107X
107X
    HAMMONDMANUFACTURING
    插件-6,16x14.9mm
    107X
107X 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 107X 6 MINIATURE EPOXY POTTED AUDIO TRANSFORMER Audio input, line matching and output transformers Epoxy potted in an attractive molded case, Pin type, P.C. board mount, (min. 0.187” length) Rugged epoxy potted construction produces a completely sealed unit withstanding severe environmental conditions. In some models where no center tap is present (on the secondary), pin 5 is omitted. Secondary may be used as primary and primary as secondary. Will withstand soldering for 10 sec. @ 260 degrees C, ambient temp. 85 degrees C max. Power level: 150mw @ 150 Hz. to 50 Khz. -Freq. range @ +0 dbm is 150 Hz. to 80 Khz. +/- 1.5db -Freq. range @ +10 dbm is 150 Hz. to 80 Khz. +/- 1.5db -Freq. range @ +20 dbm is 150 Hz. to 80 Khz. +/- 1.5db -Freq. measurements with no D.C. saturation. 5 4 107X MADE IN CANADA 2 1 6 5 3 4 107X ELECTRICAL SPECIFICATIONS CANADA 1 Characteristic Input Impedance Output Impedance Output Power DCR Primary 1-3 Secondary 4-6 Inductance Primary Secondary 3.66KΩ (2.15KΩ/1.51KΩ) 75 Ω (37.5Ω/37.5Ω) @ 1.0 kHz, 1.0 V OC 56.7 Hy 0.83 Hy Impedance Primary Secondary @ 1.0 kHz, 1.0 V OC 300 KΩ 3.90 KΩ 2 3 Typical 100000 ΩCT 1000 ΩCT 0.150 Watts SCHEMATIC DIAGRAM PRIMARY 1 Frequency Response ±1.5db from 300Hz to 50KHz Turns ratio 10:1 Dielectric Strength Temperature Range SECONDARY 6 500 Vrms -40 To 105°C** 100000 Ω CT 2 5 1000 ΩCT PCB LAYOUT 3 4 TYPICAL TEST CIRCUIT PRIMARY R S/ SECONDARY 2 RL Measurement instruments Hp4192a impedance analyzer Hp3456a DVM Keithley 2002 DVM D scope series iii audio analyzer R S/ OUT 2 ** The epoxy that is used to cast these parts has a workable temperature range of –40°C to +105°C Under a normal rate of change, this does not include thermal shock. Variations in the transformer materials and environmental conditions may reduce the workable temperature range. This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice.
很抱歉,暂时无法提供与“107X”相匹配的价格&库存,您可以联系我们找货
107X
  • 1+340.065841+43.99271
  • 10+303.0165110+39.19981
  • 25+289.3806925+37.43581
  • 50+279.4681050+36.15347
  • 100+269.88635100+34.91392
  • 250+257.72089250+33.34014
库存:4
