172E
172E
    HAMMONDMANUFACTURING
    TRANSFORMER PLUG & RECEPTACLE
172E 数据手册
www.hammondmfg.com Plug-In Isolation - Step Down (230VAC to 115VAC) 172E Hammond Plug-In Isolation Transformers Hammond isolation transformers provide complete circuit isolation to protect your sensitive electronics. 172E features an electrostatic shield between the primary and secondary which greatly attenuates surges and noise caused by power problems on the same circuit or by supply disruptions from utilities. Isolation transformers are an essential for laboratory test benches where line voltage is used. Plug-In Isolation Transformers For safety concerns, every 172E has been hi-pot tested to 2KV (115 RMS, and features a 5 amp circuit breaker on the primary. The primary features a 5’ cord with a standard NEMA 6-15P plug. The secondary is connected to a 1’ cord with a standard NEMA 5-15R receptacle. All units carry the North American mark of safety C UL & UL listed (File # E211544). Features • Primary 230VAC, 50/60 Hz., Secondary 115VAC • Provides complete circuit isolation. • Faraday electrostatic shield between primary & secondary to greatly attenuate surges and noise. • Hi-pot tested to 2 KV RMS. • Circuit breaker in primary. • Standard 3-wire, grounded plug & receptacle. • Input (primary) connected to 5 foot long cord & standard North American plug (NEMA 5-15P). • Output (secondary) connected to 1 foot long “pig tail” cord, 3-wire, standard North American grounded receptacle (NEMA 5-15R). • North American Mark of Safety - C UL & UL listed (File #E211544) • Indoor use only • Remember - These units do NOT convert line frequency www.hammondmfg.com Plug-In Isolation - Step Down (230VAC to 115VAC) 172E Electrical Specifications: Primary Voltage Secondary Voltage Frequency Capacity VA Leakage Current Full Load Efficiency Full Load Total Harmonic Distortion 230VAC 115VAC 50 / 60 Hz 750 < 100 µA 94% (typical) 0.19% (typical) Surge/ Noise Suppression -38.24 dB (typical) Capacitance Between Windings @ 1 kHz 20 pF (typical) Circuit Breaker (Amps) 5A on primary Dimensions A B C D E Weight Cord Length (Primary) Cord Length (Secondary) Plug on Primary 4.4” / 112 mm 8.7” / 221 mm 5.39” / 137 mm 3.5” / 89 mm 6.78” / 172 mm 30 lbs / 13.61 kg 5ft / 1.52m 1ft/ 0.30m NEMA 6-15P Receptable on Secondary NEMA 5-15R 5A Breaker 230V 50 / 60 Hz 115V 6.52A
很抱歉,暂时无法提供与“172E”相匹配的价格&库存,您可以联系我们找货
172E
  • 1+2929.684011+379.74283
  • 5+2676.287735+346.89785
  • 10+2574.4835010+333.70208
  • 25+2446.2103225+317.07543
库存:1
