Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1630SEA
SINGLE ENDED “CLASSIC” TUBE OUTPUT TRANSFORMER – ULTRA-LINEAR
Over designed" for high fidelity, single ended, Class-A, tube output circuits (triode, tetrode or pentode tubes).
Enclosed (shielded), four slot, chassis Type "X" mounting.
Frequency response at least 20Hz. to 20Khz. at full rated power (+/- 1db max., ref. 1Khz.)
Insulated flexible leads 8" min.
For maximum versatility, all units (except the 1642SE & 1638SEA) include a 40% screen tap for Ultra-Linear,
tetrode/pentode operation (if desired). The 1642SE & 1638SEA do NOT include this screen tap as they were
designed principally for high impedance triode tubes.
High quality laminations, (M6) grain oriented silicon steel.
Core is gapped to reduce core saturation in Class-A tube amplifier circuits.
For general purpose or replacement use in single ended tube output circuits see our 125SE Series.
BLK
GRN
YEL
WHT
RED
BLU/YEL
BLU
*For Full Dimensional Details see page 4
www.hammondmfg.com
ELECTRICAL SPECIFICATIONS**
Schematic and Hook Up Data
Characteristic
Input Impedance
Output Impedance
Output Power
Primary - DCR
Blue – Red
Secondary DCR
Black – Green
Black – Yellow
Black – White
Typical
3500
4/8/16
30Watts
PRIMARY
114
RED
(B+)
415m
522m
732m
3500
Inductance
Primary – Blue – Red
Black – Green
Black – Yellow
Black – White
@ 1.0kHz, 1.0V OC
15Hy
26.4mH
51.9mH
98.7mH
Impedance
Black – Green
Black – Yellow
Black – White
@ 1.0kHz, 1.0V OC
92K
157
306
585
Frequency Response
Dielectric Strength
Temperature Range
See graphs for specific
response, Typ. 1.0db from
20Hz to 20KHz
2000Vrms
-40 To 105C
BLU/YEL
(40% SCREEN TAP)
BLU
(PLATE)
SCHEMATIC
SECONDARY
WHT - 16
YEL - 8
GRN - 4
BLK - COM
www.hammondmfg.com
www.hammondmfg.com
Dimensional Details:
Label:
1630SEA
Audio Transformer
30WATTS 20 - 20KHz
PRIMARY 3500 Ohms
SECONDARY 4 Ohms/8Ohms/16Ohms
SCREEN TAP 40% OF PRI VOLTS
Made In Canada
DATE
TYPICAL TEST CIRCUIT
PRIMARY
R S/
2
Measurement instruments
Hp4192a impedance analyzer
Hp3456a DVM
Keithley 2002 DVM
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
* All graphs input level 20dbu.
** The results are typical and are subject to normal manufacturing and electrical tolerances.
SECONDARY
RL
R S/
OUT
2
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or use d in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
很抱歉,暂时无法提供与“1630SEA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2135.582551+276.35564
- 10+1901.8405310+246.10819
- 25+1816.1782325+235.02304
- 50+1754.0045150+226.97743
