10/5/22, 9:05 AM
TOROIDAL Isolation (120VAC to 120VAC) (178 Series) - Hammond Mfg.
Quality Products. Service Excellence.
TOROIDAL Isolation (120VAC to 120VAC) 178 Series
Plug-In
Features
Primary 120VAC, 50/60 Hz., Secondary 120VAC.
Provides circuit isolation.
Toroidal transformer for high isolation, low noise, light weight, cool operation and low
profile.
World wide applications, 50 or 60 Hz. operation, step down (120VAC to 120 VAC).
Standard 3-wire, grounded plug (for use with adaptors for proper grounding).
Input (primary) connected to a 5 foot long cord & standard North American plug (NEMA 5
15P).
Output (secondary) connected to two standard - 3 wire grounded receptacles (NEMA 515R).
Features include ventilated black steel case, rocker lighted on-off switch & circuit breaker
protected output.
North American Mark of Safety - C UL & UL listed (File #E211544).
Indoor use only.
Remember - These units do NOT convert line frequency.
Note about Inrush Current:
Due to the superior magnetic properties of Toroidal transformers they will be susceptible
to high magnetizing current when initially energized, only limited by the low DC resistance
of the primary winding. Depending on where you are in the AC cycle when the
transformer is energized dictates the chances of overloading the supply circuit. This is
why the transformer may sometimes energize without a problem and other times it will
blow the fuse or trip the circuit breaker. The duration of this overload is rarely longer than
a half of a cycle. Therefore, you should consider using a slow-blow fuse, time delayed
circuit breaker or other form of soft start circuitry for the supply line when using these high
efficient Toroidal transformers.
Accessories
International Grounded Adaptor Plugs
Capacity
Outlet
Part No.
VA
Qty
Length
Overall Dimensions
Width
Height
178CT
250
2
8.25
6.00
4.00
178DT
500
2
9.00
6.00
4.00
178ET
750
2
10.25
7.50
5.00
178FT
1000
2
10.25
7.50
5.00
178GT
1500
2.00
12.50
9.00
5.00
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
https://www.hammfg.com/electronics/transformers/line/178
1/2
10/5/22, 9:05 AM
2/2
很抱歉,暂时无法提供与“178CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2572.158791+332.40548
