141H
141H
    HAMMONDMANUFACTURING
    插件-6,19.8x16.8mm
    141H
141H 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammfg.com 141 Series PCB-Mount Low Profile Audio Transformer 141H Features:      Pin type (0.25" length & 0.035" diameter), P.C. board mount Low profile, open type construction Frequency response 200 Hz - 50 KHz. (±1.0dB, Reference @ 1 KHz.) Core uses high grade silicon laminations (29M6) Weight: 0.6 oz. ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power Typical 600 Ohms 600 Ohms 150mW 15.54 Ohms 15.08 Ohms 19.35 Ohms 18.90 Ohms DCR PRI Pin 1-2 DCR PRI Pin 2-3 DCR SEC Pin 4-5 DCR SEC Pin 5-6 Max. PRI DC Dielectric Strength Temperature Class Inductance | Impedance ±20% ±20% ±20% ±20% 2mA 250 VRMS Up to 105 degC PRI Pin 1-3 Leakage Inductance @ 1 KHz, 1 V OC 252.10mH 2.05K Ohm @ 1 KHz, 1 V SC PRI Pin 1-3 1.48mH DIMENSIONAL DETAILS: Tolerance : ±0.02 in. 5 4 1 2 3 DATE CODE 6 This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitte d or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. PERFORMANCE GRAPHS:     MEASUREMENT INSTRUMENTS dScope Series III Audio Analyzer Wayne Kerr 3255B with a 3265B Inductance Analyzer HP 4192a LF Impedance Analyzer Keithley 2010 DVM **The results are typical and are subject to normal manufacturing and electrical tolerances. Hammond Mfg. Co. Ltd., Electronics Division www.hammfg.com TEST CONDITIONS PRIMARY R S/ 2 R S/ 2 SECONDARY RL OUT Release 2: 07.30.2021
很抱歉,暂时无法提供与“141H”相匹配的价格&库存,您可以联系我们找货
141H
    • 1+387.70920
    • 200+154.69920
    • 500+149.53680
    • 1000+146.97720
