Speaker Matching (119 Series)
SPEAKER MATCHING
TRANSFORMER
Tube Audio
• Audio isolation unit (ie...separate primary and secondary)
• Built in response to requests from the "Collins Collectors Association" to match "classic" high impedance audio out
puts to modern low impedance speakers.
• Unit can also be used reverse connected to match "classic" high impedance speakers with newer equipment.
• Primary: 600 Ohm (with 6" wire leads)
• Secondary: 8 Ohm with 4 Ohm center tap (with solder lugs)
• Power: Rated at 12 watts
• Excellent frequency response: 30 Hz. - 20 Khz. (+/- 1 db @ Full Power - 1 Khz. Reference)
• Weight: 1 pound, 4 oz.
• Mounting: 2 hole bracket mount - on 2 13/16" mounting hole centers.
Dimensions (Inches)
Part No.
119DA
A
B
C
D
G
Mtg. Hole
3.28
2.35
2.00
2.81
0.187
Schematic & Hook Up Data
Blk
8 Ohm
600 Ohms
4 Ohm
Blk
0 Ohm
PRI
SEC
EUROPE
Basingstoke, UK 01256 812812
AUSTRALIA
Queenstown, Australia 61-8-8240-2244
CANADA
www.hammondmfg.com
Guelph, Ontario (519) 822-2960
St. Laurent, Quebec (514) 343-9010
83
Cheektowaga, NY (716) 630-7030
USA
很抱歉,暂时无法提供与“119DA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+444.338981+57.76263
- 10+395.8849410+51.46376
- 25+378.0573825+49.14624
- 50+365.0973250+47.46147
- 100+352.57918100+45.83416
- 250+336.68374250+43.76780
