Hammond Mfg. Co. Ltd., Electronics Division
1750C
PRIMARY
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
RED
50 mADC
Designed for drop in replacement of original
units.
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 9" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-1.0dB reference @ 1KHz)
Distortion is less than 1% @ 70Hz
SECONDARY
BLK COM
5000 Ohm BRN
8000 Ohm BLU
YEL 3.2 Ohm
5 WATTS
70Hz - 15kHz
BLK
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Max PRI DC
Typical
5000/8000 Ohms
3.2 Ohms
5W
50mA
DCR
Primary Red-Brown
Primary Brown-Blue
Secondary Black-Yellow
255.84 Ohms
73.89 Ohms
0.295 Ohm
Inductance
Impedance
Primary Red-Brown
Primary Red-Blue
@ 1.0 kHz, 1.0 V OC
14.25H
84.12 KOhm
20.42H
122.68 KOhm
64.53 mH
154.90 Ohm
RE
DA
TE
C
DB
5
BL RN - WA
K - B TT
YE LU: S
L:
7
5
3.2 000 0Hz
/8 -1
MA
DE 00 kHz
50
IN
mA
CA
DC
NA
DA
17
50
C
YEL
B
RED
BRN
A
BLU
D
G
NOTE: ALL LEADS 9" LONG MIN.
Leakage Inductance
Primary Red-Brown
Primary Red-Blue
@ 1.0 kHz, 1.0 V SC
54.28 mH
74.48 mH
Dielectric Strength
Temperature Range
1500VRMS
-40 to 105 degC
Dimensions
A 2.813” ±0.063
B 1.560” ±0.125
C
D
1.683” ±0.063
2.375” ±0.063
G
0.187” ±0.015
TYPICAL TEST CIRCUIT
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
TEST CONDITIONS
PRIMARY
R S/
2
Keithley 2010 DVM
Hp4192a impedance analyzer
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
SECONDARY
RL
R S/
OUT
2
Release 2: 02.12.2021
www.hammfg.com
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission
of Hammond Manufacturing. Data subject to change without notice.
www.hammfg.com
很抱歉,暂时无法提供与“1750C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+511.904151+66.35253
- 10+456.0732410+59.11578
- 25+435.5258725+56.45245
- 50+420.5972050+54.51741
- 100+406.17212100+52.64764
