106J
106J
    HAMMONDMANUFACTURING
    插件-5,27.4x22.4mm
    106J
106J 数据手册
10/6/22, 12:51 PM Miniature Audio Epoxy Potted (106 Series) - Hammond Mfg. Quality Products. Service Excellence. Miniature Audio Epoxy Potted 106 Series PC Board Mount Features Output power models from 5 to 1,500 milliwatt level available. P.C. board mount - square pin type (0.025" square typical) - see mechanical information below for lengths. Bifilar winding technique used on center tapped units for balanced resistive and capacitive characteristics. Rugged black epoxy potted construction produces a completely sealed unit withstanding severe environmental conditions including those of MIL-T-27 (Grade 5, Class S). For the more economical open type P.C. mount types please refer to the 148 and 149 series. Peak working voltage rating of: 200V Referring to figures 1-9, if connection is not used - no pin will exist. Gallery       Nominal Impedance Max. Primary D.C. Resistance Output Insertion (Ohms) D.C. ma. (Ohms) +/- 15% Milliwatts Loss Roll Off Drawing (*2) db (*3) -1 db (Hz.) (*4) Figure Typical Low Frequency Part No. Applicaton Primary Secondary (*1) Primary Secondary 106C Input 50000 1,500 ct 0 2400 52 10 1 60 7 106E Input 600 ct 600 9 65 83 500 1 150 8 106EE Input 600 ct 600 ct 9 65 83 500 1 150 9 106G Interstage 4000 600 ct 10 340 24 150 1 215 7 106H Interstage 4000 2,600 ct 10 340 100 150 1 215 7 106J Interstage 10000 2,000 ct 6.5 700 89 150 1 215 7 106M Interstage 20000 2,000 ct 4.5 1180 89 150 1 215 7 106Q Output 48 ct 3.2 32 2.4 0.3 1500 1 170 8 106R Output 48 ct 8 32 2.4 0.7 1500 1 170 8 106S Output 100 ct 3.2 22 4.4 0.3 1500 1 170 8 106T Output 100 ct 8 22 4.4 0.7 1500 1 170 8 106V Output 250 ct 8 14 11 0.7 1500 1 170 8 106W Output 500 ct 3.2 10 26 0.3 1500 1 170 8 106X Output 500 ct 8 10 26 0.7 1500 1 170 8 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/audio/106 1/2 10/6/22, 12:51 PM Miniature Audio Epoxy Potted (106 Series) - Hammond Mfg. https://www.hammfg.com/electronics/transformers/audio/106 2/2
106J
物料型号:106系列
器件简介: - 该系列是微型音频环氧灌封变压器,适用于PCB安装。 - 提供从5毫瓦到1500毫瓦级别的输出功率型号。 - 使用双线绕制技术,中心抽头单元具有平衡的电阻和电容特性。 - 坚固的黑色环氧灌封结构,完全密封,能够承受包括MIL-T-27(5级,S类)在内的恶劣环境条件。
引脚分配: - PCB安装类型为方形引脚(典型尺寸为0.025英寸方形)。 - 如果连接未使用,则不会有引脚存在。
参数特性: - 峰值工作电压等级:200V - 初级直流电阻(欧姆):±15% - 输出毫瓦数 - 插入损耗(分贝) - 低频滚降-1分贝(赫兹)
功能详解: - 该系列变压器适用于输入和中继级应用,具有不同的典型应用、标称阻抗、最大初级直流电流、直流电阻、输出毫瓦数、插入损耗、低频滚降等参数。
应用信息: - 适用于需要密封和环境耐受性的音频应用。
封装信息: - 提供了不同型号的详细机械信息,包括引脚长度等。
很抱歉,暂时无法提供与“106J”相匹配的价格&库存,您可以联系我们找货
