10/5/22, 1:59 AM
General Replacement Tube Output (8 Watt) Push-Pull (125H Series) - Hammond Mfg.
Quality Products. Service Excellence.
General Replacement Tube Output (8 Watt) Push-Pull 125H Series
Features
Designed for general purpose or replacement use in push-pull tube output circuits.
Frequency response: 150 Hz. - 15 Khz (+/- 1db max. ref. 1 Khz)
Open style with minimum 5" long primary leads, secondary solder lugs for convenient
secondary connections.
Also see our 125J Series.
For single ended use, see our 125SE Series.
For more impedance options, see our universal impedance push-pull 125 Series.
Primary
Secondary
Audio
Impedance
Impedance
Primary
Weight
Mounting
Part No.
Watts
(Ohms)
(Ohms)
Inductance
(lbs.)
125H
8
10K
2, 4 or 8
5.60 H
0.55
Overall Dimensions
A
B
C
2.81 1.00 1.63
Hole
D
G
2.38
0.19
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
https://www.hammfg.com/electronics/transformers/audio/125h
1/1
