Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1760H
PRIMARY
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
SECONDARY
BRN
Designed for drop in replacement of original
units.
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 9" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1dB reference @ 1KHz)
Distortion is less than 1% @ 70Hz
RED
6600 CT
Ohm
BLU
WHT
16 Ohm
GRN
8 Ohm
YEL
4 Ohm
BLK
COM
70Hz - 15kHz
20W
BLK
YEL
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
6600 Ohms
4, 8 & 16 Ohms
20W
DCR
Primary Brown-Blue
Secondary Black-Yellow
Secondary Black-Green
Secondary Black-White
347.8 Ohms
0.686 Ohm
0.803 Ohm
1.157 Ohm
C
HA
MA MMO
NU N D
FA
CT
U
@ 1.0 kHz, 1.0 V OC
25.8H
157 KOhm
Leakage Inductance
Primary Brown-Blue
@ 1.0 kHz, 1.0 V SC
12.30 mH
Dielectric Strength
Temperature Range
1500VRMS
-40 to 105 degC
A
D
G
NOTE: ALL LEADS 9" LONG MIN.
Dimensions
A 3.688” ±0.063
B 2.400” ±0.125
C 2.308” ±0.063
D
G
3.125” ±0.063
0.187” ±0.015
TYPICAL TEST CIRCUIT
PRIMARY
Keithley 2010 DVM
Hp4192a impedance analyzer
G
BRN
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
B
R IN
BLU
RED
Inductance Impedance
Primary Brown-Blue
R S/
SECONDARY
2
RL
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
GRN
WHT
BL
DA K/Y
TE EL/ BLU 20W
GR - R AT 176
N/W ED TS
0H
MA HT: - BR 70H
DE CO N:
z
IN
M 66 - 1
CA /4 00 5kHz
NA /8 C
DA /1 T
6
R S/
OUT
2
www.hammondmfg.com
RL
R S/
OUT
2
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission
of Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
很抱歉,暂时无法提供与“1760H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+799.190761+103.59034
- 10+711.8441210+92.26855
- 25+679.7549925+88.10919
- 50+656.4450750+85.08778
- 100+633.94197100+82.17095
