146H
146H
    HAMMONDMANUFACTURING
    螺栓安装
    146H
146H 数据手册
10/4/22, 8:19 AM Audio Chassis Mount (143-146 Series) - Hammond Mfg. Quality Products. Service Excellence. Audio Chassis Mount 143-146 Series Features Small, economical, open, two hole horizontal bracket mount. Insulated, color coded flexible leads, 4" long minimum (143, 144 & 145 Series) or 3" long minimum (146 Series). For a similar, P.C. board mount version, refer to the 148 and 149 series. Frequency response 150 Hz. to 15 Khz. (+/- 1 db, reference 1000 Hz.) When operating at impedances below nominal, power capability and the frequency spectrum are proportionately lower, conversely, at higher impedances power capability and frequency spectrum will be proportionately higher. Net weight: 0.5 oz. (143, 144, 146 Series) & 1.4 oz. (145 Series).   Part No. Applicaton 143B 143D Nominal Impedance Primary (Ohms) D.C. Primary Secondary (*1) ma Input 3.2 4000 Input 200K 1000 143H Driver 1500 D.C. Resistance (Ohms) +/- 15% Output Overall Dimensions Primary Secondary (mW) A B C D Schematic 0 0.4 245 15 1.26 0.69 0.69 1.06 1 0 4500 30 25 1.26 0.69 0.69 1.06 1 500 ct 4 111 24 30 1.26 0.69 0.69 1.06 2 143J Driver 3000 1000 ct 2.6 265 53 30 1.26 0.69 0.69 1.06 2 143L Driver 10000 200 ct 1.5 720 9 30 1.26 0.69 0.69 1.06 2 143N Driver 10000 2000 ct 1.5 720 89 30 1.26 0.69 0.69 1.06 2 https://www.hammfg.com/electronics/transformers/audio/143-146 1/2 10/4/22, 8:19 AM Part No. Audio Chassis Mount (143-146 Series) - Hammond Mfg. Nominal Impedance Primary (Ohms) D.C. Applicaton Primary Secondary 143R Driver 25000 144B Output 200 ct 144D Output 144F D.C. Resistance (Ohms) +/- 15% (*1) ma Primary Secondary 600 ct 1 1890 3.2 10 10 300 ct 3.2 9 Output 500 ct 3.2 144G Output 500 ct 144H Output 144I Output 144P Output Overall Dimensions (mW) A B C D Schematic 25 30 1.26 0.69 0.69 1.06 2 0 150 1.26 0.69 0.69 1.06 3 15 0.33 150 1.26 0.69 0.69 1.06 3 6 27 0.33 150 1.26 0.69 0.69 1.06 3 8 6 27 0.9 150 1.26 0.69 0.69 1.06 3 500 ct 50 6 28 7.3 150 1.26 0.69 0.69 1.06 3 600 ct 150 ct 6 45 8.2 150 1.26 0.69 0.69 1.06 4 Output 10000 3.2 5 575 0.5 50 1.26 0.69 0.69 1.06 1 144Q Output 10000 8 5 575 0.9 50 1.26 0.69 0.69 1.06 1 144S Output 20000 8 3.5 1240 0.9 50 1.26 0.69 0.69 1.06 1 145A Driver 100 200 ct 45 14 19 100 1.63 0.88 0.81 1.38 2 145B Driver-Output 600 600 18 30 38 200 1.63 0.88 0.81 1.38 1 145C Input 50000 1500 ct 1 2400 52 50 1.63 0.88 0.81 1.38 2 145D Input 200K 1000 0.5 3600 33 10 1.63 0.88 0.81 1.38 1 145E Input-Output 600 ct 600 ct 5 65 83 200 1.63 0.88 0.81 1.38 4 145F Driver 600 ct 200 ct 20 45 9 135 1.63 0.88 0.81 1.38 4 145G Driver 2000 200 ct 12 140 9 135 1.63 0.88 0.81 1.38 2 145H Driver 2000 500 ct 12 148 17 135 1.63 0.88 0.81 1.38 2 145J Driver 4000 600 ct 8 340 24 135 1.63 0.88 0.81 1.38 2 145L Driver 4000 2600 ct 8 340 100 135 1.63 0.88 0.81 1.38 2 145N Driver 10000 2000 ct 5 700 89 135 1.63 0.88 0.81 1.38 2 145O Driver 15000 200 ct 4 850 10 135 1.63 0.88 0.81 1.38 2 145P Driver 20000 1000 ct 3.5 1180 50 135 1.63 0.88 0.81 1.38 2 145R Driver 20000 2000 ct 3.5 1180 89 135 1.63 0.88 0.81 1.38 2 146B Output 48 ct 3.2 20 2.4 0.3 700 1.63 0.88 0.81 1.38 3 146C Output 48 ct 8 20 2.4 0.7 700 1.63 0.88 0.81 1.38 3 146D Output 100 ct 3.2 14 4.4 0.3 700 1.63 0.88 0.81 1.38 3 146E Output 100 ct 8 14 4.4 0.7 700 1.63 0.88 0.81 1.38 3 146F Output 250 ct 3.2 8 11 0.3 700 1.63 0.88 0.81 1.38 3 146G Output 250 ct 8 8 11 0.7 700 1.63 0.88 0.81 1.38 3 146H Output 500 ct 3.2 6 26 0.3 700 1.63 0.88 0.81 1.38 3 146I Output 500 ct 8 6 26 0.7 700 1.63 0.88 0.81 1.38 3 146J Output 1000 ct 3.2 4 56 0.3 700 1.63 0.88 0.81 1.38 3 146K Output 1000 ct 8 4 56 0.7 700 1.63 0.88 0.81 1.38 3 146N Output 2000 ct 8 3 97 0.7 700 1.63 0.88 0.81 1.38 3 146S Output 4000 ct 8 2 220 0.7 700 1.63 0.88 0.81 1.38 3 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/audio/143-146 2/2
146H
1. 物料型号:143-146系列音频底盘安装变压器。 2. 器件简介:小型经济型开放式两孔水平支架安装,绝缘的彩色软线,长度至少为4英寸(143, 144 & 145系列)或3英寸(146系列)。 3. 引脚分配:文档中提供了四种不同的电路图,展示了不同的引脚分配方式。 4. 参数特性: - 频率响应:150 Hz至15 kHz(±1 dB,参考1000 Hz)。 - 阻抗:不同型号有不同的标称阻抗值。 - 直流电阻和输出功率:不同型号有不同直流电阻和输出功率。 5. 功能详解:文档列出了不同型号的变压器,包括输入、驱动和输出应用,并提供了它们的直流电阻、输出功率和整体尺寸。 6. 应用信息:适用于音频应用,如输入、驱动和输出变压器。 7. 封装信息:提供了不同型号的变压器的外形尺寸。
很抱歉,暂时无法提供与“146H”相匹配的价格&库存,您可以联系我们找货
146H
