560N
560N
    HAMMONDMANUFACTURING
    插件-8,41.7x33.8mm
    560N
560N 数据手册
10/7/22, 9:25 AM Audio Broadcast Quality (560 Series) - Hammond Mfg. Quality Products. Service Excellence. Audio Broadcast Quality 560 Series Features Rugged black epoxy potted case with 9 pin connections (.025" square by 0.5" long). Frequency response minimum @ 0 dbm +/- 1 db max. (+/- 0.5 db is typical) of 30 Hz. to 30 Khz., except 560Q which is 30 Hz. to 15 Khz. - see data sheets below for more detail. Higher signal levels possible with reduced low frequency performance. Insertion loss of 1 db maximum Electrostatic shield between primary & secondary connected to core and brought out to pin "SH". Humbucking construction Balanced split windings on pri. & sec. for circuit versatility. Primaries and secondaries can be reversed for impedance matching. Overall dimensions 1.64" (41.7 mm) x 1.33" (33.8 mm) x 0.85" (21.6 mm) high max. Shipping weight 4 oz. (0.1 kg)   Nominal Impedance (Ohms) Part No. Application 560C 560E Overall Dimensions Primary Secondary A B C D E F G H Emitter or mic to Line 12/48 150/600 1.33 1.64 0.85 0.20 1.30 0.14 0.36 0.17 Emitter or mic to Line 50/200 150/600 1.33 1.64 0.85 0.20 1.30 0.14 0.36 0.17 560G Isolating or Hybrid 150/600 150/600 1.33 1.64 0.85 0.20 1.30 0.14 0.36 0.17 560J Collector to Line or Line to Base 150/600 1200/4800 1.33 1.64 0.85 0.20 1.30 0.14 0.36 0.17 https://www.hammfg.com/electronics/transformers/audio/560 1/2 10/7/22, 9:25 AM Audio Broadcast Quality (560 Series) - Hammond Mfg. Nominal Impedance (Ohms) Part No. Application Primary Overall Dimensions Secondary A B C D E F G H 560L Collector to Line or Matching 150/600 5K/20K 1.33 1.64 0.85 0.20 1.30 0.14 0.36 0.17 560N Collector to Line 150/600 10K/40K 1.33 1.64 0.85 0.20 1.30 0.14 0.36 0.17 560Q Matching or Bridging 10k/40k 10K/40K 1.33 1.64 0.85 0.20 1.30 0.14 0.36 0.17 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/audio/560 2/2
很抱歉,暂时无法提供与“560N”相匹配的价格&库存,您可以联系我们找货
