10/3/22, 1:31 AM
Universal Push-Pull Tube Output (125A-125E Series) - Hammond Mfg.
Quality Products. Service Excellence.
Universal Push-Pull Tube Output 125A-125E Series
Audio
Features
Designed for general purpose or replacement use in push-pull tube output circuits.
For single ended use, see our 125SE Series.
Frequency response: 150 Hz. - 15 Khz at full rated power (+/- 1db max. ref. 1 Khz)
Open style with minimum 5" long primary leads.
Secondary solder lugs for convenient secondary connections (except 125B - uses
minimum 5" secondary leads).
Primary impedances from 1,200 to 25,000 Ohms.
Secondary impedances from 1.5 to 15 Ohms.
For smaller sized units (but fewer impedance options) see our multiple impedance 125H
Series.
Gallery
Audio
Max. D.C. Bias Per Side
Primary
Weight
Part No.
Watts
(ma)
Inductance
(lbs.)
A
Overall Dimensions
B
C
D
Mounting Hole
G
125A
3
14.94 H
0.19
2.06
1.25
1.19
1.75
0.19
125B
5
35
8.97 H
0.3
2.38
1.38
1.38
2.00
0.19
125C
8
45
5.60 H
0.5
2.81
1.50
1.69
2.38
0.19
125D
10
55
4.48 H
1
3.25
1.75
2.00
2.81
0.19
125E
15
60
2.99 H
1.5
3.69
2.00
2.31
3.13
0.19
Hook-Up Data
Connect
Speaker To
(Secondary Lugs)
Voice Coil Impedance (Ohms)
1.5
2
3.2
4
6
8
12
15
Resulting Total Primary Impedance (Below), Blue Wire to Brown Wire
https://www.hammfg.com/electronics/transformers/audio/125a-125e
1/2
10/3/22, 1:31 AM
Connect
Speaker To
1.5
(Secondary Lugs)
2
3.2
4
6
8
12
15
1&2
27000
2&3
18000
24000
3&4
16500
22000
4&5
10000
13500
21600
27000
5&6
8500
11000
18000
22000
1&3
5400
7200
11500
15000
21600
2&4
4200
5600
9000
11200
16800
22500
3&5
3300
4400
7000
8800
13200
17600
26400
4&6
2400
3200
5100
6400
9600
12800
19200
24000
1&4
2150
2900
4600
5800
8700
11600
17400
21500
2&5
1550
2050
3300
4100
6150
8200
12300
15500
3&6
1300
1700
2700
3400
5100
6800
10200
12800
1&5
1400
2200
2800
4200
5600
8400
10200
2&6
1700
2100
3150
4200
6300
8000
1&6
1200
1500
2300
3000
4500
5600
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“125A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+577.791951+74.89284
- 10+514.6784310+66.71213
- 25+491.4898025+63.70644
- 50+474.6377850+61.52210
- 100+458.36396100+59.41270
