1750NA
1750NA
    HAMMONDMANUFACTURING
    螺栓安装
    1750NA
1750NA 数据手册
Hammond Mfg. Co. Ltd., Electronics Division www.hammondmfg.com 1750NA PRIMARY TUBE GUITAR AMPLIFIER - OUTPUT TRANSFORMER • • • • • Designed for drop in replacement of original 6000 Ohm units such as Marshall1 JTM30/60 (Drake 292-772 ) Constructed to look similar to original factory units (where possible). Material used & design specifications were kept as close as possible to the original part to preserve the stock "tone". Frequency response 70Hz - 15KHz (0/-1dB reference @ 1KHz) Distortion is less than 1% @ 70Hz CT 18 12 COM 17 10 8 Ohm 16 Ohm 8 14 50Hz-12kHz 30 WATT A H 17 50 NA 12 MA D P Pinin 12 E IN 12 - P CAN 10 - P in 1 in 0: ADA 8: 16 8   8 ELECTRICAL SPECIFICATIONS Characteristics Input Impedance Output Impedance Output Power SECONDARY Typical 6000 Ohms 8 & 16 Ohms 30 W TE DA 7 D J C B 13 DCR Primary 18-14 Secondary 12-10 (8 Ohm) Secondary 12-8 (16 Ohm) Inductance Impedance Primary 18-14 Secondary 12-10 (8 Ohm) Secondary 12-8 (16 Ohm) 147.36 Ohms 0.580 Ohm 0.820 Ohm E E @ 1.0 kHz, 1.0 V SC 10.26 mH Dielectric Strength Temperature Range 2500VRMS -40 to 105 degC TEST CONDITIONS 18 E @ 1.0 kHz, 1.0 V OC 8.00H 49.78K Ohm 37.8mH 410.3 Ohm 76.64mH 716.6 Ohm Leakage Inductance Primary 18-14 Measurement instruments: D scope series iii audio analyzer Wayne Kerr 3255B with a 3265B E G 13 Pin 18 -P 14 in 17 - BOTTOM LABEL Pin 1 4: 17 60 00  18 CT Dimensions A 3.000” ±0.063 C 2.465” ±0.063 E 0.300” ±0.030 H 2.500” ±0.063 B 2.500” ±0.125 D 1.600” ±0.063 G 0.219” ±0.063 J 2.000” ±0.063 TYPICAL TEST CIRCUIT PRIMARY Keithley 2010 DVM Hp4192a impedance analyzer 17 50 NA R S/ SECONDARY 2 RL * All graphs input level 27dBu @1.0KHz reference. **The results are typical and are subject to normal manufacturing and electrical tolerances. 1 R S/ OUT 2 DISCLAIMER: Hammond Mfg. is not affiliated with Fender Musical Instruments Corp., Marshall Amplification, Yorkville/Traynor, AMPEG or VOX Amplification companies. Amplifier model names are trademarks of the amplifier companies and are just listed here for reference purpose only. www.hammondmfg.com This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of Hammond Manufacturing. Data subject to change without notice. www.hammondmfg.com
