149V
149V
    HAMMONDMANUFACTURING
    插件-8,26.9x20.8mm
    149V
149V 数据手册
10/3/22, 1:33 AM Audio Open Frame (149 Series) - Hammond Mfg. Quality Products. Service Excellence. Audio Open Frame 149 Series PC Board Mount Features Pin type (0.25" length & 0.025" square), P.C. board mount. Economical, open type, horizontal bracket construction. Includes clinching lugs for extra mounting strength. Frequency response 200 Hz. - 15 Khz. (+/- 1 db, ref. @ 1 Khz.). Total distortion approximately 2% for drivers and 1% for outputs at 200 Hz., decreasing at higher frequencies. Insertion loss less than 1/2 db. Bifilar wound for balanced capacitive and resistance characteristics, on pin bobbins for standard 0.2" grid pin spacing. Insulation test 250V rms. For rugged epoxy cast type units refer to our 102, 104, 106 or 107, 108 and 109 series. Net weight: 0.6 oz. (148 Series) & 1.0 oz. (149 Series).     https://www.hammfg.com/electronics/transformers/audio/149 1/2 10/3/22, 1:33 AM Audio Open Frame (149 Series) - Hammond Mfg. Max. Primary D.C. Resistance Nominal Impedance D.C. current (Ohms) +/- 15% (Ohms) (ma.) (See Note 2) Part No. Applicaton Primary 149C Driver 149E Driver 149F Schematic Output Drawing Secondary (Milliwatts) Figure Secondary (See Note 1) Primary 160 20/80 56 24 7 200 2 300 30/120 42 41 10 200 2 Driver 450 40/160 33 52 19 200 2 149G Driver 600 150/600 29 92 58 200 2 149H Driver 1000 60/240 22 155 24 200 2 149Q Output 200 ct 3.2 7 19 0.4 1000 4 149S Output 600 ct 150 ct 4 53 17 1000 5 149T Output 600 ct 600 ct 4 53 70 1000 5 149U Output 150/600 8 4 53 95 1000 6 149V Hybrid 600 ct 300/1200 4 53 63 1000 7 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/audio/149 2/2
很抱歉,暂时无法提供与“149V”相匹配的价格&库存,您可以联系我们找货
