Hammond Mfg. Co. Ltd., Electronics Division
www.hammondmfg.com
1760F
TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER
PRIMARY
BRN
Designed for drop in replacement of original
units.
Constructed to look similar to original factory
units (where possible).
Material used & design specifications were kept
as close as possible to the original part to
preserve the stock "tone".
Open style with minimum 7" long primary and
secondary leads
Frequency response 70Hz - 15KHz
(0/-2.5dB reference @ 1KHz)
Distortion is less than 3% @ 70Hz
SECONDARY
WHT 16 Ohm
GRN 8 Ohm
RED
6950 CT
Ohm
BLU
YEL
4 Ohm
BLK
COM
70Hz - 15kHz
15W
ELECTRICAL SPECIFICATIONS
Characteristics
Input Impedance
Output Impedance
Output Power
Typical
6950 Ohms
4, 8 & 16 Ohms
15W
DCR
Primary Brown-Blue
Secondary Black-Yellow
Secondary Black-Green
Secondary Black-White
BLK
BL
K/Y
C
17
B
EL LU- 15
/G RE W
RN D/W BR 70H
MA
HT N: z-1
DE
IN
: C 69 5k
CA
OM 50 Hz
NA
DA
/4 CT
/8
D
60
AT
E
Y EL
F
GRN
WHT
/16
B
147.90 Ohms
0.171 Ohm
0.245 Ohm
0.476 Ohm
BRN
A
RED
D
G
Inductance Impedance
Primary Brown-Blue
BLU
@ 1.0 kHz, 1.0 V OC
2.56H
15.89 KOhm
Leakage Inductance
Primary Brown-Blue
@ 1.0 kHz, 1.0 V SC
3.68 mH
Dielectric Strength
Temperature Range
1500VRMS
-40 to 105 degC
Dimensions
A 3.250” ±0.063
B 2.063” ±0.125
C 1.995” ±0.063
Keithley 2010 DVM
Hp4192a impedance analyzer
D
G
2.813” ±0.063
0.187” ±0.015
TYPICAL TEST CIRCUIT
TEST CONDITIONS
Measurement instruments:
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
NOTE: ALL LEADS 7" OUT MIN.
PRIMARY
R S/
SECONDARY
2
* All graphs input level 27dBu @1.0KHz reference.
**The results are typical and are subject to normal manufacturing and
electrical tolerances.
RL
R S/
OUT
2
www.hammondmfg.com
R S/
2
RL
R S/
OUT
2
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission
of Hammond Manufacturing. Data subject to change without notice.
www.hammondmfg.com
很抱歉,暂时无法提供与“1760F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+859.23720
- 200+342.84600
- 500+331.38720
- 1000+325.72800
