IS250HG
IS250HG
    TRIPPLITE
    TRANSF ISO 250W 2OUT HOSP GRADE
IS250HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Isolator Series 120V 250W UL 60601-1 MedicalGrade Isolation Transformer with 2 HospitalGrade Outlets MODEL NUMBER: IS250HG Highlights ● Complete line isolation & noise filtering ● 250 watts, 2 outlets, 10-ft. (3.05 m) power cord ● Hospital-grade plug and receptacles ● Lowers cumulative leakage current of connected equipment to under 100 A ● TAA-compliant Package Includes Description Isolator Series UL 60601-1 Listed Medical-Grade Isolation Transformers offer line isolation and continuous noise filtering. An internal low-impedance isolation transformer component offers 100% isolation from the input AC line. Full UL 60601-1 medical-grade listing with hospital-grade plug and outlet receptacles makes Isolator medical-grade transformers ideal for protecting sensitive electronic equipment in patient-care areas. Faraday shield reduces the cumulative leakage current of the Isolator and connected equipment to levels less than 100 microamps. Removes EMI/RFI noise, utility switching transients and harmonics generated by other on-site loads. Reduces impact of utility-related surge conditions. Transformer filtering provides continuous common-mode noise rejection with no wearable parts. Reduces 6000V IEEE587 Category A & B ring wave and combination wave test surges to only 0.5V common mode. Includes two NEMA 5-15R hospital-grade output receptacles, 10-ft. (3.05 m) power cord, hospital-grade input plug, circuit breaker overload protection, lighted power switch and rugged all-metal unit housing. Ships ready for placement in any industrial, medical, office or network environment. PLUG/OUTLETS: Input - NEMA 5-15P Hospital Grade; Output - 2 NEMA 5-15R Hospital Grade ELECTRICAL: 120V AC, 60 Hz, 2.2A (requires NEMA 5-15R wall receptacle). Features ● Offers line isolation and continuous noise filtering ● Internal low-impedance isolation transformer with Faraday shield offers 100% isolation from the input AC line ● Full UL 60601-1 medical-grade listing with hospital-grade plug and outlet receptacles for the protection of sensitive electronic equipment in patient-care areas ● Reduces cumulative leakage current of the Isolator and connected equipment to levels less than 100 A ● Floating AC output prevents noise coupling from noisy hospital ground circuits ● Inexpensive alternative to dedicated circuits and site electrical upgrades ● Removes EMI/RFI noise, utility switching transients, load-generated harmonics and ground loops ● Transformer filtering offers continuous common-mode noise rejection with no wearable parts ● Reduces 6000V IEEE587 Cat A & B ring wave and combination wave test surges to only 0.5V common mode ● Includes 2 NEMA 5-15R hospital-grade output receptacles, 10-ft. (3.05 m) power cord, hospital-grade input plug, circuit breaker overload protection, lighted power switch and rugged all-metal unit housing 1/3 ● IS250HG Isolation Transformer ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Ships ready for upright tower placement in any industrial, medical, office or network environment Specifications OVERVIEW UPC Code 037332116208 Efficiency 96% Let-through Voltage (Combination Wave) L-N: 250V Let-through Voltage (Ring Wave) L-N: 20V Nominal Voltage / Frequency 120V/60Hz VA / Watt Capacity 250 Transformer Type Medical grade, low impedance transformer-based line isolation transformer L-G: 250V L-G: 20V N-G: 0.5V N-G: 0.5V INPUT Total Harmonic Distortion Less than 1% Input Plug Type NEMA 5-15P-HG Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Receptacles (2) 5-15R-HG Output Amp Capacity 2.1 ISOLATION Leakage Current Less than 100 microamps SURGE / NOISE SUPPRESSION Noise Suppression Rating 35-65 DB PHYSICAL Cooling Method Convection Form Factors Supported Tower Shipping Dimensions (hwd / in.) 7.00 x 6.90 x 10.30 Shipping Dimensions (hwd / cm) 17.78 x 17.53 x 26.16 Shipping Weight (lbs.) 14.50 Shipping Weight (kg) 6.58 Unit Dimensions (hwd / in.) 4.500 x 4.750 x 7.750 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / cm) 11.43 x 12.07 x 19.69 FEATURES & SPECIFICATIONS Over Current Protection 2.5A circuit breaker STANDARDS & COMPLIANCE Product Certifications UL 60601-1 Product Compliance RoHS; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
IS250HG 价格&库存
很抱歉,暂时无法提供与“IS250HG”相匹配的价格&库存,您可以联系我们找货
