IS1800HG
IS1800HG
    TRIPPLITE
    ISOLATOR TRANSFORMER 18W
IS1800HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Isolator Series 120V 1800W UL 60601-1 MedicalGrade Isolation Transformer with 6 HospitalGrade Outlets MODEL NUMBER: IS1800HG Highlights ● Complete line isolation and noise filtering ● Hospital-grade plug and receptacles ● Lowers cumulative leakage current of connected equipment to under 100 A ● Floating AC output prevents noise coupling ● TAA-compliant Package Includes Description Isolator Series UL 60601-1 Listed Medical-Grade Isolation Transformers offer line isolation and continuous noise filtering. An internal low-impedance isolation transformer component offers 100% isolation from the input AC line. Full UL 60601-1 medical-grade listing with hospital-grade plug and outlet receptacles makes Isolator medical-grade transformers ideal for protecting sensitive electronic equipment in patient-care areas. Faraday shield reduces the cumulative leakage current of the Isolator and connected equipment to levels less than 100 microamps. Removes EMI/RFI noise, utility switching transients and harmonics generated by other on-site loads. Reduces impact of utility-related surge conditions. Transformer filtering provides continuous common-mode noise rejection with no wearable parts. Reduces 6000V IEEE587 Category A & B ring wave and combination wave test surges to only 0.5V common mode. Includes six widely spaced NEMA 5-20R hospital-grade output receptacles, 10-ft. (3.05 m) power cord, hospital-grade input plug, circuit breaker overload protection, lighted power switch and rugged all-metal housing. Ships ready for placement in any industrial, medical, office or network environment. PLUG/OUTLETS: Input - NEMA 5-20P Hospital Grade; Output - 6 NEMA 5-20R Hospital Grade ELECTRICAL: 120V AC, 60 Hz, 15A (requires NEMA 5-15R wall receptacle). Features ● Offers line isolation and continuous noise filtering ● Internal low-impedance isolation transformer with Faraday shield offers 100% isolation from the input AC line ● Full UL 60601-1 medical-grade listing with hospital-grade plug and outlet receptacles for the protection of sensitive electronic equipment in patient-care areas ● Reduces cumulative leakage current of the Isolator and connected equipment to levels less than 100 A ● Floating AC output prevents noise coupling from noisy hospital ground circuits and meets agency requirements ● Inexpensive alternative to dedicated circuits and site electrical upgrades ● Removes EMI/RFI noise, utility switching transients, load-generated harmonics and ground loops ● Transformer filtering offers continuous common-mode noise rejection with no wearable parts ● Reduces 6000V IEEE587 Cat A & B ring wave and combination wave test surges to only 0.5V common mode ● Includes 6 widely spaced NEMA 5-20R hospital-grade output receptacles, hospital-grade input plug, 1/3 ● IS1800HG Isolation Transformer ● NEMA5-15P replacement plug ● User manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States circuit breaker overload protection, lighted power switch and rugged all-metal unit housing ● 10-ft. (3.05 m) power cord with NEMA 5-20P-HG input plug; NEMA 5-15P-HG plug included for compatibility with common 15A wall outlets ● Ships ready for upright tower placement in any industrial, medical, office or network environment Specifications OVERVIEW UPC Code 037332116222 Efficiency 96% Let-through Voltage (Combination Wave) L-N: 250V Let-through Voltage (Ring Wave) L-N: 20V Nominal Voltage / Frequency 120V / 60Hz VA / Watt Capacity 1800 Transformer Type Hospital Grade, low impedance transformer-based line isolation transformer L-G: 250V L-G: 20V N-G: 0.5V N-G: 0.5V INPUT Input Plug Type NEMA 5-20P-HG Total Harmonic Distortion Less than 1% Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Receptacles (6) 5-20R-HG Output Amp Capacity 15 ISOLATION Leakage Current Less than 100 microamps SURGE / NOISE SUPPRESSION Noise Suppression Rating 35-65 DB PHYSICAL Cooling Method Convection Form Factors Supported Tower Shipping Dimensions (hwd / in.) 13.70 x 9.70 x 12.90 Shipping Dimensions (hwd / cm) 34.80 x 24.64 x 32.77 Shipping Weight (lbs.) 59.10 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 26.81 Unit Dimensions (hwd / in.) 7.750 x 8.250 x 12.250 Unit Dimensions (hwd / cm) 19.69 x 20.96 x 31.11 FEATURES & SPECIFICATIONS Over Current Protection 1x thermal, 2 pole, 10 amp STANDARDS & COMPLIANCE Product Certifications UL 60601-1 Product Compliance RoHS; Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
IS1800HG 价格&库存
很抱歉,暂时无法提供与“IS1800HG”相匹配的价格&库存,您可以联系我们找货
