10/4/22, 2:39 AM
Miniature Audio Potted (101 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Miniature Audio Potted 101 Series
PC Board Mount
Features
Pin type, miniature size, P.C. board mount, net weight of only 0.1 oz.
Rugged potted construction produces a completely sealed unit withstanding severe
environmental conditions.
Secondary may be used as primary and primary as secondary.
Power level: Minimum frequency range: 300 Hz. to 100 Khz. +/- 0.5 db @ 100 mw
Frequency range @ +10 dbm is 200 Hz. to 100 Khz. +/- 0.5 db
Frequency range @ +15 dbm is 200 Hz. to 100 Khz. +/- 0.5 db
Frequency range @ +20 dbm is 300 Hz. to 100 Khz. +/- 0.5 db
Frequency measurements with no D.C. current saturation.
See data sheets for more detailed information.
Nominal Impedance
Nominal Resistance
(Ohms)
(Ohms)
Useful Impedance Range
(Ohms)
Part No.
Primary
Secondary
Primary
Secondary
Pri./Sec. to Pri./Sec.
101D
300 ct
600 ct
20.4
54
150/300
600/1200
101F
600 ct
600 ct
44
52
300/300
1200/1200
101H
1200 ct
600 ct
80
53
600/300
2400/1200
101J
2500 ct
600 ct
150
54
1250/300
5000/1200
101P
300 ct
50 ct
20.4
4.8
150/25
600/100
101R
600 ct
50 ct
44
4.7
300/25
1200/100
101V
2500 ct
50 ct
150.7
4.9
1250/25
5000/100
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
https://www.hammfg.com/electronics/transformers/audio/101
1/2
10/4/22, 2:39 AM
2/2
很抱歉,暂时无法提供与“101P”相匹配的价格&库存,您可以联系我们找货
