109N
109N
    HAMMONDMANUFACTURING
    插件-6,33.4x23.6mm
    109N
109N 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 109N MINIATURE EPOXY POTTED AUDIO TRANSFORMER • • • • • • Audio input, line matching and output transformers Epoxy potted in an attractive molded case, Pin type, P.C. board mount, (min. 0.187” length) Rugged epoxy potted construction produces a completely sealed unit withstanding severe environmental conditions. In some models where no center tap is present (on the secondary), pin 5 is omitted. Secondary may be used as primary and primary as secondary. Will withstand soldering for 10 sec. @ 260 degrees C. ambient temp. 85 degrees C max. 5 6 Power level: 2.0W @ 300 Hz. to 50 Khz. -Freq. range @ +0 dbm is 300 Hz. to 50 Khz. +/- 1.5db -Freq. range @ +10 dbm is 300 Hz. to 50 Khz. +/- 1.5db -Freq. range @ +27 dbm is 300 Hz. to 50 Khz. +/- 1.5db -Freq. measurements with no D.C. saturation. 4 MADE IN CANADA 2 1 3 ELECTRICAL SPECIFICATIONS Characteristic Input Impedance Output Impedance Output Power DCR Primary 1-3 Secondary 4-6 Inductance Primary Secondary Typical 10 KΩCT 600 ΩCT 2 Watts 660.0 Ω (330Ω/330Ω) 54 Ω (27Ω/27Ω) @ 300 Hz, 1.0 V OC 20.6 H 1.49 H Leakage Inductance 60.00 mH Impedance Primary Secondary @ 300 Hz, 1.0 V OC 41.00 KΩ 3.04 KΩ SCHEMATIC DIAGRAM Frequency Response Unbalanced DC Turns ratio Dielectric Strength Temperature Range PRIMARY 1 ±1.5db from 300Hz to 50KHz 6mA Max. 4.08:1 100 Vrms -40 To 105°C** PCB LAYOUT 10KΩ CT 2 N.T.S. 3 SECONDARY 6 5 600 Ω CT 4 TYPICAL TEST CIRCUIT PRIMARY R S/ SECONDARY 2 RL Measurement instruments Hp4192a impedance analyzer Hp3456a DVM Keithley 2002 DVM R S/ OUT 2 D scope series iii audio analyzer **The epoxy that is used to cast these parts has a workable temperature range of –40°C to +105°C Under a normal rate of change, this does not include thermal shock. Variations in the transformer materials and environmental conditions may reduce the workable temperature range. This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice.
