Hammond Mfg. Co. Ltd., Electronics Division
www.hammfg.com
124 Series
Tube Driver – Interstage Transformer
124B
SCHEMATIC
Features:
Designed for general purpose or replacement use in pushpull or phase inverter tube driver circuits.
Frequency response 150Hz-15KHz (+1/-3dB) @1KHz
reference.
Unit has no gap for DC bias current present in SE mode.
Not recommended for single ended applications.
Open style with minimum 6" long leads out.
49% Nickel laminations for greater fidelity compared to
124A with grain-oriented steel.
Available in coil-only configuration for enthusiasts’ own
choice of lamination (model 124C)
Weight: 5.9 oz.
PRIMARY
RED
10K Ohms
SECONDARY
GRN1
BLK
90K Ohms CT
BLU
GRN2
ELECTRICAL SPECIFICATIONS
Characteristics
Typical
Input Impedance
Output Impedance
Output Power
DCR RED-BLUE
DCR GRN1-GRN2
Dielectric Strength
Temperature Range
10K Ohms
90 KOhms CT
5W
405 Ohms ±20%
1525 Ohms ±20%
500V RMS
up to 105 degC
Inductance | Impedance
PRI RED-BLUE
Leakage Inductance
PRI RED-BLUE
@ 150 Hz, 2.0 V OC
65.38H
71.46 KOhms
@ 150 Hz, 2.0 V SC
37.4mH
GREEN
BLACK
GREEN
RED
BLUE
Minimum 6" leads out
DIMENSIONAL DETAILS:
This drawing and the information in it is the property of Hammond Manufacturing. It may not be reproduced, transmitted or used in any manner whatsoever without the written permission of
Hammond Manufacturing. Data subject to change without notice.
PERFORMANCE GRAPHS:
MEASUREMENT INSTRUMENTS
dScope Series III Audio Analyzer (THD+N & Phase Shift Graphs)
Wayne Kerr 3255B with a 3265B Inductance Analyzer
Voltech AT5600 Wound Component Tester (Frequency Response Graph)
HP 4192a LF Impedance Analyzer
Keithley 2010 DVM
**The results are typical and are subject to normal manufacturing and electrical tolerances.
www.hammfg.com
TEST CONDITIONS
PRIMARY
R S/
2
R S/
2
SECONDARY
RL
OUT
Release 2: 11052020
