SU5000XFMRT2U
SU5000XFMRT2U
    TRIPPLITE
    TRANSFORMER ISOLATION 2U RACK
SU5000XFMRT2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5kVA / 5kW Step-Down Isolation Transformer 208V to 120V, 2U Rack-Mount, L6-30P, 5-15/20R, L6-30R Highlights ● 5kVA / 5,000 watt step-down isolation transformer converts 208V to 120V ● Simple plug-in installation with L6-30P input plug, 10-ft. (3.05 m) cord ● 12 NEMA 5-15/20R 120VAC outlets accommodate 5-15P and 5-20P equipment plugs, L6-30R outlet accommodates one high voltage plug ● Ideal means of converting UPS, utility, generator or other 208V input to 120VAC ● Supports 2U rackmount installation MODEL NUMBER: SU5000XFMRT2U Package Includes Description Tripp Lite's SU5000XFMRT2U step-down, isolation transformer converts 208V input from generator, utility or UPS high voltage source to 120V low voltage output. 208V 30A input plug with 10-ft. (3.05 m) AC cord connects to L6-30R socket. 12 NEMA 5-15/20R output receptacles accommodate 5-15P or 5-20P equipment plugs. Built-in L6-30R outlet supports high voltage output. Supports 2U rackmount installation with included brackets for 4 post enclosures. Supports 2 post rackmount installation with optional 2POSTRMKITWM. Supports upright tower installation with 2-9USTAND. Features ● Step-down/isolation transformer converts high voltage 208V input from generator, utility or UPS to low voltage 120V output ● 5kVA/5,000 watt power handling capacity ● L6-30P input plug ● 10-ft. (3.05 m)/10 gauge input line cord ● 12 built-in NEMA 5-15/20R output receptacles accept common 5-15P and 5-20P equipment plugs. Builtin L6-30R outlet supports high voltage output. ● 4 built-in 20A circuit breakers protect against overload conditions ● Included mounting accessories support 2U installation in 4 post rack enclosures with a max depth requirement of only 20.75 inches ● Optional 2POSTRMKITWM enables 2 post relay-rack installation ● Optional 2-9USTAND accessory enables upright tower installation Specifications OVERVIEW UPC Code 037332122087 1/3 ● SU5000XFMRT2U step-down, isolation transformer ● 4 post rackmount accessories ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Accessory Type Isolation Transformer Accessory Class UPS Accessories INPUT Nominal Input Voltage(s) Supported 208V AC UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 208V 30A Maximum Input Amps 24 Input Connection Type NEMA L6-30P Voltage Compatibility (VAC) 120 Input Frequency 60 Hz OUTPUT Frequency Compatibility 60 Hz Output (VA) 5000 Output (Watts) 5000 Output Receptacles (12) 5-15/20R; (1) L6-30R Output Nominal Voltage 120/208V AC Overload Protection Includes 4 built-in 20A circuit breakers. Each breaker protects 3 5-15/20R outlets each. PHYSICAL Material of Construction Steel Form Factors Supported Rack/Tower (2U) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Minimum Required Rack Depth (cm) 60.96 Minimum Required Rack Depth (inches) 24 Shipping Dimensions (hwd / in.) 8.60 x 19.90 x 23.40 Shipping Dimensions (hwd / cm) 21.84 x 50.55 x 59.44 Shipping Weight (lbs.) 74.50 Shipping Weight (kg) 33.79 Unit Dimensions (hwd / in.) 3.500 x 17.500 x 20.750 Unit Dimensions (hwd / cm) 8.9 x 44.5 x 52.7 Unit Weight (lbs.) 63.5 Unit Weight (kg) 28.80 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Relative Humidity 0-95% (non-condensing) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SU5000XFMRT2U 价格&库存
很抱歉,暂时无法提供与“SU5000XFMRT2U”相匹配的价格&库存,您可以联系我们找货
