Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
101F
8
1
7
2
3
6
101F
5
4
MINIATURE EPOXY POTTED AUDIO TRANSFORMER
Pin type, P.C. board mount, net weight of only 0.1 oz.
Rugged black epoxy potted construction produces a completely
sealed unit withstanding severe environmental conditions.
Secondary may be used as primary and primary as secondary.
Power level: 100mw @ 300 Hz. to 100 Khz.
-Freq. range @ +10 dbm is 200 Hz. to 100 Khz. +/- 0.5db
-Freq. range @ +15 dbm is 200 Hz. to 100 Khz. +/- 0.5db
-Freq. range @ +20 dbm is 300 Hz. to 100 Khz. +/- 0.5db
-Freq. measurements with no D.C. saturation.
CANADA
ELECTRICAL SPECIFICATIONS
Characteristic
Input Impedance
Output Impedance
Output Power
DCR
Primary 1-3
Secondary 6-8
Inductance
Primary
Secondary
44 Ω (22Ω/22Ω)
52 Ω (26Ω/26Ω)
@ 1.0 kHz, 1.0 V OC
288 mH
288 mH
Leakage Inductance
0.40 mH
Impedance
Primary
Secondary
@ 1.0 kHz, 1.0 V OC
2.86 KΩ
2.86 KΩ
Frequency Response
Turns ratio
±0.5db from 200Hz to
100KHz
1:1
Dielectric Strength
No Connection
100 Vrms
Pins 4 & 5
Storage Temp
Operating Temp
-40 To 105°C**
-40 To 85°C**
8
1
7
2
3
6
101F
5
4
Typical
600 ΩCT
600 ΩCT
0.100 Watts
CANADA
SCHEMATIC DIAGRAM
PRIMARY
1
600 Ω CT 2
SECONDARY
6
7 600 Ω CT
PCB LAYOUT
3
8
TYPICAL TEST CIRCUIT
PRIMARY
R S/
SECONDARY
2
RL
Measurement instruments
Hp4192a impedance analyzer
Hp3456a DVM
Keithley 2002 DVM
D scope series iii audio analyzer
R S/
OUT
2
** The epoxy that is used to cast these parts has a workable temperature range of –40°C to +105°C
Under a normal rate of change, this does not include thermal shock.
Variations in the transformer materials and environmental conditions may reduce the workable temperature range.
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
很抱歉,暂时无法提供与“101F”相匹配的价格&库存,您可以联系我们找货
