Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1760E
PRIMARY
BLK
COM
YEL
4 Ohm
GRN
8 Ohm
BRN
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
SECONDARY
Designed for drop in replacement of original
units.
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 9" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1dB reference @ 1KHz)
Distortion is less than 1% @ 70Hz
8500 CT
Ohm
RED
WHT 16 Ohm
BLU
15 WATTS
70Hz - 15kHz
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
8500 Ohms
4, 8 & 16 Ohms
15W
BLK
17
C
DCR
Primary Brown-Red
Primary Red-Blue
Secondary Black-Yellow
Secondary Black-Green
Secondary Black-White
154.40 Ohms
159.20 Ohms
0.410 Ohm
0.540 Ohm
0.830 Ohm
HA
M
MA MO
N U ND
FA
CT
U
@ 1.0 kHz, 1.0 V OC
21.60H
129 KOhm
Leakage Inductance
Primary Brown-Blue
@ 1.0 kHz, 1.0 V SC
323.9mH
Dielectric Strength
Temperature Range
1500VRMS
-40 to 105 degC
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
A
WHT
B
RIN
G
D
G
BRN
NOTE: ALL LEADS 9" LONG MIN.
Dimensions
A 3.250” ±0.063
B 2.085” ±0.125
C 1.995” ±0.063
D
G
2.813” ±0.063
0.187” X 0.300”
±0.015
TYPICAL TEST CIRCUIT
PRIMARY
Keithley 2010 DVM
Hp4192a impedance analyzer
E
BLU
RED
Inductance Impedance
Primary Brown-Blue
60
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
YEL
GRN
B
D A LK /
T E Y E B R N 15 W
L /G
RN - RE A TT
S
D
MA WH T - B
7
D E : C LU : 0H z
IN O M 8 5 - 1 5
CA /4 00 kH
z
NA
DA /8 C T
/ 16
R S/
OUT
2
www.hammondmfg.com
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission
of Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
很抱歉,暂时无法提供与“1760E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+855.05760
- 200+341.18280
- 500+329.77800
- 1000+324.14040
- 国内价格 香港价格
- 1+657.923071+85.22405
