Hammond Mfg. Co. Ltd., Electronics Division
www.hammfg.com
125B
UNIVERSAL PUSH-PULL “CLASSIC” TUBE OUTPUT TRANSFORMER
Designed for general purpose or replacement use in push-pull tube output circuits.
For single ended use, see our 125SE Series.
Frequency response: 150 Hz. - 15 Khz at full rated power (+/- 1db max. ref. 1 Khz) also see graphs for more
detailed response data
Open style with minimum 5" long primary leads.
Secondary solder lugs for convenient secondary connections (except 125B - uses minimum 5" secondary
leads).
Primary impedances from 1,200 to 25,000 Ohms. (For the full range of impedances see page 6)
Secondary impedances from 1.5 to 15 Ohms.
Designed for general purpose or replacement use (not Hi-Fi), in tube output circuits.
GRN (3)
ORG (2)
BLK (1)
WHT (6)
BLU
VIO (5)
YEL (4)
RED
BRN
www.hammfg.com
ELECTRICAL SPECIFICATIONS**
Characteristic
Input Impedance
Output Impedance
Output Power
Primary - DCR
Blue – Brown
Secondary DCR
1–2
1–3
1–4
1–5
1–6
Inductance
Primary – Blue – Brown
Sec – 1 – 2
Sec – 1 – 3
Sec – 1 – 4
Sec – 1 – 5
Sec – 1 – 6
Impedance
Sec – 1 – 2
Sec – 1 – 3
Sec – 1 – 4
Sec – 1 – 5
Sec – 1 – 6
Frequency Response
Dielectric Strength
Temperature Range
Typical
1200 - 25000
1.5 - 15
5 Watts
Schematic and Hook Up Data
PRIMARY
SCHEMATIC
SECONDARY
BRN
(PLATE)
WHT (6)
296
143 m
290 m
443 m
608 m
788 m
@ 1.0 kHz, 1.0 V OC
3.70 Hy
0.22 mH
1.52 mH
2.97 mH
10.9 mH
19.1 mH
@ 1.0 kHz, 1.0 V OC
16.7 K
1.27
7.58
20.6
46.7
86.4
See graphs for specific
response, Typ. 1.0db from
100Hz to 15KHz
1500Vrms
Up to 105C
VIO (5)
YEL (4)
RED
(B+)
GRN (3)
ORG (2)
BLU
(PLATE)
BLK (1)
125B
DATE CODE
5 WATTS
MADE IN CANADA
www.hammfg.com
www.hammfg.com
www.hammfg.com
www.hammfg.com
Hook-Up Data
Connect
Speaker To
(Secondary
Lugs)
1&2
2&3
3&4
4&5
5&6
1&3
2&4
3&5
4&6
1&4
2&5
3&6
1&5
2&6
1&6
1.5
Voice Coil Impedance (Ohms)
3.2
4
6
8
2
12
15
Resulting Total Primary Impedance (Below), Blue Wire to Brown Wire (Ohms)
27000
18000
16500
10000
8500
5400
4200
3300
2400
2150
1550
1300
24000
22000
13500
11000
7200
5600
4400
3200
2900
2050
1700
1400
21600
18000
11500
9000
7000
5100
4600
3300
2700
2200
1700
1200
PRIMARY
TYPICAL TEST CIRCUIT
R S/
27000
22000
15000
11200
8800
6400
5800
4100
3400
2800
2100
1500
21600
16800
13200
9600
8700
6150
5100
4200
3150
2300
26400
19200
17400
12300
10200
8400
6300
4500
24000
21500
15500
12800
10200
8000
5600
SECONDARY
2
RL
Measurement instruments
Hp4192a impedance analyzer
Hp3456a DVM
Keithley 2002 DVM
D scope series iii audio analyzer
Wayne Kerr 3255B with a 3265B
22500
17600
12800
11600
8200
6800
5600
4200
3000
R S/
OUT
2
* All graphs input level 20dbu.
** The results are typical and are subject to normal manufacturing and electrical tolerances.
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice. Revision 1: 05.25.2021
很抱歉,暂时无法提供与“125B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+588.554061+76.18219
- 10+524.3185910+67.86758
- 25+500.6993925+64.81032
- 50+483.5309150+62.58804
- 100+466.94741100+60.44148
