Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
108G
MINIATURE EPOXY POTTED AUDIO TRANSFORMER
6
Audio input, line matching and output transformers
Epoxy potted in an attractive molded case, Pin type, P.C. board
mount, (min. 0.187” length)
Rugged epoxy potted construction produces a completely
sealed unit withstanding severe environmental conditions.
In some models where no center tap is present (on the secondary), pin 5 is omitted.
Secondary may be used as primary and primary as secondary.
Will withstand soldering for 10 sec. @ 260 degrees C, ambient temp. 85 degrees C max.
Power level: 500mw @ 300 Hz. to 50 Khz.
-Freq. range @ +0 dbm is 300 Hz. to 50 Khz. +/- 1.5db
-Freq. range @ +15 dbm is 300 Hz. to 50 Khz. +/- 1.5db
-Freq. range @ +27 dbm is 300 Hz. to 50 Khz. +/- 1.5db
-Freq. measurements with no D.C. saturation.
54 Ω (27Ω/27Ω)
27.0 Ω (13.5Ω/13.5Ω)
@ 1.0 kHz, 1.0 V OC
0.95 Hy
0.38 Hy
Leakage Inductance
3.00 mH
Impedance
Primary
Secondary
@ 1.0 kHz, 1.0 V OC
8.20 KΩ
3.33 KΩ
MADE IN
CANADA
2
1
6
5
3
4
108G
CANADA
1
ELECTRICAL SPECIFICATIONS
Characteristic
Input Impedance
Output Impedance
Output Power
DCR
Primary 1-3
Secondary 4-6
Inductance
Primary
Secondary
5
4
108G
3
2
Typical
600 ΩCT
250 ΩCT
0.500 Watts
Frequency Response ±1.5db from 300Hz to 50KHz
Unbalanced DC
6mA Max.
Turns ratio
1.55:1
Dielectric Strength
100 Vrms
Temperature Range
-40 To 105°C**
SCHEMATIC DIAGRAM
PRIMARY
1
600 Ω CT 2
SECONDARY
6
5 250 Ω CT
PCB LAYOUT
3
4
TYPICAL TEST CIRCUIT
PRIMARY
R S/
SECONDARY
2
RL
Measurement instruments
Hp4192a impedance analyzer
Hp3456a DVM
Keithley 2002 DVM
D scope series iii audio analyzer
R S/
OUT
2
**The epoxy that is used to cast these parts has a workable temperature range of –40°C to +105°C
Under a normal rate of change, this does not include thermal shock.
Variations in the transformer materials and environmental conditions may reduce the workable temperature range.
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
很抱歉,暂时无法提供与“108G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+395.16120
- 200+157.66920
- 500+152.40960
- 1000+149.80680
