 3.16 4.50 3.81 176C 300 3.16 5.00 176D 500 3.80 176E 750 3.80 176F 1000 176G 1500 E E Wt. Wt. Lbs. Lbs. 2.50 2.94 3.5 2.50 3.19 4.5 3.81 2.50 3.69 6 6.00 4.68 3.00 4.38 10 7.06 4.68 3.00 5.38 14 3.80 7.06 4.68 3.00 5.38 14.5 4.40 6.63 5.39 3.50 6.09 22 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/line/176 2/2
很抱歉,暂时无法提供与“176E”相匹配的价格&库存,您可以联系我们找货
