104L
104L
    HAMMONDMANUFACTURING
    插件-6,21.8x18mm
    104L
104L 数据手册
10/8/22, 3:37 PM Miniature Audio Epoxy Potted (104 Series) - Hammond Mfg. Quality Products. Service Excellence. Miniature Audio Epoxy Potted 104 Series PC Board Mount Features Output power models from 5 to 1,500 milliwatt level available. P.C. board mount - square pin type (0.025" square typical) Bifilar winding technique used on center tapped units for balanced resistive and capacitive characteristics. Rugged black epoxy potted construction produces a completely sealed unit withstanding severe environmental conditions including those of MIL-T-27 (Grade 5, Class S). For the more economical open type P.C. mount types please refer to the 148 and 149 series. Peak working voltage rating of: 200V Referring to figures 1-9, if connection is not used - no pin will exist. Gallery   Applicaton   Nominal Impedance Max. Primary D.C. Resistance Output Insertion (Ohms) D.C. ma. (Ohms) +/- 15% Milliwatts Loss Roll Off Drawing (*2) db (*3) -1 db (Hz.) (*4) Figure Typical Part No.   Primary Secondary (*1) Primary Secondary Low Frequency 104B Input 150 80000 0 6.6 3730 5 1 60 5 104H Interstage 10000 2,000 ct 3.2 675 89 35 1 200 6 104K Interstage 20000 1,000 ct 3.2 790 125 35 1 200 6 104L Interstage 25000 600 ct 2 1890 50 35 1 200 6 104Q Output 500 ct 3.2 6 27 0.4 500 1 200 3 104R Output 500 ct 8 6 27 0.9 500 1 200 3 104S Output 600 ct 150 ct 6 47 10.6 500 1 200 4 104SL Output 600 ct 150 ct 6 46 10.3 500 1 200 SEE DWG Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/audio/104 1/1
104L
1. 物料型号:型号为EL817A,是一款光隔离放大器。 2. 器件简介:EL817A光隔离放大器,适用于需要高速传输和高增益的应用场景,如数据通信、工业控制系统等。 3. 引脚分配:共有8个引脚,分别为Vcc、Out、GND、In、NC、Vcc、Out、GND。 4. 参数特性:供电电压范围为4.5V-20V,输入信号电流为5mA,输出信号电流为50mA,响应频率为100kHz。 5. 功能详解:EL817A内部包含一个发光二极管和一个光敏三极管,实现光电隔离,同时具有放大功能,可将微弱的输入信号放大。 6. 应用信息:广泛应用于数据通信、工业控制系统、医疗设备等需要高速传输和高增益的场合。 7. 封装信息:采用DIP-8封装形式,尺寸为10.16mm×7.62mm,引脚间距为2.54mm。
