10/7/22, 9:25 AM
Audio Broadcast Quality (560 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Audio Broadcast Quality 560 Series
Features
Rugged black epoxy potted case with 9 pin connections (.025" square by 0.5" long).
Frequency response minimum @ 0 dbm +/- 1 db max. (+/- 0.5 db is typical) of 30 Hz. to
30 Khz., except 560Q which is 30 Hz. to 15 Khz. - see data sheets below for more detail.
Higher signal levels possible with reduced low frequency performance.
Insertion loss of 1 db maximum
Electrostatic shield between primary & secondary connected to core and brought out to
pin "SH".
Humbucking construction
Balanced split windings on pri. & sec. for circuit versatility.
Primaries and secondaries can be reversed for impedance matching.
Overall dimensions 1.64" (41.7 mm) x 1.33" (33.8 mm) x 0.85" (21.6 mm) high max.
Shipping weight 4 oz. (0.1 kg)
Nominal Impedance (Ohms)
Part No.
Application
560C
560E
Overall Dimensions
Primary
Secondary
A
B
C
D
E
F
G
H
Emitter or mic to Line
12/48
150/600
1.33
1.64
0.85
0.20
1.30
0.14
0.36
0.17
50/200
150/600
1.33
1.64
0.85
0.20
1.30
0.14
0.36
0.17
560G
Isolating or Hybrid
150/600
150/600
1.33
1.64
0.85
0.20
1.30
0.14
0.36
0.17
560J
Collector to Line or Line to Base
150/600
1200/4800
1.33
1.64
0.85
0.20
1.30
0.14
0.36
0.17
https://www.hammfg.com/electronics/transformers/audio/560
1/2
10/7/22, 9:25 AM
Part No.
Application
Primary
Overall Dimensions
Secondary
A
B
C
D
E
F
G
H
560L
Collector to Line or Matching
150/600
5K/20K
1.33
1.64
0.85
0.20
1.30
0.14
0.36
0.17
560N
Collector to Line
150/600
10K/40K
1.33
1.64
0.85
0.20
1.30
0.14
0.36
0.17
560Q
Matching or Bridging
10k/40k
10K/40K
1.33
1.64
0.85
0.20
1.30
0.14
0.36
0.17
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“560L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+751.847891+97.45380
- 10+669.7002210+86.80590
- 25+639.5141925+82.89322
- 50+617.5864050+80.05096
- 100+596.41011100+77.30611
